MYGSXR1000 Posted October 25, 2008 Share Posted October 25, 2008 i have a ? i spliced into the rear speakers and was going to wire the RCA up that way my problem is when i hook the center/positive part of the RCA to the speaker it works fine but if i try to hook up the ground it kicks the amp off is that normal? Link to comment Share on other sites More sharing options...
MYGSXR1000 Posted October 25, 2008 Author Share Posted October 25, 2008 do i need the ground wire on the speaker hooked up to the amp? Link to comment Share on other sites More sharing options...
stclark13 Posted October 25, 2008 Share Posted October 25, 2008 i'm not sure i understand what your trying to do. Why are you hooking up rca's to speakers? If you have a line/out converter there should be 4 speaker wires usually white+ white/black- gray+ gray/black-. Whites are left and grays are right. Hook those wires up to coresponding speakers or behind radio. Then on the opposite side there are your rca connections and run a set of rcas from there to your amp and thats it. It sounds like your trying to hook rca's directly from your speaker to you amp which in theory will work but if any ground wire( the wires on the outside of the rca when stripped) is touching the center wire the positive it'll short out whatever your running it to. The amp is protecting itself from burning the channels out. Hope this helps. Link to comment Share on other sites More sharing options...
smokedoutv6 Posted October 25, 2008 Share Posted October 25, 2008 /\ +1 you need to use a lineout converter. you're risking blowing your amp by running it drectly to the speaker. IIRC speakers are normally a 4 ohm load and RCAs are not so you would be pusing an incorrect signal into the amp which isnt good. the line out converter does more then just pass the signal going into the speaker into an rca plug it also changes the ohm going into the rca. Link to comment Share on other sites More sharing options...
str8dwn Posted October 25, 2008 Share Posted October 25, 2008 +1 Spend the $75 and take it to a reputable shop for installation. They'll set your gains and make the install clean and neat. Link to comment Share on other sites More sharing options...
stclark13 Posted October 26, 2008 Share Posted October 26, 2008 ^^^^ sounds like a good idea however the shops i used to work at used to charge more once you decided to "try" yourself, plus they like to use all there wires. Link to comment Share on other sites More sharing options...
NutBucket Posted October 27, 2008 Share Posted October 27, 2008 But don't most amps have speaker level inputs? Link to comment Share on other sites More sharing options...
stclark13 Posted October 27, 2008 Share Posted October 27, 2008 wow didn't even think of that, can't remember the last time i hooked one up like that. Link to comment Share on other sites More sharing options...
20lgt06 Posted October 28, 2008 Share Posted October 28, 2008 get a 4 channel line out converter then you will be fine Link to comment Share on other sites More sharing options...
