volodyalysak Posted May 31, 2013 Share Posted May 31, 2013 Hi everybody, 05 LGT, my PS Pump going bad, was trying to find reseal kit, but there is nothing for 05 Turbo, also i found couple PS pumps from 05 Legacy non turbo, will that work ?? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted June 1, 2013 Share Posted June 1, 2013 I believe people have used the OEM o-ring to fix the leaking pumps. Is that your problem or is the pump as you say going bad? I would think any auto parts store can find you a rebuilt one. Call them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
