Wicat3 Posted June 14, 2017 Share Posted June 14, 2017 Hey everyone. I was wondering if everyone follows the manufacturer oil recommendations in their cars? I need an oil change and the dealer is one of the cheapest I have seen but it also seems every time im in there is something else they want to replace. To buy the oil recommended for my car is expensive verse a normal standard oil like 5w-20 or 5w-30. Link to comment Share on other sites More sharing options...
s2baru Posted June 14, 2017 Share Posted June 14, 2017 Keep in mind the most important pieces of your vehicle reside inside the the engine. Go with what's recommended. Spending an extra 10-25$ for proper care shouldn't break the bank for you I'd hope Link to comment Share on other sites More sharing options...
capttris Posted June 14, 2017 Share Posted June 14, 2017 Wicat3, Do you have the 2.5 or the 3.6? I'm thinking you have the 2.5 0W20 Full synthetic is only a few dollars more. Most of the time, you can find it on sale at Walmart for $22-25 a gallon, with 1 of the top 3 brands. For example: Mobil 1 0W20 is now on sale for $22.88 https://www.walmart.com/ip/Mobil-1-0W-20-Advanced-Fuel-Economy-Full-Synthetic-Motor-Oil-5-qt./17034374?athznid=ItemCarouselType_WPA&athena=true&athcpid=17034374&athpgid=WPADesktopHP&isAthAd=true&findingMethod=wpa&tgtp=2&cmp=11280&relRank=308&pt=hp&adgrp=11686&bt=1&plmt=1145x345_B-C-OG_TI_1-20_HL-MID-HP-ERO-BACKFILL&wpa_qs=HJ8vE8n7alJgkrWBAA6Y7MNcGK3P4NnbbhTvL6PD52EA3jec7-VXbm9GgoZ7rwbv&bkt=__bkt__&pgid=hp-3&itemId=17034374&relUUID=c3c47879-b599-4252-9aa8-52ea4cad1861&adUid=74c26703-8d39-48e8-ad08-4894a9404187&adiuuid=12d5d0c7-e45c-4eb7-b3c6-15d6b0888080&adpgm=wpa&pltfm=desktop Versus Conventional Motor Oil Castrol GTX (which is great oil) 5W30 $15.97 https://www.walmart.com/ip/Castrol-GTX-5W-30-Motor-Oil-5qt/17200822 So 0W20 Full Synthetic is about $6.91 MORE per gallon than 5W30 conventional oil That comes out to about 1.3 cents more per 10 miles driven, assuming an oil change every 5000 miles. And THAT seems expensive?? Link to comment Share on other sites More sharing options...
acumenhokie Posted June 14, 2017 Share Posted June 14, 2017 If you're getting your oil changed at the dealer you'd save more than the cost of the higher quality oil just by going to a regular shop. I provide the oil and filter and the shop I go to charges me $15 for the labor. Link to comment Share on other sites More sharing options...
DugsSin Posted June 14, 2017 Share Posted June 14, 2017 Difference between a 5 qt jug of Castrol 5w-30 conventional and synthetic blend is $1.91 and to full synthetic is 7 bucks at Walmart. If you can change it yourself you can run the best oil & filter and still save $$$. Don't get me started on running (supposed) money saving fluids in a car Link to comment Share on other sites More sharing options...
Wicat3 Posted June 14, 2017 Author Share Posted June 14, 2017 Trust me Im not trying to be cheap by any means. I am in desperate need of an oil change and trying to weigh my options. Last time I went to the parts store I found the oil to be pretty pricey, Conventional oil was about 20 dollars while the 0w-20 synthetic was about 30 dollars. I also found out that normal oil filters leak so I would have to get a subaru filter as well. Link to comment Share on other sites More sharing options...
MilesA Posted June 14, 2017 Share Posted June 14, 2017 Subaru OEM blue oil filters are not too expensive if you buy a small quantity online, like three or six at a time. I see good quality synthetic oil quite often for under $25 for a 5-quart container. It makes sense to follow the recommendations, consider it cheap insurance. Link to comment Share on other sites More sharing options...
cww516 Posted June 14, 2017 Share Posted June 14, 2017 Auto parts store prices on oil are usually going to be higher than Walmart, that way their sale prices or rebates or whatever end up in line with Walmart's normal prices. Link to comment Share on other sites More sharing options...
GTEASER Posted June 14, 2017 Share Posted June 14, 2017 Castrol Edge 0W-20 (synthetic) is about $26 at Walmart, sometimes $23 when on sale, and an OEM or Wix filter should be less than $8. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
cww516 Posted June 14, 2017 Share Posted June 14, 2017 Or, for the truly committed (or indoctrinated, whatever): http://www.discountfleetsupply.com/wix57712.html Link to comment Share on other sites More sharing options...
