ripsweetness Posted March 14, 2009 Share Posted March 14, 2009 I have 740 Injectors to install in a 2008 GT. There is nothing on this site about them. Has anybody seen install instructions on another forum or know where to find some info on it? Link to comment Share on other sites More sharing options...
fonts Posted March 14, 2009 Share Posted March 14, 2009 Are they Deatschwerks??? If so are you sure you have the right ones?? I thought they did 740cc in side feed and 750cc in top feed. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted March 14, 2009 Share Posted March 14, 2009 check vacation pics they are very easy to do on our cars vs the 2.0 top feed Link to comment Share on other sites More sharing options...
PeterJMC Posted March 15, 2009 Share Posted March 15, 2009 2008's are top feed. Link to comment Share on other sites More sharing options...
ripsweetness Posted March 15, 2009 Author Share Posted March 15, 2009 Are they Deatschwerks??? If so are you sure you have the right ones?? I thought they did 740cc in side feed and 750cc in top feed. They came out of a 08 GT and im pretty sure he said they were DW 740's. Either he didnt know what he had or I got them mixed up. But now youre making me have doubts,thanks:confused:. They are baby blue if anyone knows what color they should for the top feed Link to comment Share on other sites More sharing options...
fonts Posted March 15, 2009 Share Posted March 15, 2009 Blue DW are top feed. Just wanted to make sure that you didn't get the job started and realize that you had wrong injectors. Link to comment Share on other sites More sharing options...
ripsweetness Posted March 18, 2009 Author Share Posted March 18, 2009 Dammit, if know one can answer this in the open forum im gonna have to go back to PMing the usual suspects:lol: Sorry guys I gave it a chance. Get ready whitetiger unclemat etc Link to comment Share on other sites More sharing options...
DukeTrout Posted March 20, 2009 Share Posted March 20, 2009 I'm curious as well. I did the fuel pump install and that went smoothly (except the gasket - had to go back near the finish and realign that puppy). Next up is injectors, and it would be great to get a visual walkthrough before diving in there. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
mattg Posted March 20, 2009 Share Posted March 20, 2009 I found this on the Turbo XS website, via NASIOC. The instructions are for a WRX and I'm not sure how they translate to a LGT. Drivers Side Injectors: Remove "green" protective bracket from the fuel rail assembly by the 5 bolts. This is a "PITA" but be patient and pull it out towards the rear of the car.Remove 2, 12mm bolts between the injectors securing fuel rail to the heads and 1, 12mm bolt at the front of the fuel rail.Disconnect electrical connectors from fuel injectorsPull up on fuel rail and slip out injectors one at a time. Be careful not to damage the fuel injector's rubber gaskets.Install TXS Fuel Injectors in reverse of task "4."Put everything back together from "Install the Larger Fuel Injectors" in reverse order. Passenger Side Injectors: Remove the coolant assembly located next to the intake manifold.Remove the various bolts securing hoses to the "green" bracket.Remove "green" protective bracket from the fuel rail assembly by the 4 bolts. This is a "PITA" but be patient.Remove 2, 12mm bolts between the injectors securing fuel rail to the heads, 1, 12mm bolt at the front of the fuel rail and 2, 12mm bolts at the top of the fuel rail.Disconnect electrical connectors from fuel injectorsPull up on fuel rail and slip out injectors one at a time. Be careful not to damage the fuel injector's rubber gaskets.Install TXS Fuel Injectors in reverse of task "6."Put everything back together from "Install the Larger Fuel Injectors" in reverse order. Link to comment Share on other sites More sharing options...
