hugo-specb Posted July 13, 2012 Share Posted July 13, 2012 I have a 06 spec b with 136 k , I'm looking for a timing belt kit .. any recommendations on any brand ?? Thanks Link to comment Share on other sites More sharing options...
northstar Posted July 13, 2012 Share Posted July 13, 2012 I asked a similar question a while back. Seems like Gates is the one to go with. I'm about to order mine (105k maintenance). Link to comment Share on other sites More sharing options...
Max Capacity Posted July 13, 2012 Share Posted July 13, 2012 The belt should have been changed at 105,000 miles. But yes, the Gates kit is the same as OEM. I found mine in the for sale forum here. Or buy it from one of the Vendors on here. Support those that support the forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dzehner2 Posted July 13, 2012 Share Posted July 13, 2012 +1 Gates all the way! Let me know if you need a tensioner... I've got one with the grenade pin in if you want it (for a few bucks). It's soooo much easier to just put another one in than to try to reload one (unless you have a press, in which case that's pretty straightforward). Link to comment Share on other sites More sharing options...
hugo-specb Posted July 13, 2012 Author Share Posted July 13, 2012 I know I should' ve done it before but I bought the cat with 120 k and I didn't know if the previous owner had it replaced or not but I got in contact with him not long ago and he told me he didn't change it ... Thank you guy for your help ... I guess I'm gonna go for Gates... @ Dezehner I will let u know this next week about the tensioner I ll send u a pm .. thanks Link to comment Share on other sites More sharing options...
VermontGT Posted July 14, 2012 Share Posted July 14, 2012 Who makes which components that come in the Gates kit? I know that they make the belt, but who makes the two smooth rollers, the cogged roller, the tensioner, and the water pump? Link to comment Share on other sites More sharing options...
rps13de Posted July 15, 2012 Share Posted July 15, 2012 I purchased the gates kit a little while back. I got a great price from vendors here. Link to comment Share on other sites More sharing options...
rob-2 Posted July 15, 2012 Share Posted July 15, 2012 Why not stay stock? Link to comment Share on other sites More sharing options...
king_j Posted July 16, 2012 Share Posted July 16, 2012 Why not stay stock? $$$. Gates is comparable at almost half the cost (kit). Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 16, 2012 Share Posted July 16, 2012 I'd strongly advise you to change your timing belt tensioner as well. @ 55000 miles, mine decided to die on me. Luckily (strong emphasis on this word), my engine still runs. Fairly rare occurrence for these tensioners to fail but it does happen. Since you'll be 'in there', take this opportunity to change that part as well. Link to comment Share on other sites More sharing options...
lowwill Posted July 17, 2012 Share Posted July 17, 2012 Wow 136k on original belt..... Im babying the wagon with 106k untill next week change out. Link to comment Share on other sites More sharing options...
ericem Posted July 17, 2012 Share Posted July 17, 2012 usually the belt is fine just when a idler seizes or a tensioner fails belt snaps. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 17, 2012 Share Posted July 17, 2012 usually the belt is fine just when a idler seizes or a tensioner fails belt snaps. ^+1 like so: http://www.subaruoutback.org/forums/438221-post5.html Though this was a bit extreme.. Usually, the idler that fails is the small one to the right of the tensioner: [ame=http://www.youtube.com/watch?v=ZVEk0-UIE-k]Project Import: Subaru WRX STi Timing Belt Pulley Tensioner Bearing Goes Bad www.projectimport.com - YouTube[/ame] Link to comment Share on other sites More sharing options...
stocklgt Posted July 17, 2012 Share Posted July 17, 2012 +1 on the Gates kit with the Kevlar belt. Just did mine at 97K. You can buy from Boston Motorsports or PM M Sprank, both have great pricing at around $300. Link to comment Share on other sites More sharing options...
