MJ in PA Posted January 9, 2011 Share Posted January 9, 2011 I just noticed that one of the two license plate lights is out. The manual doesn't even give instructions on how to replace it - it just says replacement may be difficult, take it to the dealer. That's insane! There's no reason to (a) make it difficult to replace a bulb or (b) not even provide instructions on how to do it. I guess you have to remove the inside trunk lid lining? Link to comment Share on other sites More sharing options...
frank_ster Posted January 9, 2011 Share Posted January 9, 2011 maybe change the entire trunk ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted January 9, 2011 Share Posted January 9, 2011 25.License Plate Light A: REMOVAL 1. SEDAN MODEL 1) Remove the trunk lid trim. <Ref. to EI-70, TRUNK LID TRIM, REMOVAL, Trunk Room Trim.> 2) Turn and remove the bulb socket (A). 3) Remove the bulb. so looks like you need to remove the licence plate and work your way from the out side in. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
boymk123 Posted January 9, 2011 Share Posted January 9, 2011 I just noticed that one of the two license plate lights is out. The manual doesn't even give instructions on how to replace it - it just says replacement may be difficult, take it to the dealer. That's insane! There's no reason to (a) make it difficult to replace a bulb or (b) not even provide instructions on how to do it. I guess you have to remove the inside trunk lid lining? yea u do, buy the right tool and it'll take u 10 mins http://www.beisansystems.com/procedures/rear_shocks_procedure_files/image015.jpg Link to comment Share on other sites More sharing options...
MJ in PA Posted January 9, 2011 Author Share Posted January 9, 2011 Thanks, looks like a pain in the ass. Maybe I'll wait and have the dealer do it. Link to comment Share on other sites More sharing options...
Molal24 Posted January 9, 2011 Share Posted January 9, 2011 It's really easy. Sounds much harder than what it actually is. When I had my LGT I swapped mine for LEDs in less than 5 minutes. Link to comment Share on other sites More sharing options...
XXB4XX Posted January 10, 2011 Share Posted January 10, 2011 Just to clarify here, you need to work from the inside of the boot-lid? as in remove all the carpet trim to get to the globes??.. Link to comment Share on other sites More sharing options...
boymk123 Posted January 10, 2011 Share Posted January 10, 2011 Just to clarify here, you need to work from the inside of the boot-lid? as in remove all the carpet trim to get to the globes??.. that's how I do mine, it's really easy, all u need is a tool (pic above) Link to comment Share on other sites More sharing options...
mr.hicksta Posted January 10, 2011 Share Posted January 10, 2011 There are a few popits you have to remove then you can reach under the carpet/cover to reach the light bulbs. Once you pull the cover up it's relatively easy to reach the bulbs. Link to comment Share on other sites More sharing options...
pillboy Posted January 10, 2011 Share Posted January 10, 2011 Just be forewarned that when going in through the inside, if you are changing to LED bulbs, some of them suck a$$ and don't stay seated in the socket well. When they fall out of the socket it can be a real biotch to get them out of the light housing. It is still ugly. Link to comment Share on other sites More sharing options...
2005legacy2.5i Posted January 10, 2011 Share Posted January 10, 2011 it sucks, but with enough time you can get it Link to comment Share on other sites More sharing options...
aziankingz Posted January 10, 2011 Share Posted January 10, 2011 why would anyone want to make their license plates visible lol Link to comment Share on other sites More sharing options...
XXB4XX Posted January 10, 2011 Share Posted January 10, 2011 I usually just use a flat head screwdriver and pry each clip side by side.. When I owned my b4 I had almost every light converted to LED including reverse lights/brakes/doors/license plate/fog lights etc.. On the GT I've already done the interior, now moving onto the license plate and then the Parkers in the headlights (not sure what you call them in the states).. Link to comment Share on other sites More sharing options...
ehsnils Posted January 10, 2011 Share Posted January 10, 2011 When I replaced the license plate lights last time I went for LED lights. On the wagon there are two phillips screws from the outside for each light. A little fiddling and they were replaced - hopefully I don't need to go at them again. Link to comment Share on other sites More sharing options...
MJ in PA Posted January 10, 2011 Author Share Posted January 10, 2011 On the wagon there are two phillips screws from the outside for each light. A little fiddling and they were replaced - hopefully I don't need to go at them again. Why on Earth didn't they make it that easy for the sedan?! Link to comment Share on other sites More sharing options...
jxjjang Posted January 10, 2011 Share Posted January 10, 2011 if you go from the outside, it's much easier. its just a matter of removing the trunk panel (the ones where the emblems are attached) and a few 10mm bolts. search and you'll find the walkthrough posted somewhere. Link to comment Share on other sites More sharing options...
ehsnils Posted January 10, 2011 Share Posted January 10, 2011 Why on Earth didn't they make it that easy for the sedan?! The catch on the wagon is that you want an extremely long blade on the screwdriver or you won't approach the screws straight and the screwdriver jumps. And keep the knuckles close to the trunk lid. So even the wagon has it's problems. Link to comment Share on other sites More sharing options...
SCSpecB Posted January 10, 2011 Share Posted January 10, 2011 if you go from the outside, it's much easier. its just a matter of removing the trunk panel (the ones where the emblems are attached) and a few 10mm bolts. search and you'll find the walkthrough posted somewhere. +1 Makes some scary noises when you're removing it, but its pretty easy overall. Link to comment Share on other sites More sharing options...
gnod85 Posted January 10, 2011 Share Posted January 10, 2011 quick question but, what's the bulb type on them? 168? i need to replace mine too this weekend. Link to comment Share on other sites More sharing options...
slowGT Posted January 11, 2011 Share Posted January 11, 2011 Yes it is a 168. I'm guessing the rubber stops just pop out like the other carpeting clips as well? They just spin and spin so i'm guessing they are a clip.... Link to comment Share on other sites More sharing options...
