munje22 Posted June 27, 2013 Share Posted June 27, 2013 I bought xxr 522s for my 2005 legacy gt they are 18x9.5 and apparently the worker at tallmans tires said that the rims are too wide and are touching my struts. Has this been a problem with everyone? I've seen people running 10.5s with no problems. Does anyone know what I should do? Thanks Link to comment Share on other sites More sharing options...
JermTheElf Posted June 27, 2013 Share Posted June 27, 2013 offset? Link to comment Share on other sites More sharing options...
KCwagon Posted June 27, 2013 Share Posted June 27, 2013 I bought xxr 522s for my 2005 legacy gt they are 18x9.5 and apparently the worker at tallmans tires said that the rims are too wide and are touching my struts. Has this been a problem with everyone? I've seen people running 10.5s with no problems. Does anyone know what I should do? Thanks You should sell those wheels and get a width that works for your car. Link to comment Share on other sites More sharing options...
JermTheElf Posted June 27, 2013 Share Posted June 27, 2013 You should sell those wheels and get a width that works for your car. But they handle pot holes so well Link to comment Share on other sites More sharing options...
munje22 Posted June 27, 2013 Author Share Posted June 27, 2013 offset is 38+ and on forums people told me it would fit. Also I seen someone with the same setup except his fit. Also would spacers help? Link to comment Share on other sites More sharing options...
BA_SUBARU24 Posted June 28, 2013 Share Posted June 28, 2013 I was looking at XXR 527 and I was concerned about 17x8.25 not fitting lol. The stock oem rims on my 07 are 17x7 I believe. I don't think your tire guy would be lieing to you, they want to make money.. Link to comment Share on other sites More sharing options...
.clipse Posted June 28, 2013 Share Posted June 28, 2013 offset is 38+ and on forums people told me it would fit. Also I seen someone with the same setup except his fit. Also would spacers help? if you're on stock suspension then that might be the issue. wider fitment/lower offset wheels tend to hit the clunky stock suspension/bottom spring perch. that's what coilovers are for but yes, spacers should do the trick but be sure to roll your fenders to prevent rubbing on that side. Link to comment Share on other sites More sharing options...
munje22 Posted June 28, 2013 Author Share Posted June 28, 2013 Alright thanks for the info il prolly just go with about 20mm spacers and I might roll my fenders but I doubt it will rub since its stock suspension and if it does il still roll em and then il be set when I buy my coilovers. After that i just take the spacers off and il be set But yeah guys thanks a lot guys! Link to comment Share on other sites More sharing options...
munje22 Posted June 28, 2013 Author Share Posted June 28, 2013 Another thing I was wondering was if this setup would look ugly because its too wide Link to comment Share on other sites More sharing options...
.clipse Posted June 28, 2013 Share Posted June 28, 2013 Another thing I was wondering was if this setup would look ugly because its too wide ok well first off, xxr 522's are atrocious in general since the wider 522's spokes poke too far out of the barrel and look like spider crab wheels but other than that, lets do the math. +20mm spacers on 18x9.5 +38 wheels. you're already going to poke like crazy with the wheels alone since you're on stock suspension now adding +20 mm spacers? mexi-flush city. run a bare minimum spacer to have them barely clear your stock struts (+3 - +5mm spacers?). to have them remotely look decent, you're going to need to (lack for a better word) "stance" your car aka go moar low/camber/slightly stretched tires. without proper suspension to make these wheels 'work' you're going to end up looking like this: http://i43.photobucket.com/albums/e400/MiLLNuY/DSCN0291-1.jpg my $0.02 = sell the 522's and get suspension theeen get your wheels Link to comment Share on other sites More sharing options...
KCwagon Posted June 29, 2013 Share Posted June 29, 2013 There are a ton of threads on Nasioc regarding - putting wheels on your car that are are too wide. They include answers to issues such as this: 1) My wheels are rubbing my struts, what do I do ? 2) My tires are being chewed up by my fenders, what do I do? 3) My wheels don't look wide enough, what do I do ? 4) My wheels look too wide, what do I do ? 5) My friends have wider wheels, what do I do ? Link to comment Share on other sites More sharing options...
Sideways the Seven Posted June 29, 2013 Share Posted June 29, 2013 18x9.5 +38 will fit without rubbing the strut. You'll have to run either a 235/40/18 or 245/40/18 though. I had them for a couple months. That got old quick. Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Cone_Killer Posted June 29, 2013 Share Posted June 29, 2013 omg Link to comment Share on other sites More sharing options...
munje22 Posted June 30, 2013 Author Share Posted June 30, 2013 Well I'm going to be running stretched tires 225/40/18 and I have h tech springs that I could install but in thinking of selling those and just buying some coilovers and not putting the spacer on at all. Link to comment Share on other sites More sharing options...
S13lgt Posted July 3, 2013 Share Posted July 3, 2013 Hey everyone i need wheel help too! I did a little research but just want to verify what I found out. I'm looking to buy a set of 17x8 rpf1's for my 05 lgt. It's on coils no camber kits or arms ect. Right now debating between 35 offset and 45 offset. I come from the land of 240sx owners so I really badly want to go with a 35 offset just because lower the better. Unfortunately I'm planning on running a 245/40 sumitomo tire. Last thing I wanna do it roll the fenders and chip my paint.( I have beater 240's for that) should I be safe and just go for the 45 offset and 245's or does that have some complications I don't know about? Lol or will the 35's fit no problem? Thanks for all the help Andrew Link to comment Share on other sites More sharing options...
munje22 Posted July 11, 2013 Author Share Posted July 11, 2013 Yes I believe everything will fit s13. Coils give a lot more clearance Link to comment Share on other sites More sharing options...
