wideband location ?
jaxx4k
Really, the WBO2 kit's manual doesn't tell you this?
Sniffing after the cat tells you nothing. Sniffing before the turbo is inaccurate when in boost. Installing the sensor in the lower half of a pipe puts it in contact with condensate which will kill it. This pretty much leaves the section of bellmouth or pipe between the turbo flange and any cats, and the top half of the pipe, meaning anywhere between 270* and 90*, or 9 o'clock and 3 o'clock.
I do hope you read the manual before touching any wiring.
Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs.
yea Really on a catted DP... cause Im planning on going back catted.
I now have a catless and is welded bout 10" down from bellmouth.
the manual calls for 10-18" away from turbo and if is to close to hotside it will kill the sensor, but from 7" & on the cat is in the way and I don't think reading it after the cat is good for anything..
http://i859.photobucket.com/albums/ab157/graphite_subaru/subaru%20pics/d56fe2f2.jpg
NSFW hit this particular nail straight on the head. The manufacturers are thinking regular inline-4 installs where the turbo is very close to the exhaust ports rather than our remote location in the next county. On any Subaru but a 5th gen Legacy you go right ahead and weld it in straight after the flange. The exhaust gas is cold enough by that point it won't hurt the sensor.
Cause of sensor death for us will be either pig-rich mixture or condensation from bad placement.
Putting the wideband O2 after a a high-flow cat is not a big deal. The sensor will read slightly richer than the A/F actually is, but it's nothing major. The cat deals with NOx emissions much more than affecting the amount of oxygen in the exhaust stream.
I got rid of my rear O2 sensor and put my wideband in its place.
I just installed my Zeitronix wideband system today, and I installed the sensor before the cat where the rear O2 sensor was on my Cobb HFC DP. How much more accurate would it be if installed up top?
The distance doesn't affect accuracy per se, a lot of dyno shops will use a sniffer in the tailpipe. There is however more delay between a combustion event and it being measured by the sensor the further away it is from the exhaust ports. For this reason I wouldn't mount so far back if for example I was using it for closed-loop fueling. For logging at typical K-line speeds I wouldn't worry about it too much.
any catted guys w/pics?
I've got a shot. What dp are you running. I've got the invidia and because it has a divorced bellmouth, the wbo2 is not centered. Take a look. Been running the original sensor probably close to 2 years and still no problems with erratic readings.
http://i108.photobucket.com/albums/n29/joeleodee/IMAG0266.jpg
