rustler753 Posted June 27, 2009 Share Posted June 27, 2009 I read the stickies, but I just want to make sure I'm not fudging my numbers, guys gonna order the setup tomorrow: I run a stock suspension, and I am going with 225/40/18 Yoko S drives. I would like to run 235/40/18 but I am not sure if the tires will rub on a stock spring setup. According to the "Will it fit" sticky, they shouldn't but if someone could just verify that would be nice. More then likely the tire will be 18x8.5" but they said I could use 18x8" for a 235 tire. The guide said fender rolling MAY be required, but I wanted to see if anyone has experience with this setup. Link to comment Share on other sites More sharing options...
johnnymack Posted June 27, 2009 Share Posted June 27, 2009 Um, what kind of car do you drive? Lets start there. I run a 235/40/18 on a 18x8.5 wheel. I'm on COBB springs as well. I have NO rubbing issues whatsoever. Even after a few spirited drives, no issues. Link to comment Share on other sites More sharing options...
rustler753 Posted June 27, 2009 Author Share Posted June 27, 2009 Um, what kind of car do you drive? Lets start there. I run a 235/40/18 on a 18x8.5 wheel. I'm on COBB springs as well. I have NO rubbing issues whatsoever. Even after a few spirited drives, no issues. I drive a legacy GT limited >_>; I'm on stock springs, and I would be running 18x8" wheels on a 235/40/18. I'm just concerned about rubbing. Link to comment Share on other sites More sharing options...
str8dwn Posted June 27, 2009 Share Posted June 27, 2009 What offset are the wheels? Link to comment Share on other sites More sharing options...
rustler753 Posted June 28, 2009 Author Share Posted June 28, 2009 What offset are the wheels? There are two wheels I'm considering: Drag Wheels: DR-33 OFFSET: 18" - 42mm / 45mm or DR-9 OFFSET: 18" - 40mm to recap: 235/40/18 on a 18x8" Wheel with a 42mm/45mm offset: will that fit on a stock suspension on a 2005 legacy gt limited with no rubbing? Link to comment Share on other sites More sharing options...
rustler753 Posted June 28, 2009 Author Share Posted June 28, 2009 to recap: 235/40/18 on a 18x8" Wheel with a 42mm/45mm offset: will that fit on a stock suspension on a 2005 legacy gt limited with no rubbing? Bamp, need to know by tomorrow, he's ordering the tires/wheels by noon monday Link to comment Share on other sites More sharing options...
str8dwn Posted June 29, 2009 Share Posted June 29, 2009 Go with the +45. Lower than that offset, and you may run into fender rubbing issues if you ever decide to lower it. Also, +45 is closer to OEM offset and better for your wheel bearings. Link to comment Share on other sites More sharing options...
rustler753 Posted June 29, 2009 Author Share Posted June 29, 2009 Go with the +45. Lower than that offset, and you may run into fender rubbing issues if you ever decide to lower it. Also, +45 is closer to OEM offset and better for your wheel bearings. Thanks! Link to comment Share on other sites More sharing options...
