stanjk3 Posted November 13, 2007 Share Posted November 13, 2007 Recently my parking brake stopped catching - if I pull it up it just springs back down. Once in a while it does catch. The release button feels like it's sticking. Any ideas what it could be and how hard it is to fix? It just passed inspection last weekend, so it's not due to the brake pads being worn. The parking lots at home and work are mostly level, so I'm not too worried it might pop out of park and roll away. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
Bdubs Posted November 14, 2007 Share Posted November 14, 2007 Mine does this, and I found not pushing the button while pulling the handle up enables the brake to catch the teeth (you know, it so it sounds like a giant zipper?). Pulling back as you lightly push the button to disengage the brake is also a great trick. If it still isn't catching, the spring is probably completely toast. Going to a salvage yard and getting another complete handle would be your best bet. Installation is a breeze. Link to comment Share on other sites More sharing options...
icrackedcorn Posted November 14, 2007 Share Posted November 14, 2007 Mine does this, and I found not pushing the button while pulling the handle up enables the brake to catch the teeth (you know, it so it sounds like a giant zipper?). Pulling back as you lightly push the button to disengage the brake is also a great trick. If it still isn't catching, the spring is probably completely toast. Going to a salvage yard and getting another complete handle would be your best bet. Installation is a breeze. same problem, same solution. after a few months, the brake wasnt "pulling hard" enough for me- the travel was too long. tightening a few nuts, as per the manual not only helped the travel distance to engage with any effectiveness, but also fixed the "sticky button" obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
stanjk3 Posted November 16, 2007 Author Share Posted November 16, 2007 Naturally, after I post this it catches again. Didn't do a thing to it. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
