phildog33 Posted August 22, 2011 Share Posted August 22, 2011 I put in a VF52 in my 2005 Legacy and went stage 3 with all the other mods: Fuel Pump, TMIC, Injectors, Inlet, etc, etc... In the T hose coming off the Turbo Compressor Housing... were 2 stock restictor pills and my tuner (Shamar) asked me to remove them both and then put one in and then the other.. Just a One Pill set up All 3 pulls that I sent him had either weak boost and a low, midrange boost. Anyways... what size are those 2 pills I was swapping around? One is bigger than the other by about 20% it looks like. He told me to go buy a 1mm pill... but Fred Beans told me that the VF52 i bought came with 1mm and 1.2mm pills What do you guys think? If I go buy a 1mm pill, am I simple replacing it with the exact same one? P Link to comment Share on other sites More sharing options...
subiedad51 Posted August 22, 2011 Share Posted August 22, 2011 You only need to run one pill - a 1mm pill subaru part number 22326AA010 Link to comment Share on other sites More sharing options...
phildog33 Posted August 29, 2011 Author Share Posted August 29, 2011 I just received the 1mm pill and I will try it with this one.. It seems that one side of this pill is longer than the other.. can you tell me which size goes closer to the turbo compressor housing.. or does it not matter http://phillipangert.com/dropbox/pill1mm.JPG Link to comment Share on other sites More sharing options...
