P-UNIT Posted January 10, 2014 Share Posted January 10, 2014 Apologies if this list exists somewhere, but I was not able to find via search. I am trying to track down my idle issue, but am new to tuning. Does anyone have a comprehensive list of what each parameter's value should be for a stock LGT? (5EAT for those that matter). Seems like this might be a useful list to have. Thanks! Link to comment Share on other sites More sharing options...
ras06LGT Posted January 10, 2014 Share Posted January 10, 2014 You can find stock maps here: http://www.romraider.com/forum/viewtopic.php?f=35&t=7591 Link to comment Share on other sites More sharing options...
P-UNIT Posted January 11, 2014 Author Share Posted January 11, 2014 Appreciate the link, might be helpful in the future. But I'm more curious in the expected values for things like: boost at Idle, max boost, throttle at idle, rpm at idle, etc. Thanks! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 11, 2014 Share Posted January 11, 2014 I can't tell you precisely some of these values right now. But what I can tell you is to monitor the roughness cylinder parameters. Select all four (one per cylinder). If all is well, you should get 0 for all of them at all time. If you see a few counts of misfires reccuring in the same cylinder, then it may be time to troubleshoot and could be related to your rough idle. Also, pull an LV (learning view) and check your fuel trims. There are four of them and should all be +/-5%. If you see the first one (related to idle) really off, you may have a vaccum leak. Link to comment Share on other sites More sharing options...
P-UNIT Posted January 12, 2014 Author Share Posted January 12, 2014 Thanks for the tip on fuel trims! Link to comment Share on other sites More sharing options...
