FocuS Posted December 1, 2012 Share Posted December 1, 2012 Hey Everybody Been a while since I posted but I've been crazy busy at work and the Subie has been running fine...and you know what they say about if it ain't broke! Well, the running fine has ended and I figured it can't hurt to ask some questions to the gurus who troll these interwebz. Here is the story: Very dead battery over the thanksgiving holiday at the hands of the wife. Tried to jump but no go. Pulled the battery and charged it overnight inside. Installed the next AM with no issues, starts fine but throws a code (p0031 - front O2 sensor heater low amperage read). Drive it home with no real difference in drivability or power. I'm still running on Custom flash from TDC on my V1 AP, Cobb catless UP/DP, filter, prodrive ends, and mufflers. my question is this, I replaced the sensor almost 12 months to the day for the same code. it ran fine after... Should I replace it with the more expensive Bosch sensor or the Denso? is the seneor even needed ona a custom mapped ECU? Can I fake the ECU out with a resistor if thats the case? My thought is to get an Infamous tune since I think it could help power/economy...should I do the new tune as well as a sensor? DISCUSS.... Thanks in advance Link to comment Share on other sites More sharing options...
mwiener2 Posted December 1, 2012 Share Posted December 1, 2012 You're gonna need a new AP My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
FocuS Posted December 1, 2012 Author Share Posted December 1, 2012 I was going to go open source instead... Link to comment Share on other sites More sharing options...
mwiener2 Posted December 1, 2012 Share Posted December 1, 2012 AP is better My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
FocuS Posted December 1, 2012 Author Share Posted December 1, 2012 ....and close to $600+ more Link to comment Share on other sites More sharing options...
mwiener2 Posted December 1, 2012 Share Posted December 1, 2012 Yeah, and? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
FocuS Posted December 1, 2012 Author Share Posted December 1, 2012 my car, which I do enjoy, is not what I choose to spend $ on indiscriminately.... Link to comment Share on other sites More sharing options...
joeleodee Posted December 1, 2012 Share Posted December 1, 2012 Why does he need a new AP? Is it because Infamous doesn't offer tuning maps for the v1? Link to comment Share on other sites More sharing options...
joeleodee Posted December 1, 2012 Share Posted December 1, 2012 By the way, get a sensor free if you can. If it's within a year, you should be able to take it where you got it for a replacement. Link to comment Share on other sites More sharing options...
FocuS Posted December 1, 2012 Author Share Posted December 1, 2012 I do all my own work...so it would asking Denso for a replacement... also, Infamous is sans AP...Thus open source Link to comment Share on other sites More sharing options...
joeleodee Posted December 1, 2012 Share Posted December 1, 2012 It has been a while since you've been on. Welcome back. http://legacygt.com/forums/showthread.php/remotely-tune-accessports-too-146762.html Link to comment Share on other sites More sharing options...
FocuS Posted December 1, 2012 Author Share Posted December 1, 2012 yeah...a 3 year old will do that... plus, 60+ hr weeks! Link to comment Share on other sites More sharing options...
joeleodee Posted December 1, 2012 Share Posted December 1, 2012 Been there, brother. I understand. Denso should replace that sensor for you at no cost. I've burned through a sensor in under a year and it was replaced. Link to comment Share on other sites More sharing options...
FocuS Posted December 1, 2012 Author Share Posted December 1, 2012 ill Gove it a try before dropping the coin on it... I thought that once you had a fixed fuelling map via Custom tune the sensor was not needed? Link to comment Share on other sites More sharing options...
mwiener2 Posted December 1, 2012 Share Posted December 1, 2012 Your custom tune is really only tweaked in the high load areas of the map. The low load areas are controlled by the ECU which needs the front O2 sensor. E-tunes are nowhere near a perfect tune and I bet yours runs a bit hot and is cooking your sensors. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
FocuS Posted December 1, 2012 Author Share Posted December 1, 2012 my current tune is not an etune but rather a custom dyno tune. It looks like Denso is going to replace the sensor under warranty so that's good... Now, the decision as to get a new dyno tune from a trusted local tuner or trust that Shamar at Infamous knows his 'ish...? The dyno time will likely run 2x that of the etune.... thoughts? Link to comment Share on other sites More sharing options...
FocuS Posted December 1, 2012 Author Share Posted December 1, 2012 it had been my thought as well that my current tune burned up the sensor but the previous one lasted 5+ years at Stage 2 levels.... idk... Link to comment Share on other sites More sharing options...
mwiener2 Posted December 1, 2012 Share Posted December 1, 2012 go with dyno tune if it's a good tuner My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Shello007 Posted December 4, 2012 Share Posted December 4, 2012 What's the normal voltage reading on that sensor? Anyone knows? Link to comment Share on other sites More sharing options...
FocuS Posted December 5, 2012 Author Share Posted December 5, 2012 can't find it... but it is reading low on amps..-.8... think replacing with Bosch is worth the extra $? Denso denied my warranty claim... Link to comment Share on other sites More sharing options...
FocuS Posted December 24, 2012 Author Share Posted December 24, 2012 Good News! Called up Amazon about their product being a knockoff sensor being sold under the Denso name. They refunded ALL my $ for both sensors and let me keep the new sensor. I'll just see how long this one lasts and then use the returned $ for an actual Bosch sensor when it fails again... Link to comment Share on other sites More sharing options...
Yayo Posted March 8, 2013 Share Posted March 8, 2013 Hopefully someone can steer me in the right direction: EFI Tuned in December 12'. P0031 code a few weeks ago, car was jerking during acceleration at all speeds. Had front 02 sensor replaced, solved problem for a week and now error code is back. Car isn't jerking around during low RPMs anymore, but it still is during a harder acceleration, it has a pulsing/jerky feel. All I did was clean MAF and Throttle body and I also checked intercooler hoses. What should be my next step? Link to comment Share on other sites More sharing options...
FocuS Posted March 12, 2013 Author Share Posted March 12, 2013 I would check for leaks and any damage to the MAF... You might have EFI take a look at the tune again...perhaps send them a log...? IDK, my problems never effected drivability like that other then not allowing the cruise to work. The '05 versus '08 are pretty different since the '08 is CANBUS... GL Link to comment Share on other sites More sharing options...
mwiener2 Posted March 13, 2013 Share Posted March 13, 2013 How did you clean the MAf and did you clean the black ring around the inside of the throttle body off? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