GTEASER Posted June 14, 2017 Share Posted June 14, 2017 Or, for the truly committed (or indoctrinated, whatever): http://www.discountfleetsupply.com/wix57712.html 57712 is not correct, it is for the EJ motors in the 10-12 Legacy 2.5i 57055 is for the FB in the 13-14 Legacy 2.5i And who knows, he may have a 3.6R, he hasn't been specific as to which model he drives. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
cww516 Posted June 14, 2017 Share Posted June 14, 2017 Good call, my mistake there. For some reason, I thought it was the same filter for the EJ and FB motors. Link to comment Share on other sites More sharing options...
Wicat3 Posted June 15, 2017 Author Share Posted June 15, 2017 Sorry I have a 13 2.5 legacy Link to comment Share on other sites More sharing options...
Legacy199 Posted June 15, 2017 Share Posted June 15, 2017 You need a crush ring for the oil plug correct? I had an 07 Legacy prior to my recent purchase of a 2014 2.5i so I'm working on understanding the vehicle better. Thanks Link to comment Share on other sites More sharing options...
amusa Posted June 15, 2017 Share Posted June 15, 2017 For my 2013 2.5i Prem Legacy. I only use Ardeca SYNTH-SX Ow20 for my other vehicles I only stick with Ardeca brand. As for oil filters I just get some aftermarket ones. For the oil drain washer. I only replaced it one time since owning my 2013. Link to comment Share on other sites More sharing options...
MilesA Posted June 15, 2017 Share Posted June 15, 2017 ...As for oil filters I just get some aftermarket ones...The oil filter needs to have the correct bypass pressure, it's important. The Subaru OEM filters and a few aftermarket ones do, but some don't. It's supposed to be 23 psi, IIRC. You can find a list via search. Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted June 15, 2017 Share Posted June 15, 2017 How come everyone is using 0w-20 synth? Is that what the dealer uses? Last oil change I was in a hurry and brought it to subie for a synthetic change. First time. And that caused some leaking issues I believe, in my front seals. Currently replacing them. I assumed the dealer used 5w-30 synthetic? Sent from my SM-N920P using Tapatalk Link to comment Share on other sites More sharing options...
cww516 Posted June 15, 2017 Share Posted June 15, 2017 5W-30 is what's recommended for the EJ253, but the FB25 in the '13+ is supposed to get 0W-20. Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted June 15, 2017 Share Posted June 15, 2017 Oohh. Didn't know the engines differed for those years. Sent from my SM-N920P using Tapatalk Link to comment Share on other sites More sharing options...
RWebb Posted June 15, 2017 Share Posted June 15, 2017 Where is RAO? Link to comment Share on other sites More sharing options...
GTEASER Posted June 15, 2017 Share Posted June 15, 2017 GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Wicat3 Posted June 15, 2017 Author Share Posted June 15, 2017 Ive changed my oil before and had an issue with the filter leaking. I used a purluator filter so maybe the psi rating was off and I was unaware of that even being an issue. This is part of the reason why I hesitate to working on the Subaru. Any other car I worked on is fairly straight forward. I am thinking if I can get the right info I will change the oil myself and takle my cabin air filter since that needs to be changed Link to comment Share on other sites More sharing options...
MilesA Posted June 15, 2017 Share Posted June 15, 2017 Filter bypass shouldn't cause leaks. What the bypass valve does is sense the pressure difference between inlet and outlet on the filter. When the difference is large enough, it allows oil to bypass the filter so the engine is not starved for lubrication. Bypass can happen when the oil is cold on initial start-up or if the filter becomes blocked with contaminants. Of course, you don't want the oil to bypass the filter unless it's really necessary. Link to comment Share on other sites More sharing options...
GTEASER Posted June 15, 2017 Share Posted June 15, 2017 Of course, you don't want the oil to bypass the filter unless it's really necessary. Exactly! With filters that have a 8 or 15 psi bypass, its likely that oil is bypassing the filter all the time, even when at idle as most cars idle between 10 and 20 psi. With the OEM Subaru and Wix, set at 23, all the oil is getting filtered at warm idle. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
cww516 Posted June 15, 2017 Share Posted June 15, 2017 The bypass pressure setting on an oil filter refers to the pressure drop across the filter, not the actual oil pressure at the filter inlet or pump outlet. There's a bypass valve in the oil pump that serves that purpose, but the one in the filter only lets oil by when the filter is too plugged (or the oil is too cold) to flow enough oil. Link to comment Share on other sites More sharing options...
