Trailer Wiring 1997 GT Wagon
  • I Donated
probably. I'm not sure how they are wired in. I have an Outback, but mine doesn't have the connector so I cant look to see how its done. I can't imagine it being too hard.
-broknindarkagain
My Current Project - Click Here
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
the connector in the outback is located behind the driver side tail light. open the inside cover, above and to the rear of the jack storage compartment, like you would to replace the bulb and it should be right in there.
the only difference between the GT and the outback MAY be that the outback has a wire with 12v all the time when the car is on which goes to the trailer conector. i'm not sure the same wire is there on the GT or legacy.
  • I Donated
It should be there I would think. Dont they use the same harnesses?
And I had no idea the connector was hidden away. I figured it would be under the car...I didn't remember seeing any wiring down there
-broknindarkagain
COME AND TAKE IT
  • 1 year later...
