JermTheElf Posted May 23, 2014 Share Posted May 23, 2014 If you've had problems with their clutches please fill this out and post and I will update the OP with everyone's issues. I'd like to consolidate all of these issues everyone is having. CM Clutch Model: Car TQ: Flywheel: Chatter experienced?: How many miles installed for: Reason for removal: Replaced with: Happy with replacement?: JermThElf CM Clutch Model: ClutchMasters FX350 Car TQ: 370 ft/lbs (wheel) Flywheel: WRX SMFW (resurfaced) Chatter experienced?: Mostly in humid conditions, inconsistant, worse after breakin How many miles installed for: 12,500 miles Reason for removal: Clutch began to slip in 1st gear from a stop only, eventually slipped in all gears Replaced with: Spec Stage 2+ SU203H Happy with replacement?: Very happy, would reccomend this clutch for pedal effort, grab and comfort ras06LGT Clutch Model: CM FX350 Car TQ: ~280 WHP (BNR 16G, 93 octane, never been on a dyno) Flywheel: New OEM 06+ SMFW Chatter: None through break-in up to about 2,000 miles. Got progressively worse until I removed it at ~9,000 miles. All weather condition, all take-off RPMs, all clutch release speeds. Miles installed for: ~9,000 miles Reason for removal: Excessive chatter in all conditions Replaced with: Exedy Stage 1 kit 15804, same SMFW Happy with replacement: Absolutely! Heavier pedal effort, but very smooth and predictable engagement. Zero chatter after 5,000 miles on clutch. Holds my power levels very well. Cheaper than other options ($430). RedDawg CM Clutch Model: FX350 Car TQ: Stage 2 e-tune (unsure of the exact tq) Flywheel: wrx oem single-mass Chatter experienced?: very bad chatter to where the car is shaking if I start from a stop with anything <2k-rpms How many miles installed for: 10,000 miles and just noticed slipping in 4th & 5th gear when boost builds for passing on the highway. Reason for removal: not removed yet Replaced with: note removed yet Happy with replacement?: I hope I will be idiot4hire CM Clutch Model: FX350 Car TQ: 318lbs Flywheel: wrx oem single-mass Chatter experienced?: lasted 5k miles How many miles installed for: 8k miles Reason for removal: slipping 3rd, 4th, 5th and jumping in second Replaced with: spec 2+ going in soon Happy with replacement?: I had one before so I know I will be dahoseman 1) CM Clutch Model: FX300 Car TQ: 302 Flywheel: WRX SMFW Chatter experienced?: NO How many miles installed for:3000 miles Reason for removal:Complete failure with inability to put car into neutral. “Defective Pressure Plate” was final analysis by CM Replaced with: FX350 sent as replacement Happy with replacement?:NO 2) CM Clutch Model: FX350 Car TQ: 302 Flywheel: WRX SMFW - Resurfaced Chatter experienced?: YES, Like an earthquake. Progressively worse over time. All gears. All conditions. How many miles installed for: 5000 miles Reason for removal:Chatter became so severe that bolts, nuts, and screws were being rattled loose. Clutch found to be ‘worn out’ by CM Replaced with: FX200 sent as replacement Happy with replacement?: I think so. However, the clutch pedal has been creeping up over 8000 miles. compsurge CM Clutch Model: FX300 Car TQ: Stage 2 Flywheel: OEM WRX SMFW Chatter experienced?: Yes - slight after 3k How many miles installed for: 32k Reason for removal: No more clutch material Replaced with: FX300 - thanks M Sprank for a good deal! Happy with replacement?: Haven't driven yet (low priority until next week) PutnamCO CM Clutch Model: FX400 Car TQ:380 wtq Flywheel: OEM STI Chatter experienced?: No How many miles installed for:7k Reason for removal: Sudden and complete failure. No slipping, smoke, smell etc before it completely stopped working. Literally shifted into gear and felt like I was in neutral. To get the car out of the road, I revved it up, and the car inched forward at 5000+ rpm. Replaced with:FX300 Happy with replacement?: Not installed yet. Mailed the clutch to Clutchmasters, and they "We unable to determine reason for failure". They offered to give me a deal on rebuilding my clutch, but I'm not comfortable putting the same clutch back in, since they don't know what the problem was. Luckily, Mike from Infamous bailed me out and gave me a very good deal on an FX300, since I bought the original from him. Mike being a stand-up vendor as always. I went with the FX300 because many fewer people on here report problems, and Mike recommended it. Fingers crossed... Timbo7 CM Clutch Model: fx350 Car TQ: 340 Flywheel: oem wrx Chatter experienced?: Yes. How many miles installed for:9k Reason for removal: Havent removed yet. But its slipping in 3rd and 4th when wide open. Hopefully I can get new one soon and pull it. Replaced with: looking at the spec2+ Happy with replacement?: see above MaStaMooN CM Clutch Model: FX300 Car TQ: unknown (stage2+tmic) Flywheel: WRX SMFW Chatter experienced?: Bad in the beginning, fine now. How many miles installed for: 25k Reason for removal: Slipping in 5th gear when passing/accelerating Replaced with: tuner recommends Exedy Stage 1, still weighing options Happy with replacement?: see above NastyLGT CM Clutch Model: fx350 Car TQ: 260ish Flywheel: 06 WRX Chatter experienced?: Since day one.... How many miles installed for: about 10,000 Reason for removal: haven't removed yet. But its slipping in all gears and chatter is extremely bad Replaced with: either oem or spec 2 Happy with replacement?: hopefully.... srehn CM Clutch Model: FX350 Car TQ: 330 Flywheel:New OEM single mass Chatter experienced?: Massive. From the beginning until about 9500 miles at which point it started to slip in 5th and 6th under boost. Now slipping in 3rd and 4th if not babied. Now that it's dying, its actually manageable from a dead stop. How many miles installed for: Still in at 10,000 but living on borrowed time. Reason for removal: ^^ Replaced with: Looking at Southbend stage 3 daily and Spec 3+ Happy with replacement?: Advice is always welcome. Link to comment Share on other sites More sharing options...
