Woodstock Posted May 15, 2015 Share Posted May 15, 2015 So today I replaced my wiper motor because it stop in the middle of a rainy day:rolleyes: As a result of my work, the blades stop higher that what it used to be. is there a way to adjust it? I think I messed up the linkage and/or the motor that I bought is defective? help is greatly appreciated. Video of how the wiper work https://youtu.be/oN67rG2q3pU Link to comment Share on other sites More sharing options...
starionesir Posted May 15, 2015 Share Posted May 15, 2015 You can remove the arms from the wiper cowl area and position them down lower. Not hard to do at all just remove the plastic cover, remove the nut and pull the arm off. Link to comment Share on other sites More sharing options...
Woodstock Posted May 15, 2015 Author Share Posted May 15, 2015 I have tried it, but then it would hit the plastic cover below if I reposition it lower. the video shows it swipe all the way down and stops where it is on the picture. I guess I will repostion it again and press it all the way down because I can still move the wiper blades while in parked position. Link to comment Share on other sites More sharing options...
starionesir Posted May 15, 2015 Share Posted May 15, 2015 I couldn't watch the video at work sorry. I did watch it on my lunch break and see what your talking about. I'm not sure if they have a adjustment for the park location or not. I'll see what I can find out. Link to comment Share on other sites More sharing options...
CapnJack Posted May 15, 2015 Share Posted May 15, 2015 Maybe try removing both wipers, allowing it to find home position by operating without the wipers installed, then reinstalling the wipers? Link to comment Share on other sites More sharing options...
