PrelateBishop Posted October 12, 2012 Share Posted October 12, 2012 Might be buying an '09 OBXT. Before I do, I would like to know if all 3rd generation Outbacks will accept the same mods? I'd love to lower the stance, change the grill to an earlier OBXT (such as the '07 model), and be able to reflash/upgrade the ECU with a new tune. Is there anything specific about 2009 model that I should know about before I pull the trigger? Thanks in advance. Link to comment Share on other sites More sharing options...
ktmrider Posted November 4, 2012 Share Posted November 4, 2012 The delta list is pretty much exactly the same as the LGT models, lots of threads out there. Grill, headlights, AND bumper cover are different on 05-07 and 08-09. Gotta change it all. 07+ are CANBus for ECU. Needs specific cable that supports it, cannot use the VAGCOM model. Lowering an OB is a contradiction IMO. You want a lowered stance?!? Buy an LGT, Subaru already took care of it! Link to comment Share on other sites More sharing options...
Rickbubello Posted November 30, 2012 Share Posted November 30, 2012 im looking for an exhaust for my outback 2008 xt manual, downpipe and front grill (blank empty black grill) seems impossible to find any of the above Link to comment Share on other sites More sharing options...
oldskoolbiker Posted December 2, 2012 Share Posted December 2, 2012 Here is the OB specific Exhaust I have. It's a little pricy. http://www.avoturboworld.com/avoshop/outback-catback-p-162.html?osCsid=ofekk3o7tnj1h52t8c55ifb7s1 The downpipe is same as LGT. The exhaust is the same as LGT as well, except you would have to have someone modify the mufflers to make the tips point down. Link to comment Share on other sites More sharing options...
Rickbubello Posted December 6, 2012 Share Posted December 6, 2012 can i ask without being flamed... I see you say the 05-07 is different then the 08/09, fine that makes sense. Grills for a 08/09 legacy gt should fit an 08 outback then? im looking for a black mesh empty grill like some members have on their 05-07. just trying to figure out if i find one for the 08/009 lgt, it will fit my outback xt. thanks Link to comment Share on other sites More sharing options...
Lucid Posted December 6, 2012 Share Posted December 6, 2012 No, a Legacy grille will not fit your Outback XT. The Outback grilles are considerably bigger, and the hood and bumper designs are different. The Legacy hood curves around the top of the grille, your Outback hood is nearly straight, with chrome trim attached to your hood and not the top of the grille. Link to comment Share on other sites More sharing options...
PrelateBishop Posted December 6, 2012 Author Share Posted December 6, 2012 Grills for a 08/09 legacy gt should fit an 08 outback then? im looking for a black mesh empty grill like some members have on their 05-07. just trying to figure out if i find one for the 08/009 lgt, it will fit my outback xt. thanks The answer is a resounding, "No!" The Legacy grill and the Outback grill are not even close with regards to shape. Study the perimeter lines and you'll see it right away. I too would like a mesh grill, but as far as I can tell, it is going to have to be a custom job. I'm seriously considering doing just that and would likely document the process to share with others. Finally, some OEM grill pics for reference: Legacy: http://images01.olx.com/ui/2/24/28/36731628_1.jpg Outback: http://i99.photobucket.com/albums/l299/uclamutt/DSC_1876.jpg Link to comment Share on other sites More sharing options...