ras06LGT Posted May 23, 2014 Share Posted May 23, 2014 Clutch Model: CM FX350 Car TQ: ~280 WHP (BNR 16G, 93 octane, never been on a dyno) Flywheel: New OEM 06+ SMFW Chatter: None through break-in up to about 2,000 miles. Got progressively worse until I removed it at ~9,000 miles. All weather condition, all take-off RPMs, all clutch release speeds. Miles installed for: ~9,000 miles Reason for removal: Excessive chatter in all conditions Replaced with: Exedy Stage 1 kit 15804, same SMFW Happy with replacement: Absolutely! Heavier pedal effort, but very smooth and predictable engagement. Zero chatter after 5,000 miles on clutch. Holds my power levels very well. Cheaper than other options ($430). Link to comment Share on other sites More sharing options...
RedDawg Posted May 23, 2014 Share Posted May 23, 2014 CM Clutch Model: FX350 Car TQ: Stage 2 e-tune (unsure of the exact tq) Flywheel: wrx oem single-mass Chatter experienced?: very bad chatter to where the car is shaking if I start from a stop with anything <2k-rpms How many miles installed for: 10,000 miles and just noticed slipping in 4th & 5th gear when boost builds for passing on the highway. Reason for removal: not removed yet Replaced with: note removed yet Happy with replacement?: I hope I will be Link to comment Share on other sites More sharing options...
idiot4hire Posted May 24, 2014 Share Posted May 24, 2014 CM Clutch Model: FX350 Car TQ: 318lbs Flywheel: wrx oem single-mass Chatter experienced?: lasted 5k miles How many miles installed for: 8k miles Reason for removal: slipping 3rd, 4th, 5th and jumping in second Replaced with: spec 2+ going in soon Happy with replacement?: I had one before so I know I will be Link to comment Share on other sites More sharing options...
dahoseman Posted May 26, 2014 Share Posted May 26, 2014 1) CM Clutch Model: FX300 Car TQ: 302 Flywheel: WRX SMFW Chatter experienced?: NO How many miles installed for:3000 miles Reason for removal:Complete failure with inability to put car into neutral. “Defective Pressure Plate” was final analysis by CM Replaced with: FX350 sent as replacement Happy with replacement?:NO 2) CM Clutch Model: FX350 Car TQ: 302 Flywheel: WRX SMFW - Resurfaced Chatter experienced?: YES, Like an earthquake. Progressively worse over time. All gears. All conditions. How many miles installed for: 5000 miles Reason for removal:Chatter became so severe that bolts, nuts, and screws were being rattled loose. Clutch found to be ‘worn out’ by CM Replaced with: FX200 sent as replacement Happy with replacement?: I think so. However, the clutch pedal has been creeping up over 8000 miles. Link to comment Share on other sites More sharing options...
compsurge Posted May 26, 2014 Share Posted May 26, 2014 CM Clutch Model: FX300 Car TQ: Stage 2 Flywheel: OEM WRX SMFW Chatter experienced?: Yes - slight after 3k How many miles installed for: 32k Reason for removal: No more clutch material Replaced with: FX300 - thanks M Sprank for a good deal! Happy with replacement?: So far, so good. ~230 miles into break-in. I have about ~3k on it as of 7/30/2014 and it seems to be holding up better than my last one. Original likely failed due to improper break in (not enough city style driving) and riding the clutch for smooth engagement. I was very happy with it initially. I will give it a second chance before judgment. I replaced several components as well for the second attempt: new TSK3 TOB, clutch fork, pivot ball, and added the flywheel cover and bellhousing plastic inspection cover both were missing when I bought the car). Salt spray and water intrusion may have had a role in accelerated wear. Carnage pics Link to comment Share on other sites More sharing options...
idiot4hire Posted May 26, 2014 Share Posted May 26, 2014 What really f'd up about this is cm told me they don't have any reported of early slipping Link to comment Share on other sites More sharing options...
