Al Thomson Posted March 8, 2014 Share Posted March 8, 2014 What's the good bad and ugly on after market wheel bearings? Should one stick with OEM or go aftermarket? Thanks for any real life experience Link to comment Share on other sites More sharing options...
mwiener2 Posted March 8, 2014 Share Posted March 8, 2014 They both probably have the same actual Chinese made bearing assembly in them. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
covertrussian Posted March 9, 2014 Share Posted March 9, 2014 I personally think Subaru OEM bearings suck, if they were built decently we wouldn't have this many issues... I personally use Timken bearings on all of my cars, Subaru or not. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
bjrongo Posted March 9, 2014 Share Posted March 9, 2014 I personally use the Moog Premium Hub bearing assembly as they have a nipple on them that you can use to re grease the bearings without taking the whole assembly apart. In my opinion best bang for buck they run ~$95 each. Link to comment Share on other sites More sharing options...
Brian3676 Posted March 9, 2014 Share Posted March 9, 2014 I have run the napa hubs for years on many cars. Most of them are skf bearings, which are good quality. They work well with no issues. If they do fail, the warrenty is much easier to deal with than Subaru, which must have the failure "validated" by a Subaru tech at a dealer, which you must pay for. Kinda silly they do that. Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 9, 2014 Share Posted March 9, 2014 Post #66 http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238p5.html Link to comment Share on other sites More sharing options...
lovedr79 Posted March 10, 2014 Share Posted March 10, 2014 how much of a pain is changing the rear bearings on these? I know the older forester is a pain....... Link to comment Share on other sites More sharing options...
Holla Posted March 10, 2014 Share Posted March 10, 2014 They're really not that bad to change. They are 4 bolt flange bearings. Remove tire, remove caliper from bracket, remove bracket, remove rotor, remove abs sensor, remove axle nut, remove 4 bolts from bearing flange, remove hub assembly and install in reverse. I did both rears in about 4 hours never having done it before. I went with oem bearings. Only swapped them out 10k ago but no issues so far. Link to comment Share on other sites More sharing options...
007Legacy Posted March 10, 2014 Share Posted March 10, 2014 I have just ordered a bearing from http://www.am-autoparts.com/Subaru/Legacy/wheel-bearing-hub-rear/AM-26980221/480448-2007.html?utm_campaign=gb_csv_br&utm_content=SHR&gclid=CMjSvumhiL0CFZLm7AodSU0A9w I will report back on quality and fitment or any issues that I find. Link to comment Share on other sites More sharing options...
theflystyle Posted March 11, 2014 Share Posted March 11, 2014 I have just ordered a bearing from http://www.am-autoparts.com/Subaru/Legacy/wheel-bearing-hub-rear/AM-26980221/480448-2007.html?utm_campaign=gb_csv_br&utm_content=SHR&gclid=CMjSvumhiL0CFZLm7AodSU0A9w I will report back on quality and fitment or any issues that I find. Damn thats cheap Link to comment Share on other sites More sharing options...
007Legacy Posted March 13, 2014 Share Posted March 13, 2014 So, I got the wheel bearing. Seems decent. Spins easy by hand. It's to cold and snowy to put it on tonight. Plus my boys Honda is in the garage at the moment. Link to comment Share on other sites More sharing options...
lovedr79 Posted March 13, 2014 Share Posted March 13, 2014 what brand did you get? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2014 Share Posted March 13, 2014 what brand did you get? see link in post 9 $40.00 that is cheap. Wonder how long it will last. Keep us updated. Remember let the PB Blaster do it work. Use anti-sieze pn the bolts when going back together. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 13, 2014 Share Posted March 13, 2014 So, I got the wheel bearing. Seems decent. Spins easy by hand. It's to cold and snowy to put it on tonight. Plus my boys Honda is in the garage at the moment. Kick Honda out of garage Link to comment Share on other sites More sharing options...
