chillij715 Posted March 29, 2011 Share Posted March 29, 2011 ok so i have a problem... i replaced my clutch and when tighten a mount bolt(c pic, T2) the nut inside the frame broke off its weld so now i cant take the bolt out or put it in what can i do? ima do something tomorrow night so hopefully someone can give me a lil advice. so far the plan is to cut or drill out a hole big enofe to fit the welders head then patch it over. can i get better access if i go threw the passenger side floor board behind the computor? or the frame rail where the nut is? or is there a way to not cut anything? (oh plz let there b a way) thanks Link to comment Share on other sites More sharing options...
papp101 Posted March 29, 2011 Share Posted March 29, 2011 get a giant freakin ubolt and run it up over the frame mount. or drill a hole all the way through the frame and put in a giant long bolt and put a nut on top of the frame. Link to comment Share on other sites More sharing options...
