Mrrlyn Posted June 23, 2011 Share Posted June 23, 2011 I've got a 1999 30th Aniv that I've been trying to 'fancy-up', after having done a full engine swap (no turbo, just a replacement 2.2 for the original). My question is this - Where the hell does the keyless entry module plug in! This is the first year the Alpine system was used, and also the last year of the 2nd Gen Legacy. So, I'm looking for those other 1999 legacy owners out there. I originally bought a module off ebay with the part # 88035AE16B, from a 2003 I believe, and there was a perfect match under the driver kick panel, near the center console, kinda near the green two-wire set that is disconnected as standard. When I when down to the dealership to ask about part numbers and compatibility and such, I realized that for 2003 they had gone to chirps not honks, and maybe some internals in the module had been changed around and that was why it didn't work. Went back to eBay, picked one up with a 1999 part number this time, 88035AE050. Of course, the pin connector is now different. the 2003 module was arranged with 8 large pins across the top (closest to the side with writing), and then two sets of 5 smaller ones, one on either side of the locking tab. the other has a setup with all the same size pins, with four off to one side in a square and the remainder in two even rows. I was able to find a plug with this exact setup under the kick panel, just to the left of the steering column as viewed from the seat. The only problem was this was already connected to something, but only a couple of wires were coming off the back side of this one, one of which just looped back on itself into another pin on the same plug. Anyways, I disconnected that set-up, plugged the module in, and as a test, just made sure the power door locks still worked. Nope. Blew the 20A fuse. Figured maybe the module needed to be programed first, so I went through the whole open-close door, and key turning, but got no honk. So, my question is, where the heck is the proper plug for this module? I will attach pictures as needed, but if someone else with a 1999 legacy with the OEM keyless entry module could snap a few under-dash pictures, that would be awesome! Link to comment Share on other sites More sharing options...
Mrrlyn Posted June 28, 2011 Author Share Posted June 28, 2011 Self-Help Bump: Anybody? All I'm looking for is where the stock Keyless Entry Module is installed in your '99 Leg. Just a picture that shows the harness? Any help would be awesome! Thank you to all you out there! Link to comment Share on other sites More sharing options...
overspool Posted June 29, 2011 Share Posted June 29, 2011 I'm curious as well, I would love to have keyless entry on my 99 30th anniversary edition. Link to comment Share on other sites More sharing options...
subikid90 Posted June 29, 2011 Share Posted June 29, 2011 I cant say for the 99 but in the 97 and 98's it is under the driver side dash right above the fuse box down there. I have an 01 and I will look to see where it is located. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Mrrlyn Posted June 30, 2011 Author Share Posted June 30, 2011 Yeah, I think the tough part is that Subaru changed keyless/alarm systems a year before the Generation change. From what I got from the dealer, if I remember right, is that the module is the same from 1999 to 2001, so hopefully your car will be the same. Hopefully its in the same place! Thanks! Link to comment Share on other sites More sharing options...
subikid90 Posted July 1, 2011 Share Posted July 1, 2011 I just looked all around my 01 and it is no where to be found under the drivers side. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Mrrlyn Posted July 1, 2011 Author Share Posted July 1, 2011 Thanks for looking. My guess is that it is behind your glove box. It's just the fact that its this damnable '99 (though I love the car!) Older body style, newer keyless system...They had to change the plug for it (or I'm assuming they did), but at the same time, would the want to completely change the harness to move it from driver kick-panel area to the other side, when they leave everything else alone? I'm going to go snap some pictures of the setup under my dash and maybe that will trigger something for someone. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 2, 2011 I Donated Share Posted July 2, 2011 Most cars are under the driver side of the dash. If yours is not, I would be surprised. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
subikid90 Posted July 2, 2011 Share Posted July 2, 2011 I looked everywhere and couldnt find one under the dash of my 01 LGT. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Mrrlyn Posted July 5, 2011 Author Share Posted July 5, 2011 Here's a few pictures of where the two harness plugs are, the one with the old style (that currently has a loop back and a few other wires attached to it) and the one with the new style plugs (not attached to anything). Does anybody with key-less on a '99 have anything plugged in at either of these places? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 6, 2011 I Donated Share Posted July 6, 2011 Dont touch the green one lol. Its a diagnostics port -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Mrrlyn Posted July 12, 2011 Author Share Posted July 12, 2011 Hate to bump myself again...but I have those pictures up now, and maybe someone else with a '99 and keyless could take a look? Thanks again! Link to comment Share on other sites More sharing options...
arlia101 Posted July 14, 2011 Share Posted July 14, 2011 I just arrived on the forum, but have a '99 Legacy with (what I assume is) the stock keyless module. I have definitely seen it under the driver's dash - will take some pictures and post today or tomorrow! Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted July 15, 2011 Share Posted July 15, 2011 I have a 99' 5mt 2.5GT. When I bought it at an auction there was no remote for keyless entry. Should there be an option to get that back or should I just get an aftermarket alarm. The horn just chirps when I lock all the doors and shut it behind me. Can someone post a pic of the Alpine remote? Please. Link to comment Share on other sites More sharing options...
