BrandonspecB Posted November 21, 2013 Share Posted November 21, 2013 Event: Dyno Pull Location: Ziptie Dynowerks Date: 11/19/2013 Ambient Temp: 60-70 or so in the shop Elevation: 4200' Weather: Light rain Car: 2007 Spec B Tuner: Me Dyno Info: Mustang Transmission: 6-speed Gear: 3rd Peak Horse Power at RPM: 467 @ ~6300 Peak Torque at RPM: 454 @ ~4900 Baseline hp/tq for a stock on same dyno: Don't know Target Boost: 29 Target AFR: 11.7-12.0 SAE Correction factor: 1.15 Fuel: 91 and meth/water injection Engine/Power Modifications: ATP GTX3576r EWG, TiAL MVR, TurboXS FMIC, FIC 775s, DW65c, Kamak ELH and UP, Turbosmart Kompact BOV, Invidia downpipe w/electric cutout, Cobb SF with custom CAI, Perrin 3" inlet, Snow Performance stage 2 methanol injection, Killer B oil pan, windage tray and pickup Driveline Modifications: ACT clutch and flywheel, Group N trans and engine mounts, Whiteline rear diff bushings, shifter bushings Suspension Modifications: Bilstein HD struts, Swift lowering springs, Whiteline sway bars I really like this turbo. The power comes on a little late in the graph because it was ran in third gear. It spools 200 RPMs later than my TD06H 20g, but has way more airflow potential. I can reach over 30 psi by 4500 in 4th. It really is a nice, hard hitting turbo. Install was super easy too. I have to remember to turn the traction control off if I plan on getting on it in first or second otherwise it cuts the throttle due to wheel spin. A third gear pull can get squirrely if the road is a little bumpy. Lots of fun! Uncorrected numbers were 406 hp and 395 tq. My whole goal with this setup was to make over 400 whp uncorrected for elevation. I'm very pleased with the result.PowerDynePC.pdf Link to comment Share on other sites More sharing options...
BrandonspecB Posted November 21, 2013 Author Share Posted November 21, 2013 So here's a bit more info regarding this turbo. I couldn't find any data on it when I was doing research, so hopefully this will help someone out in the future. I've got a virtual dyno showing the difference between 3rd and 4th gears. Notice how the 3rd gear pull is within a few hp/tq of the actual dynograph. This has me believe that the 4th gear VD would be fairly close to actual. All you get is a bit more power under the curve from the additional engine loading that spools the turbo sooner. I was amazed how close it spooled compared to my 20g. The graph is from 3rd gears pulls on the same road. Also, the 20g curve is with a TMIC and 3576r is with a front mount. If I can figure out why my logger won't do complete pulls anymore, I'll post a boost graph of 4th gear. Some of the partial graphs show almost a vertical line when the turbo gets going. It's awesome. Link to comment Share on other sites More sharing options...
spc2125 Posted November 21, 2013 Share Posted November 21, 2013 WOW. Nice power! Link to comment Share on other sites More sharing options...
Corr Performance Posted November 21, 2013 Share Posted November 21, 2013 Nice Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 6, 2013 Author Share Posted December 6, 2013 Well, the stock location setup got boring after a few weeks so I've decided to go rotated with it. If anyone's interested I'll have back-to-back results between a stock location and rotated setup using the same turbo in a few weeks. I'd like to break 500 corrected on a Mustang dyno with the stock block, heads, and cams. Link to comment Share on other sites More sharing options...
charlie_sheen Posted December 6, 2013 Share Posted December 6, 2013 holy shitballs. 29psi on stock block? you're really testing the trans at that power level, shouldnt last much longer but great numbers! seems like a very fun car Link to comment Share on other sites More sharing options...
thisisthenewsic Posted December 6, 2013 Share Posted December 6, 2013 holy shitballs. 29psi on stock block? you're really testing the trans at that power level, shouldnt last much longer but great numbers! seems like a very fun car he's got a 6 speed. then can handle 600+ no problem. also. 29psi is definitely pushing the stock cylinders. I plan to run a few different maps on my fullrace twinscroll BorgWarner 8375 kit, 25psi, 20psi and 35 psi on e85, I went with a outfront motorsports closed deck 2.5l block to hold the extra psi. Link to comment Share on other sites More sharing options...
GTTuner Posted December 6, 2013 Share Posted December 6, 2013 Mustang Dyno = The heart breaker......WOW some serious power!!! Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 7, 2013 Author Share Posted December 7, 2013 Thanks for the comments guys. The new t04e compressor housing for the gtx3076 compressor showed up today. It will replace the t04b housing that ATP uses for their stock location setups. .82 t3 35r turbine housing will be here tomorrow and the rotated up and downpipes on Monday. Then the fun can begin! Link to comment Share on other sites More sharing options...
Rester5350 Posted December 7, 2013 Share Posted December 7, 2013 Wow man, your car is putting down some good power. What are your plans for the block after it pops? Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 7, 2013 Author Share Posted December 7, 2013 Wow man, your car is putting down some good power. What are your plans for the block after it pops? Depends on what breaks. If a piston goes and the block and rods are salvageable, I'll just put forged pistons in and freshen things up. If a rod goes and takes the block with it then I'll start from scratch and build something with forged pistons and rods. Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 12, 2013 Author Share Posted December 12, 2013 Things are coming along. Hopefully it'll be done tomorrow. Just need to build the intake and relocate the coolant fill tank. Link to comment Share on other sites More sharing options...