DukeTrout Posted March 21, 2009 Share Posted March 21, 2009 Cool, Matt. I'll poke around and see if that makes sense in a Legacy engine bay. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
AWDxBOOST Posted March 23, 2009 Share Posted March 23, 2009 2008's are top feed. oooohhhhh.....hahahah that sucks have fun with the GBOD if they still have em Link to comment Share on other sites More sharing options...
ripsweetness Posted March 24, 2009 Author Share Posted March 24, 2009 Well Ive started this project, and its looking pretty tight. I sent a pm to guys I think may have tried this already. I will let you know what i find out Duketrout. Link to comment Share on other sites More sharing options...
ripsweetness Posted April 4, 2009 Author Share Posted April 4, 2009 So I finally got the passenger side done. Took my time over the last week or so. It is a very tight spot, now the hard side tomorrow. Im gonna go cry myself to sleep:icon_cry: and then tackle it in the morning. Again I have been taking photos of this and plan on putting something together for the site, but as of now I think it would be worth paying a competent shop to do this. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted April 5, 2009 Share Posted April 5, 2009 gl man...it'll be worth it when you finish! the shop isn't going to have a much easier time than you, and if you diy, you know it will be done right Link to comment Share on other sites More sharing options...
korntera Posted July 14, 2009 Share Posted July 14, 2009 Any Pics, i may need to do this soon. Link to comment Share on other sites More sharing options...
franklin Posted July 28, 2009 Share Posted July 28, 2009 Any Pics, i may need to do this soon. +1 How nasty is this for an 05 ? Link to comment Share on other sites More sharing options...
nka Posted July 28, 2009 Share Posted July 28, 2009 +1... I got one to change soon, one is going to die ! I was looking at the driver side, I see there's a Torx bolt that hold the injector, can I just remove that to remove the injector or I really need to pull the fuel rail ? Mine are sidefeed like that : http://www.scoobytuner.com/products/?vApplicationID=40&sfID1=33&productID=1619 Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted August 29, 2009 Share Posted August 29, 2009 bump So how do you get the protective plate off the driver's side? The lower rear bolt is below the TGV solenoid and impossible to get to. I have been searching and searching. If I can get away w/o removing that intake mani, that would be great. Link to comment Share on other sites More sharing options...
brock_b Posted September 7, 2009 Share Posted September 7, 2009 Install instructions from the Haynes manual: 1. Relieve the fuel system pressure a. remove fuel pump fuse b. start engine and allow it to run until it stops 2. Remove engine cover 3. Disconnect the negative battery cable 4. If you are going to remove the #1 or #3 cylinder injector, remove the air intake duct and coolant reservoir 5. Disconnect the electrical connector from the injector 6. Remove the retaining screw and pull the injector straight up. 7. Remove and discard the old o-ring 8. Install new o-ring and apply a light coat of engine oil to the o-ring to protect it durring installation 9. Install in reverse order. Link to comment Share on other sites More sharing options...
Chubien Posted March 14, 2010 Share Posted March 14, 2010 Bump. So any chance of swapping Injectors on 07+ cars with topfeeds without having to remove the intake manifold? Has anyone managed to get this done? Or do we just have to bite the bullet and take the manifold off? Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted March 14, 2010 Share Posted March 14, 2010 Unbolt the IM and just lift it up about an inch. Link to comment Share on other sites More sharing options...
Chubien Posted March 15, 2010 Share Posted March 15, 2010 Gasket can be saved? Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted March 16, 2010 Share Posted March 16, 2010 Gasket can be saved? I sure hope so! I didnt change it. I didnt even fully remove the studs (I don't think, so everything stayed in place. I only needed to luft is up a bit to move / clear a fuel line. Something like that. I forget. It was on the passenger side front. Link to comment Share on other sites More sharing options...
m sprank Posted March 17, 2010 Share Posted March 17, 2010 I have done it on my topfeeds with just releasing the fuel rail. Two bolts on top the TGV's. Passenger side is easier than drivers. It sucks, but better than pulling the manifold again. Oh, the bracket covering the injectors is gone on my car too. I never put them back in after they came out the first time. Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted March 17, 2010 Share Posted March 17, 2010 I have done it on my topfeeds with just releasing the fuel rail. Two bolts on top the TGV's. Passenger side is easier than drivers. It sucks, but better than pulling the manifold again. Oh, the bracket covering the injectors is gone on my car too. I never put them back in after they came out the first time. same here. No way I was putting that thing back in! I absolutely had to lift my manifold slightly to get the fuel rail out of the way.. I think that is why I had to lift it. I also had to relocate a ground connection on the driver's side since I did not put that plate back on. Its been a while, I somewhat forget. Link to comment Share on other sites More sharing options...