Mrrlyn Posted July 15, 2011 Author Share Posted July 15, 2011 Here is the picture of the front and the back of the Alpine remote used with the Legacy from 1999 to 2001. For the 2002+ (until they changed systems, and I don't remember which year it was), the keys/buttons were replaced with Orange and Blue, but the remotes are interchangeable. *edit* It should be pretty simple to reprogram the system you have to accept a new remote (or up to four). I'll find the instructions and put them up here. And TexasLegacy2.5GT, if you feel so inclined as to snap an under-dash picture too? It sounds like arlia101 has got it handled, but the more the merrier! and arlia101, thank you! Link to comment Share on other sites More sharing options...
arlia101 Posted July 16, 2011 Share Posted July 16, 2011 Here are the pictures I took under my own dash. I've tried to include as much information as I can in the few I'm posting; ask if you want another view, I should be able to accommodate: Under the steering wheel, removed the panel above the pedals (2 screws). http://img.photobucket.com/albums/v713/lehvak12/Subaru/th_IMG_4488.jpg Closeup of module: http://img.photobucket.com/albums/v713/lehvak12/Subaru/th_IMG_4482.jpg Module in context: http://img.photobucket.com/albums/v713/lehvak12/Subaru/th_IMG_4483.jpg And again: http://img.photobucket.com/albums/v713/lehvak12/Subaru/th_IMG_4487.jpg Connector for the module: (yes, it appears that it is the four-square pin connector) http://img.photobucket.com/albums/v713/lehvak12/Subaru/th_IMG_4493.jpg Can anyone guess if unplugging the remote module will require me to have to re-set-up it once I plug it back in? I don't really mind having to do that, but it's nice knowing beforehand. Mine also appears to be a slightly different part number - 88035AC210, versus Mrrlyn's. Relevance? Oh, right - here is a quick&dirty shot of the other large harnesses I saw underneath. Was one of them what you disconnected? http://img.photobucket.com/albums/v713/lehvak12/Subaru/th_IMG_4486.jpg Hope this helps! Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted July 16, 2011 Share Posted July 16, 2011 Mrrlyn, Let me check it out. It would be awesome if I had a keyless entry that I didn't even know about!! Thanks! Link to comment Share on other sites More sharing options...
Mrrlyn Posted July 18, 2011 Author Share Posted July 18, 2011 I believe if you unplugged it, you wouldn't need to reprogram it, based on the instructions. They indicate that if you are using a used module, you should program four things in, either one remote four times, or two twice etc., to wipe previous codes. But don't quote me on that! I obviously haven't been able to test it yet! Interesting that your part number is different, I'll have to check with the dealership on whats up with that. Maybe because yours is a SUS and mines not? Hmmm.... At least I know which plug to use! Thanks for that! Link to comment Share on other sites More sharing options...
cbt299 Posted August 20, 2011 Share Posted August 20, 2011 so i just need to order a remote and my sus can have remote entry??? Link to comment Share on other sites More sharing options...
cbt299 Posted August 21, 2011 Share Posted August 21, 2011 I'm unsure what to order... I have the module etc. Do i get alpine or one compatible with diablo? nvm figured it out... look here ... http://opposedforces.com/parts/legacy/us_b11/type_4/body_equipment_interior/key_kit_and_key_lock/illustration_2/ to program remote Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time. Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up. When the horn honks, open and close the driver's door, press any remote button and that's it. Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted August 26, 2011 Share Posted August 26, 2011 Did you get it working? Link to comment Share on other sites More sharing options...
cbt299 Posted August 28, 2011 Share Posted August 28, 2011 Haven't had a chance or money to order it just yet. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted August 28, 2011 Share Posted August 28, 2011 How much money are we talking about? Just the remotes? Link to comment Share on other sites More sharing options...
cbt299 Posted August 28, 2011 Share Posted August 28, 2011 yea lol... just remotes. I had to buy football tickets so had to wait a fewdays. I am ordering the remote tonight. update, I bought it off ebay, 24 bucks shipped. Should be here mid-week and I will let everyone know. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted August 29, 2011 Share Posted August 29, 2011 Yes, I'm interested since my GT has the whole keyless entry as well! Link to comment Share on other sites More sharing options...
