cybaster Posted March 7, 2012 Share Posted March 7, 2012 Hi everyone, Like most using the vag-com cable, I'm sick of the cable draping over my steering column and always having to take care of my laptop while driving/logging. I recently purchased a OP2.0 cable but now I am having trouble getting the logcfg.txt file done. I was reading up on here and RomRaiders and saw there was a tool to create it, http://www.verticaltier.net/configtool/logger.php but it doesn't seem to show the A2WC510N ECU. Anyone with an 2005 LGT willing to share that file so I can get an idea how it's done? Thanks Jon Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted March 7, 2012 Share Posted March 7, 2012 http://legacygt.com/forums/showthread.php/standalone-logging-microsd-w-opv2-0-134306.html just scroll down the page next time. Link to comment Share on other sites More sharing options...
cybaster Posted March 7, 2012 Author Share Posted March 7, 2012 obviously the OP of that post was running a 2006 LGT and has a different ECUID which was available on the website i listed... If my ECU id showed up in that GUI i probably didn't need to ask did I? Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted March 7, 2012 Share Posted March 7, 2012 A guy in that thread is using that ECU ID. Maybe try his code with the corrections suggested by others. Either way, no reason to start a whole new thread. Just trying to give you an idea of where to start... Link to comment Share on other sites More sharing options...
NSFW Posted March 8, 2012 Share Posted March 8, 2012 Go to the OP20 config web site, and start typing your ID into the box in the top left, where it says "--select--". It should really say "--type--" instead of "--select--" in the first place. Link to comment Share on other sites More sharing options...
cybaster Posted March 9, 2012 Author Share Posted March 9, 2012 Wow, thanks NSFW, I totally wouldn't have seen that... (besides, typing in a drop down.... yeah...) Link to comment Share on other sites More sharing options...
cybaster Posted March 9, 2012 Author Share Posted March 9, 2012 Thanks for the info guys, still can't get any csv files here is my logcfg.txt file: type=ssmk paramname = Engine_Speed(rpm) paramid = 0x00000E databits = 16 scalingrpn = x,4,/ paramname = Ignition_Total_Timing(degrees) paramid = 0x000011 databits = 8 scalingrpn = x,128,-,2,/ paramname = Mass_Airflow(g/s) paramid = 0x000013 databits = 16 scalingrpn = x,100,/ paramname = Throttle_Opening_Angle(%) paramid = 0x000015 databits = 8 scalingrpn = x,100,*,255,/ paramname = Primary_Wastegate_Duty_Cycle(%) paramid = 0x000030 databits = 8 scalingrpn = x,100,*,255,/ paramname = Roughness_Monitor_Cylinder_#1(misfire_count) paramid = 0x0000CE databits = 8 scalingrpn = x paramname = Roughness_Monitor_Cylinder_#2(misfire_count) paramid = 0x0000CF databits = 8 scalingrpn = x paramname = Roughness_Monitor_Cylinder_#3(misfire_count) paramid = 0x0000D8 databits = 8 scalingrpn = x paramname = Roughness_Monitor_Cylinder_#4(misfire_count) paramid = 0x0000D9 databits = 8 scalingrpn = x paramname = Engine_Load_(2-byte)**(g/rev) paramid = 0xFF530C databits = 16 scalingrpn = x,.00006103516,* paramname = IAM_(1-byte)**(multiplier) paramid = 0xFF5339 databits = 8 scalingrpn = x,.0625,* paramname = Manifold_Relative_Pressure_(4-byte)*(psi_relative) paramid = 0xFF4F34 databits = 32 scalingrpn = x,0.01933677,* paramname = Knock_Sum*(count) paramid = 0xFF5CEC databits = 8 scalingrpn = x ;-------------triggers--------------- paramname = defogger_sw paramid = 0x64 databits = 1 offsetbits = 5 isvisible = 0 conditionrpn = defogger_sw,1,== action = start conditionrpn = defogger_sw,0,== action = stop and here is my logcfg.out contents 001: type=ssmk : name[type,0] value[ssmk,0,0.000000] unrecognized option [type] at line 1 Link to comment Share on other sites More sharing options...
joop1987 Posted March 9, 2012 Share Posted March 9, 2012 Try: paramname = defogger_sw paramid = 0x000064 databits = 1 offsetbits = 5 isvisible = 0 Link to comment Share on other sites More sharing options...
cybaster Posted March 9, 2012 Author Share Posted March 9, 2012 thanks, i'll give that a shot and see Link to comment Share on other sites More sharing options...
