xLEGACYx Posted April 21, 2012 Share Posted April 21, 2012 So I have tein s techs installed right now and my drivers rear is sitting lower than my passenger rear -__- has anyone ran into a similar problem? My manager at the shop I work at suggested I turn my spring like a quarter turn, but I thought I'd ask you guys before I rip into it. Link to comment Share on other sites More sharing options...
mwm5094 Posted April 21, 2012 Share Posted April 21, 2012 Are you sure your parking on a level surface? And turning the spring will not do anything if they are seated properly, which is something that you should check. Link to comment Share on other sites More sharing options...
cypher0117 Posted April 21, 2012 Share Posted April 21, 2012 My car was like that as well on koni/eibach springs. Once I got a decent alignment with cross camber less than .05 degrees my body now sits even on both sides. YMMV Link to comment Share on other sites More sharing options...
xLEGACYx Posted April 22, 2012 Author Share Posted April 22, 2012 I've definitely had it leveled to check and it's seated properly, but my drivers camber is way off which I suspected was the issue. Camber kit enroute so we'll see if that fixes the issue. Link to comment Share on other sites More sharing options...
Sir_vq Posted April 23, 2012 Share Posted April 23, 2012 I've definitely had it leveled to check and it's seated properly, but my drivers camber is way off which I suspected was the issue. Camber kit enroute so we'll see if that fixes the issue. what camber kit did you use i seen AVO has a couple of them, post a pick curious how outta whack it is Link to comment Share on other sites More sharing options...
xLEGACYx Posted April 23, 2012 Author Share Posted April 23, 2012 I bought the Whiteline kit for 40$. I'll snap a pic later. It's not ridiculous, but the drivers rear definitely is cambered out quite a bit more than the passenger side. Link to comment Share on other sites More sharing options...
SpecBGuy Posted April 23, 2012 Share Posted April 23, 2012 dont worry my car is like that too when i bought my car left side seemed higher so i told the service guy to check all the alignments and it was even. ive had 3 different springs stock, ion, and now swifts the left side is still higher than the right. Link to comment Share on other sites More sharing options...
