croll326 Posted April 6, 2010 Share Posted April 6, 2010 Any suggestions? Must do's and don'ts? I just want to be safe and keep everything reliable for my daily driver. Thanks. Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 6, 2010 Share Posted April 6, 2010 there's going to be opinions about flex pipe version non flex pipe in the up pipe. new gaskets would be a good idea. Link to comment Share on other sites More sharing options...
croll326 Posted April 6, 2010 Author Share Posted April 6, 2010 I know. I am more worried about the stage 1 tune and if I have to change anything. I dont want CEL's coming on. I also have a panel filter I want to install. Link to comment Share on other sites More sharing options...
croll326 Posted April 6, 2010 Author Share Posted April 6, 2010 And will it cause a failed PA inspection/emissions? Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 6, 2010 Share Posted April 6, 2010 i'm not sure how tight your emissions laws are.. i think the stage 2 map might have the CEL removed. but you'd need a catback to go with the uppipe install. and according to the cobb notes - it doesn't recommend anything but the stock ail filter. not sure how much the panel filter is going to do to the tuning. i had a panel filter in the car before and the dealership thought it might have been a good idea that i changed it out Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 6, 2010 Share Posted April 6, 2010 i'm not sure how tight your emissions laws are.. i think the stage 2 map might have the CEL removed. but you'd need a catback to go with the uppipe install. and according to the cobb notes - it doesn't recommend anything but the stock ail filter. not sure how much the panel filter is going to do to the tuning. i had a panel filter in the car before and the dealership thought it might have been a good idea that i changed it out . Need a downpipe for stage 2. CBE is optional Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 6, 2010 Share Posted April 6, 2010 Description: Stage2 91 ATv118 – Intended for an otherwise stock 2005 Subaru Legacy GT AT vehicle with a STOCK INTAKE SYSTEM, STOCK INTAKE FILTER, and a turbo-back exhaust system with a high-flow catalytic converter running 91 or 92 octane petrol. Boost Targets: ~16.5psi peak boost pressure tapering down to ~13psi by the 6700 RPM redline, +/ 0.8psi. i should have wrote turboback. Link to comment Share on other sites More sharing options...
croll326 Posted April 7, 2010 Author Share Posted April 7, 2010 I talked to a rep from Fred Beans Subaru and was told that I dont need a tune for the new up pipe and AVO flat panel filter.....what are the chances that person didnt know what they were talking about? Link to comment Share on other sites More sharing options...
goneskiian Posted April 7, 2010 Share Posted April 7, 2010 You don't NEED a tune but to really experience any gains a tune is definitely recommended. As for the CEL's if you don't run the stage 2 map you'll need to do the resistor mod on the UP's EGT sensor. Unless the UP you are installing has a bung and you can continue to use it. The resistor fix is super easy and inexpensive though. I don't recall the exact specs on the resistor you need but you can get them at Radioshack. Edit: Just did a quick search, it's a 2.2 Kohm .5 watt resistor that you need. You simply unplug the EGT probe (somewhere along the wire there's a plug), bend the resistor into a "U" shape and stick it into the car side of the plug, wrap it with electrical tape and zip tie it somewhere so it's not dangling loose. Cheers! Link to comment Share on other sites More sharing options...
croll326 Posted April 10, 2010 Author Share Posted April 10, 2010 I talked to a COBB rep yesterday and he said I didn't need a tune either. I will not have a DP so I cant run a stage 2 map right? The rep from COBB said I wont have any trouble with an UP and a panel filter because they don't change the air flow characteristics enough. Link to comment Share on other sites More sharing options...
LIZARD Posted April 10, 2010 Share Posted April 10, 2010 You'll be fine. The AP takes care of the CELs. You can GUT the stock DP and remove the cat-guts(ceramic I believe) if you want to go the cheap route of stage II. It's easier to do this at the same time IMO b/c you'll be taking everything apart in that area to do the UP install. As far as a pro-tune, you DON'T need one, PERIOD. The AVO panel filter won't cause any problems with the AP stage I/II maps. They're fairly "tame" off the shelf type maps anyway. Iv'e done all of this as have many others on this forum. Read up on the "Performance Mods-Walk Throughs" sections and get a friend to help and maybe a 12 pack of brewskis(for after of course). Turbo-back or catback exhaust is nice, but by no means is it necessary AT ALL. Hope that helps, good luck. lizard. Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
croll326 Posted April 12, 2010 Author Share Posted April 12, 2010 I am thinking a PDX tune might be in my future......apparently they will make a tune for the AVO flat panel and the specific up pipe? Has anyone used them before? I cant send my ECU anywhere as my car is my DD. Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 13, 2010 Share Posted April 13, 2010 I am thinking a PDX tune might be in my future......apparently they will make a tune for the AVO flat panel and the specific up pipe? Has anyone used them before? I cant send my ECU anywhere as my car is my DD. IMO, send a PM to Infamous1. He can tune AP v.2 or Opensource, lots of people on here have been tuned by him with great results. Link to comment Share on other sites More sharing options...
croll326 Posted April 13, 2010 Author Share Posted April 13, 2010 I have an AP v.1. Do you think there is any concern about installing an up pipe at 90k? Should I be worried that the increased flow to the turbo will damage it? Link to comment Share on other sites More sharing options...
integroid Posted April 13, 2010 Share Posted April 13, 2010 At your mileage, I would be more concerned about the cat in the stock up breaking up and destroying your turbo. Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 13, 2010 Share Posted April 13, 2010 At your mileage, I would be more concerned about the cat in the stock up breaking up and destroying your turbo. +1, your turbo can handle the increased flow no problem. Hell, 07+ LGTs came with a catless UP from the factory anyway Link to comment Share on other sites More sharing options...
Max Capacity Posted April 13, 2010 Share Posted April 13, 2010 I have been at stage 1 with a Parrin Panel filter since Dec 04, no issuses. I use Mike at TuningAlliance for my tune's TuningAlliance@gmail.com he's in W. Springfield MA 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