Th3Franz Posted December 13, 2013 Share Posted December 13, 2013 any plans to change the intake manifold? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 14, 2013 Author Share Posted December 14, 2013 No I'm going to stay with the stock manifold. The only other thing I'll do is heads and cams. And, who knows, maybe a 40r now that turbos are easy to swap Update: I got everything buttoned up today and drove the car home from the shop. First time I drove it since Monday. It felt really good. I'll get out tomorrow and see what needs to be adjusted in the tune and beat on it a bit. I don't have any completed pics yet. The one uploaded shows what the intake setup looks like. The turboxs fmic piping didn't need to be modified at all. Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 14, 2013 Author Share Posted December 14, 2013 Got some pics of the finished product and did a bit of initial tuning. So far spool up is the same. No difference in torque. I'm going to head to rallysportdirect in a bit to pick up a t3 turbo blanket. After that I'll get to work on dialing in high rpm and see if there is a difference in peak power. Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 15, 2013 Author Share Posted December 15, 2013 Had a really nice 34 degree afternoon to get things dialed on the tune. Surprisingly, there wasn't much power to be found. The graph is comparing the stock location and rotated setup on the same road and using 3rd gear. 4th gear brings power on around 500 RPMs sooner, but I get compressor surge during spool up if I get on it hard in 4th from low revs. Boost is 29 psi for both. AFR is 12:1 for both. Timing is almost identical. I had to pull a couple degrees out during spool up on the rotated setup. Seat of the pants tells me the rotated setup pulls a bit harder up top, which is seen in the graph. The rotated setup pulls smoother too. Both these pulls ran an identical 1.545 60-80 mph. Honestly, if I didn't have plans to make more power and had known what I know now from having both setups, I probably wouldn't have gone rotated. Link to comment Share on other sites More sharing options...
Th3Franz Posted December 15, 2013 Share Posted December 15, 2013 Is your block sleeved? Any details of your engine build? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 15, 2013 Author Share Posted December 15, 2013 It's a completely stock 122,000 mile engine. It's never been out of the car or even had the valve covers off. I'm only making around 420 uncorrected whp. The corrected numbers are used for comparisons. So, cylinder pressures are only enough to make 420 whp. Cylinder pressure, not boost, is what will send a rod out the side of the block. At this elevation you can get away with running higher boost if you've got a turbo that is ok at higher PR. If I were at sea level I'd need much less boost pressure to make an uncorrected 420 whp. High boost is an issue if you are blowing off intercooler couplers or if you have a crappy intercooler that can't get the heat out of the charge. High boost will also wear out a turbo quicker. 30 psi is absolutely nothing compared to the pressure in the combustion chamber. I've got a decent front mount, meth injection, and an air temp gauge to keep track of hot and cold side air temps. I make sure to not get on it if charge temps are too high. Interesting fact: Forced induction was first used in aircraft to counter the effects of altitude Link to comment Share on other sites More sharing options...
Th3Franz Posted December 16, 2013 Share Posted December 16, 2013 It takes a good amount of cylinder pressure to make 420 whp, so it will be interesting to see how long the original engine lasts for you. You do have the advantage that you tuned it yourself, so if you notice any knock you can easily adjust it if needed. Methanol helps prevent knock too. My stock rings got leaky at 95k miles after a year being at 350 whp and putting the whp to use on-track. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
mustangendsley Posted December 16, 2013 Share Posted December 16, 2013 FUNNY how people that live in snowy places have all this power and can hardly drive it. seems like your wheels will spin in any gear in the slippery conditions. Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 17, 2013 Author Share Posted December 17, 2013 It takes a good amount of cylinder pressure to make 420 whp, so it will be interesting to see how long the original engine lasts for you. You do have the advantage that you tuned it yourself, so if you notice any knock you can easily adjust it if needed. Methanol helps prevent knock too. My stock rings got leaky at 95k miles after a year being at 350 whp and putting the whp to use on-track. Yeah, this thing will go sooner or later. In fact I should probably do another compression test to see how it's holding up to the increased power levels so far. I just need it to live until spring. I really want to run an 11 second pass here in Salt Lake with a full weight car. It would be nice to do it on the stock engine. A little update, I turned the boost up to 30 psi and made 488 corrected. That pull ran a 1.48 60-80. So very close to 500... The MAF is maxed at 5v on my 3.25" housing. I decided to go big and get a 4" MAF housing. It will be interesting to see how it works out. I couldn't find anybody online that has run that size MAF housing in draw through. So, I guess I get to be the guinea pig and see if it will be driveable. Link to comment Share on other sites More sharing options...
Th3Franz Posted December 17, 2013 Share Posted December 17, 2013 speed density time! -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
BrandonspecB Posted December 18, 2013 Author Share Posted December 18, 2013 I'm in a bit of a dilemma with speed density. I like my cutout and there's no way to run a cutout with speed density. I really, really want to convert over. That will give me a reason to buy an AP and have real time tuning. Problem I need to solve: High flowing exhaust with very little noise. I've bought my share of catbacks, but I always sell them because they're too noisy. Link to comment Share on other sites More sharing options...
spc2125 Posted December 18, 2013 Share Posted December 18, 2013 Why not just resonator or another high flow muffler after the dp ? Link to comment Share on other sites More sharing options...
spec.B Dream Posted December 18, 2013 Share Posted December 18, 2013 I too have bought and sold my share of catbacks for this car. Why can't you run SD with the cutout? Link to comment Share on other sites More sharing options...
