robnbecky Posted March 30, 2012 Share Posted March 30, 2012 Hi every one. I have a 97 Subaru Legacy L 2.2 auto. It has 148000 on the car. 100000 on motor Here is my problem the AWD is not working so this is what I know the AT oil light comes on when the car first starts then the light turns off in 1.5 seconds. But it does not flash rapid just comes on then off. There is no fuse in FWD slot. This what I have tried drained trans fluid was dark brown/black so I replaced fluid. No luck with the AWD. I have noticedat speeds higher than 60-65 I can hear tick tick tick non stop at those speeds. sounds like its coming from the trans or the rear transfer not sure. If someone could give any more knowledge about what I can do :)thanks to you all I love subaru this is my 3rd 1st 93 subaru legacy fwd 2nd 93 subaru legacy sport turbo awd 3rd 97 subaru legacy L wagon awd Link to comment Share on other sites More sharing options...
robnbecky Posted March 30, 2012 Author Share Posted March 30, 2012 If there is any more info that anybody needs I would be glad to fill you in on what ever you ask thanks for any help Link to comment Share on other sites More sharing options...
Spun Muffler Bearings Posted March 30, 2012 Share Posted March 30, 2012 The light should come on right when you start the car- this is to let you know that the bulb is working ok. Then it goes out again unless it senses high temps in the trans. Just to clarify... are you not getting AWD traction, or is it just a clicking noise at highway speed? Or both? Link to comment Share on other sites More sharing options...
robnbecky Posted March 30, 2012 Author Share Posted March 30, 2012 I am having both issues, sorry just scene your reply thank you:-) is it possibly the clutch in the rear transfer since there is no electrical? Link to comment Share on other sites More sharing options...
jamesm113 Posted March 30, 2012 Share Posted March 30, 2012 Try pulling any existing TCU codes, it might give a hint: http://www.ultimatesubaru.org/forum/showthread.php?p=668884#post668884 Link to comment Share on other sites More sharing options...
Reckoner Posted March 30, 2012 Share Posted March 30, 2012 I am having both issues, sorry just scene your reply thank you:-) is it possibly the clutch in the rear transfer since there is no electrical? Have u tried putting it on jackstand and starting it and putting it in gear and slowly letting off the brake and someone see if the driveline to the rear is turning or not Link to comment Share on other sites More sharing options...
robnbecky Posted March 30, 2012 Author Share Posted March 30, 2012 I will go to subaru shop and get the tcu checked. Yes I have had on stands it has no drive to the rear the rear diff is smooth and works properly but no power from the rear transfer. Thank you for your help :-) Link to comment Share on other sites More sharing options...
monkeyposeur Posted March 31, 2012 Share Posted March 31, 2012 Hey, what did you do with your 93 turbo leggy? Did you sell it on KSL, lol? Link to comment Share on other sites More sharing options...
