David E Posted March 21, 2013 Share Posted March 21, 2013 Searched but didn't find this info. Will a gauge cluster from a 2.2 work in a 2.5 ? Both are 120 mph so don't see an issue with the speedometer / odometer. Would be swapping the tach from the 2.5 into the 2.2 cluster. Link to comment Share on other sites More sharing options...
Carleton Posted April 2, 2013 Share Posted April 2, 2013 David, though I'm no expert the tach seems to be interchangeable. I've been reading about doing this to my tach-less manual Brighton wagon and it seems pretty straightforward. The only (non) issue is the red line for 2.5L engines is 500 rpm higher than the red line on 2.2Ls. Link to comment Share on other sites More sharing options...
sikend667 Posted April 2, 2013 Share Posted April 2, 2013 both recive the same signal displacement doesnt change that. the only time you run into trouble is when you try to run 6 cyl to 4 cyl conversions then you have to change the tach signal Link to comment Share on other sites More sharing options...
stevenva Posted April 3, 2013 Share Posted April 3, 2013 You could swap the whole cluster or just the tach. I'd just swap the tach if it was mine. The cluster is easy to work on. You could replace/upgrade the bulbs at the same time. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