007Legacy Posted March 13, 2014 Share Posted March 13, 2014 It does say "Made in China" on the box. So we shall see. Yes, GEE-OTTO...it needs to go. He wants to do a motor swap. I'm not doing it, the civic has 140,000 miles on it and puffs a little oil. I'm just not all that excited about rebuilding it. However, once we get past this snow storm that dropped 18+ inches of snow. I'll put the wheel bearing in. It's a daily driver so as long as I get a year or two out of it, I'll be happy. Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 13, 2014 Share Posted March 13, 2014 Don't be surprised if you have an ABS light on. I hope you don't but it's pretty proven that the cheap Chinese bearings have had a lot of issues with ABS sensors not being up to par. Link to comment Share on other sites More sharing options...
lingling1337 Posted March 14, 2014 Share Posted March 14, 2014 (edited) Thanks for the link on the hubs Jmp, I think I will go with [ame=http://www.amazon.com/gp/product/B004QHNBH2/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER]this GMB hub[/ame] from amazon. With Amazon's return policy I'm not too worried about it- I would rather re-do the job until I get a good bearing than pay $120+ for a "genuine" one... Edited March 14, 2014 by lingling1337 Link to comment Share on other sites More sharing options...
007Legacy Posted March 14, 2014 Share Posted March 14, 2014 Yes. I'll be sure to let you know if I have ABS issues. Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 14, 2014 Share Posted March 14, 2014 Thanks for the link on the hubs Jmp, I think I will go with this GMB hub from amazon. With Amazon's return policy I'm not too worried about it- I would rather re-do the job until I get a good bearing than pay $120+ for a "genuine" one... If you buy that hub and it works and works well, then it's a great source for everyone as it's really inexpensive. I do have experience with GMB as they are an OE supplier of some throwout bearings and when I used to rep a clutch line (I won't give the name, but you would recognize it) they had them in their kits and rarely, if ever had an issue. Please keep us up to date, both of you as if they really do work, then everyone can benefit and I'll put the links on the sticky post as alternatives. Thanks. Link to comment Share on other sites More sharing options...
discojon Posted March 14, 2014 Share Posted March 14, 2014 I just installed Moog front hubs today on my 06 gt. Didn't even pull the abs sensor out of the knuckle. Plus advance auto price matches so I got the moogs for $95ish each. About a 15 min install per side from lifting the car to bolting wheel back on. I'd suggest getting rotors at the same time. Link to comment Share on other sites More sharing options...
lingling1337 Posted March 14, 2014 Share Posted March 14, 2014 If you buy that hub and it works and works well, then it's a great source for everyone as it's really inexpensive. I do have experience with GMB as they are an OE supplier of some throwout bearings and when I used to rep a clutch line (I won't give the name, but you would recognize it) they had them in their kits and rarely, if ever had an issue. Please keep us up to date, both of you as if they really do work, then everyone can benefit and I'll put the links on the sticky post as alternatives. Thanks. I actually needed a rear wheel bearing so I got [ame=http://www.amazon.com/gp/product/B004QHJIBU/ref=oh_details_o00_s00_i02?ie=UTF8&psc=1]this part[/ame]. Should be here on Saturday. I'll post back with impressions. Link to comment Share on other sites More sharing options...
discojon Posted March 14, 2014 Share Posted March 14, 2014 I just installed Moog front hubs today on my 06 gt. Didn't even pull the abs sensor out of the knuckle. Plus advance auto price matches so I got the moogs for $95ish each. About a 15 min install per side from lifting the car to bolting wheel back on. I'd suggest getting rotors at the same time. Update. Got the surgeing then cruise dropped out and light started flashing with the Moogs. I'll pull abs sensors and clean and retest and report back. Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
covertrussian Posted March 14, 2014 Share Posted March 14, 2014 From what I remember seeing, moog's have the magnet a little too low thus the ABS sensor doesn't pick it up as well. Let us know if the cleaning helps (there will be plenty of metal shavings stuck to the ABS sensor). 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
lovedr79 Posted March 14, 2014 Share Posted March 14, 2014 I got mine in the mail yesterday, I paid $68 for both rears! and yes the box said chiner. I plan on doing them tonight. and next week I have to do head gaskets on my forester. ugh. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2014 Share Posted March 14, 2014 Update. Got the surgeing then cruise dropped out and light started flashing with the Moogs. I'll pull abs sensors and clean and retest and report back. Sent from my SAMSUNG-SGH-I747 using Tapatalk Yep, that's why its common knowledge not to use Moog on the fronts. On the rears its fine. Been there done that. Posted here about it. Remove them, return them and get OEM or timkin, or skf from NAPA. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
