Nick1657615219 Posted January 9, 2013 Share Posted January 9, 2013 Hi folks. I have done some searches, but unfortunately have not yet decided on a starting point to try to fix this issue. As some of you are probably aware, these codes means that all 4 cylidners are misfiring. I have a 2008 Legacy GT with 60K miles. Plugs, wires, etc have never really been changed. Only maintenance really have been oil and filter (aside from transmission warranty work). I'd hate to just throw parts in the car without having an idea of what could be wrong. Has anybody been through this fix before? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted January 9, 2013 Share Posted January 9, 2013 Plugs are due to be replaced every 60,000 miles. These are coil on plug, so there are no wires. It's not normal to get a CEL for that issue. They need to changed any way's so start there. Only use NGK's that are called for. If your having a shop replace them, tell the guy you have all four miss-fire codes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nick1657615219 Posted January 9, 2013 Author Share Posted January 9, 2013 Plugs are due to be replaced every 60,000 miles. These are coil on plug, so there are no wires. It's not normal to get a CEL for that issue. They need to changed any way's so start there. Only use NGK's that are called for. If your having a shop replace them, tell the guy you have all four miss-fire codes. I guess its a good time as any to replace the plugs. Actually, the CEL light went on and the "cruise" light was blinking when it started. Thanks Link to comment Share on other sites More sharing options...
Nick1657615219 Posted January 9, 2013 Author Share Posted January 9, 2013 your cruise light was flashing too? thats strange, that usually never happens. you should bring your car to a mechanic asap. I had it there the same day it started. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 9, 2013 Share Posted January 9, 2013 We need more info. If it's a rough idle only when it's cold, then it may be the intake manifold gaskets/o-rings: http://legacygt.com/forums/showthread.php/dealer-unable-properly-diagnose-problems-81832.html?t=81832 Solution was to change the intake manifold gaskets as described in post #36 of the same thread: http://legacygt.com/forums/showpost.php?p=2309781&postcount=36 Have them verify the problem using carb cleaner before replacing it though. Link to comment Share on other sites More sharing options...
ehsnils Posted January 9, 2013 Share Posted January 9, 2013 All four means something common for all cylinders, but it can be just about anything if it's only those codes. And common things are O2 sensors, MAF, MAP, PCV valve, evaporation system (in case you always fill up after the pmp has shut off), a loose hose, bad fuel pump... Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 9, 2013 Share Posted January 9, 2013 A bad PCV valve will cause misfires? Link to comment Share on other sites More sharing options...
Nick1657615219 Posted January 9, 2013 Author Share Posted January 9, 2013 We need more info. If it's a rough idle only when it's cold, then it may be the intake manifold gaskets/o-rings: http://legacygt.com/forums/showthread.php/dealer-unable-properly-diagnose-problems-81832.html?t=81832 Solution was to change the intake manifold gaskets as described in post #36 of the same thread: http://legacygt.com/forums/showpost.php?p=2309781&postcount=36 Have them verify the problem using carb cleaner before replacing it though. Awesome, thanks for that. It was in fact a bit shaky after a cold start in the morning a couple of days prior to the CEL going on. Link to comment Share on other sites More sharing options...
ehsnils Posted January 9, 2013 Share Posted January 9, 2013 A bad PCV valve will cause misfires? If it for some reason is stuck open it can pass too much gases from the crankcase into the manifold causing the engine to go lean and get misfires. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 9, 2013 Share Posted January 9, 2013 Thanks. Learned something new today. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 9, 2013 Share Posted January 9, 2013 your cruise light was flashing too? thats strange, that usually never happens. you should bring your car to a mechanic asap. It is normal for the CC light to flash when you get a CEL in these cars. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nick1657615219 Posted January 9, 2013 Author Share Posted January 9, 2013 In regards to the valves, one thought I had is that they needed to be adjusted after 60K miles (if they are in fact adjustable). Link to comment Share on other sites More sharing options...
Max Capacity Posted January 9, 2013 Share Posted January 9, 2013 The valves should not need adjustment. You could have a air leak at the intake o-rings where it mounts to the TGV's. I can't remember what CEL I got when they were leaking. I replaced them with the new orange o-rings which are much bigger then what the 05's came with. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ehsnils Posted January 9, 2013 Share Posted January 9, 2013 At least one member did have strange idle problems due to incorrectly adjusted valves, so if everything else checks out it's worth checking them too. Not sure if it was on a EJ255 or if it was an older engine. Be aware that even if a compression test checks out the valves may still need to be checked. A running engine has hotter valves and they can change enough in length to cause leaks only when the engine runs. But since the problem is on all cylinders I don't think it's the valves. It usually manifests itself on a single cylinder. Link to comment Share on other sites More sharing options...
Nick1657615219 Posted January 9, 2013 Author Share Posted January 9, 2013 Intake gasket are leaking - You heard it here first. My car is out of warrant, but is there a notice out on this issue? Anybody know if I can ask Subaru to fix it? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 9, 2013 Share Posted January 9, 2013 I could be worng, but I'd say No to both questions. Nice try... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 10, 2013 Share Posted January 10, 2013 You could ask them for a goodwill repair since it seems like you're just out of the powertrain warranty. Try calling SOA if the dealer says no. Link to comment Share on other sites More sharing options...
