mccorry Posted May 20, 2006 Share Posted May 20, 2006 Hey everyone... finally getting around to trying this mod out.... I posted some preliminary photos on the Muffler Labotomy thread... but thought I would start my own since I have a bunch more photos and I didn't want to hijack his thread. I purchased a spare set of mufflers from another member on here... intending them to be sacrificial to this cause. The first couple of photos (1 and 2) are of the muffler cut open. I used a plasma cutter to remove the entire top plate of the muffler and you can clearly see that it is a 2 chamber / single baffle design with a 90 degree long radius bend on the outlet pipe. Next up was to do some measurements, drawings, and then some plans. The existing muffler piping in & out is ~ 1.5" diameter. I utilized 2 316L Stainless steel 45 deg fittings and some Schedule 10 316L stainless steel piping to make a spool section. Pictures 3 and 4 show the piping tacked up for test fitting. After all the measurements were nailed down... we Tig welded it all together.... Comparision photos can be seen on photos 5 and 6 of the stock muffler assembly and the muffler delete assembly. Link to comment Share on other sites More sharing options...
mccorry Posted May 20, 2006 Author Share Posted May 20, 2006 Next up was to test fit the muffler delete pipe into the car. As you can see in the first attached photo, the pipe was fabricated to utilize the factory hanger locations. With a little luck, the pipe slid right into place and bolted up. In pictures 2 and 3, you can see that the tip position VERY closely matches the factory tip location. The factory muffler assembly is on the drivers side... while the muffler delete pipe is on the passenger side. I plan on moving on to fabricate a drivers side muffler delete pipe as well. Overall, I am really pleased with the outcome. It isn't obnoxiously loud... but has a good healthy boxer rumble. At 72mph on the highway there is only a little exhaust noise... I wouldn't say that it is a drone. I re-used the factory oval tip... so besides the extra pipe music... it still looks completely factory. Photo 4 shows the muffler delete pipe mounted in place... from underneath the car. I will try to get some video with sound to post on here for you guys... if you/re interested. Link to comment Share on other sites More sharing options...
DeepFreeze2 Posted May 20, 2006 Share Posted May 20, 2006 Nice work!!! YA RLY!!! Home of +2500 useless posts!!!! Link to comment Share on other sites More sharing options...
hogmeat Posted May 20, 2006 Share Posted May 20, 2006 Where were you when I was selling a pre-fabbed set of these for $125?? Foo! I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
bosco Posted May 20, 2006 Share Posted May 20, 2006 thats why you are a "mod"erator, lol bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
mccorry Posted May 20, 2006 Author Share Posted May 20, 2006 Where were you when I was selling a pre-fabbed set of these for $125?? Foo! I wanted some that didn't look like they were found in the trash! Link to comment Share on other sites More sharing options...
meier motor sports Posted May 20, 2006 Share Posted May 20, 2006 nice work. if only i had a tig welder. heck a mig would work to Link to comment Share on other sites More sharing options...
rony Posted May 20, 2006 Share Posted May 20, 2006 I wanted some that didn't look like they were found in the trash! BURN! Nice work man. My Car vBGarage Link to comment Share on other sites More sharing options...
aldouse Posted May 20, 2006 Share Posted May 20, 2006 VIDS!!! SOUND CLIPS!!! where are they?! -- yay for the sig! -- my garage! Link to comment Share on other sites More sharing options...
PGT Posted May 20, 2006 Share Posted May 20, 2006 nice. My idea exactly, but I planned to leave the can around the pipe for a stock appearance. Since you went with the pipe alone, my suggestion would be to tighten up the fit to the bumper....looks a bit odd with nothing around it. Link to comment Share on other sites More sharing options...
mccorry Posted May 20, 2006 Author Share Posted May 20, 2006 VIDS!!! SOUND CLIPS!!! where are they?! I'll make some tomorrow.... Link to comment Share on other sites More sharing options...
pillboy Posted May 20, 2006 Share Posted May 20, 2006 Nice work. I want to know how it sounds when you are done with the other side. Let me know when you are in Minnesota. It is still ugly. Link to comment Share on other sites More sharing options...
mccorry Posted May 20, 2006 Author Share Posted May 20, 2006 nice. My idea exactly, but I planned to leave the can around the pipe for a stock appearance. Since you went with the pipe alone, my suggestion would be to tighten up the fit to the bumper....looks a bit odd with nothing around it. I thought about moving it up... but there were 2 concerns.... 1.) Vibration and sway of the pipe causing it to contact the bumper cover or support bracing 2.) Difficulty in fabricating the bracket and pipes without having the factory piece as a reference I thought it best to just try to duplicate the factory assembly, less the can. Link to comment Share on other sites More sharing options...
Th3Franz Posted May 20, 2006 Share Posted May 20, 2006 I installed the Kartboy urethane hangers to keep my AVO mufflers from moving around, and they really helped a lot. They also tucked the mufflers under the cutouts a little nicer.. something you might want to consider. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
KTM 525 Posted May 20, 2006 Share Posted May 20, 2006 That setup will be fairly tame at idle and when driving easy but will be nasty loud when the go pedal is stomped. I took my mufflers off and took the car for a ride and the above is what I noticed. Definatly not something I would be interested in but thats some nice work! Link to comment Share on other sites More sharing options...
rallispec Posted May 20, 2006 Share Posted May 20, 2006 nice. My idea exactly, but I planned to leave the can around the pipe for a stock appearance. Since you went with the pipe alone, my suggestion would be to tighten up the fit to the bumper....looks a bit odd with nothing around it. this will be what i do with the spare set -- i really want it to keep the stock look. Link to comment Share on other sites More sharing options...
mccorry Posted May 20, 2006 Author Share Posted May 20, 2006 Here's a quick video of it that I made this morning.... [ame=http://video.google.com/videoplay?docid=3371442942322151040]05 Legacy GT Muffler delete[/ame] It is a little chilly here this morning and the car is cold... hence the condensation from the exhaust and the backfiring. Once the car warms up .... it doesn't do that. Link to comment Share on other sites More sharing options...
Rely18 Posted May 20, 2006 Share Posted May 20, 2006 nice. almost sounds like a lawn-boy at the end of the clip! Link to comment Share on other sites More sharing options...
rexster Posted May 20, 2006 Share Posted May 20, 2006 enjoy the tickets... Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted May 20, 2006 Share Posted May 20, 2006 I think Jedi had this set up for a while. It sounded amazing at one of the meets last year. It's gonna sound even better with my electric cutout Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted May 20, 2006 Share Posted May 20, 2006 nice. almost sounds like a lawn-boy at the end of the clip! Link to comment Share on other sites More sharing options...
mccorry Posted May 20, 2006 Author Share Posted May 20, 2006 nice. almost sounds like a lawn-boy at the end of the clip! That's my add on Briggs and Straton gas powered turbocharger. Link to comment Share on other sites More sharing options...
VTGT Posted May 20, 2006 Share Posted May 20, 2006 interesting Link to comment Share on other sites More sharing options...
KTM 525 Posted May 20, 2006 Share Posted May 20, 2006 enjoy the tickets... Link to comment Share on other sites More sharing options...
aldouse Posted May 20, 2006 Share Posted May 20, 2006 holy backfire! -- yay for the sig! -- my garage! Link to comment Share on other sites More sharing options...
