N.sane Posted October 20, 2010 Share Posted October 20, 2010 I found a set of Borbet Exor wheels locally and they look pretty nice so I'm thinking of picking them up. The thing is they have a 57.1mm center bore vs. our 56.1mm. Is that gonna be a problem? I don't imagine they make 1mm hub centric rings, right? Any advice is appreciated Link to comment Share on other sites More sharing options...
clarkwgriswold Posted October 20, 2010 Share Posted October 20, 2010 Yes it will be ok. Link to comment Share on other sites More sharing options...
Drift Motion Posted October 20, 2010 Share Posted October 20, 2010 u can run them without hub ring... Even with the standard 73.1mm you can run the wheels without hub rings Just have a set of tapered lug nuts that can properly center the wheels Link to comment Share on other sites More sharing options...
N.sane Posted October 20, 2010 Author Share Posted October 20, 2010 Do tapered lug nuts, like the McGard Splinedrive, work with OEM wheels? These wheels are actually OEM off a VW.. Link to comment Share on other sites More sharing options...
Drift Motion Posted October 21, 2010 Share Posted October 21, 2010 look at what kind of holes are on the wheel, aftermarket wheels have a tapered hole for tapered lug nuts Link to comment Share on other sites More sharing options...
ponchohome Posted October 21, 2010 Share Posted October 21, 2010 I did a 1 mm difference on my '05 Civic (thankfully sold last week) and there was a vibration on the highway. It was better with tapered lugs but still there. These were also OEM rims from another company. After that experience I would never do it again. Link to comment Share on other sites More sharing options...
Drift Motion Posted October 21, 2010 Share Posted October 21, 2010 u sure the wheels are round? Not bend or etc? Link to comment Share on other sites More sharing options...
N.sane Posted October 21, 2010 Author Share Posted October 21, 2010 Ill double check with the seller whether it's tapered or not. So if it's not tapered and I have to use the stock lugs then it's a no go? Link to comment Share on other sites More sharing options...
Drift Motion Posted October 21, 2010 Share Posted October 21, 2010 sorry, i dont really know about OEM wheels... Link to comment Share on other sites More sharing options...
abarnesDLGT Posted October 11, 2014 Share Posted October 11, 2014 I have a pair of bmw rims I'm trying to mount and am shopping for adapters , (5x100 to 5x120) the bore on the adapters is 57.1 just making sure it will fit and won't have vibration Link to comment Share on other sites More sharing options...