JermTheElf Posted May 26, 2014 Author Share Posted May 26, 2014 Thanks everyone I'll update the OP tomorrow Link to comment Share on other sites More sharing options...
JermTheElf Posted May 27, 2014 Author Share Posted May 27, 2014 Wow, seven reported cases so far. I wonder how many others have had issues. Link to comment Share on other sites More sharing options...
PutnamCO Posted June 12, 2014 Share Posted June 12, 2014 Ended up being a rear axle clip coming off, allowing the axle to move out of the diff just enough to cause a loss of power to all four wheels. Very strange, but that's what happened. Link to comment Share on other sites More sharing options...
timbo7 Posted July 22, 2014 Share Posted July 22, 2014 CM Clutch Model: fx350 Car TQ: 340 Flywheel: oem wrx Chatter experienced?: Yes. How many miles installed for:9k Reason for removal: Havent removed yet. But its slipping in 3rd and 4th when wide open. Hopefully I can get new one soon and pull it. Replaced with: looking at the spec2+ Happy with replacement?: see above Link to comment Share on other sites More sharing options...
MaStaMooN Posted July 23, 2014 Share Posted July 23, 2014 CM Clutch Model: FX300 Car TQ: unknown (stage2+tmic) Flywheel: WRX SMFW Chatter experienced?: Bad in the beginning, fine now. How many miles installed for: 25k Reason for removal: Slipping in 5th gear when passing/accelerating Replaced with: tuner recommends Exedy Stage 1, still weighing options Happy with replacement?: see above Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
NastyLGT Posted July 23, 2014 Share Posted July 23, 2014 Add another one to the list CM Clutch Model: fx350 Car TQ: 260ish Flywheel: 06 WRX Chatter experienced?: Since day one.... How many miles installed for: about 10,000 Reason for removal: haven't removed yet. But its slipping in all gears and chatter is extremely bad Replaced with: either oem or spec 2 Happy with replacement?: hopefully.... EDIT: if anyone has any insight on me throwing a 07 LGT oem clutch in there....assuming the factory clutch lasted about 90k, this should do the same. All I have done to the car is headers+up, downpipe. Plan on keeping it stage 2. Anyone think I will be disappointed with the oem clutch with these mods? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 28, 2014 Share Posted July 28, 2014 I do. I would never put a oem clutch back in these cars. Spec 2 It should work with your newly re-surfaced FW. Call Mike a www.AZPinstalls.com and tell him what you got and he'll take care of you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
NastyLGT Posted July 28, 2014 Share Posted July 28, 2014 I do. I would never put a oem clutch back in these cars. Spec 2 It should work with your newly re-surfaced FW. Call Mike a www.AZPinstalls.com and tell him what you got and he'll take care of you. I've just read a lot of bad things about spec. And not so many about oem replacement. This is the 3rd clutch I'll be putting in in 30k miles... Link to comment Share on other sites More sharing options...
Max Capacity Posted July 29, 2014 Share Posted July 29, 2014 HAve you ever tried to back up in 3-4" of heavy snow with a stock clutch. My 00'GT wagon and my 05 would smoke the stock clutch doing that. I have no faith in a OEM clutch. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JermTheElf Posted July 30, 2014 Author Share Posted July 30, 2014 Updated OP. Maybe a mod could sticky this so it's easier to find and warn about the issues with these clutches now that we've racked up quite a few cases of the same issue? Link to comment Share on other sites More sharing options...
srehn Posted August 6, 2014 Share Posted August 6, 2014 CM Clutch Model: FX350 Car TQ:330 Flywheel:New OEM single mass Chatter experienced?: Massive. From the beginning until about 9500 miles at which point it started to slip in 5th and 6th under boost. Now slipping in 3rd and 4th if not babied. Now that it's dying, its actually manageable from a dead stop. How many miles installed for: Still in at 10,000 but living on borrowed time. Reason for removal: ^^ Replaced with: Looking at Southbend stage 3 daily and Spec 3+ Happy with replacement?: Advice is always welcome. Link to comment Share on other sites More sharing options...
JermTheElf Posted August 6, 2014 Author Share Posted August 6, 2014 We now have 12 reported cases of premature failure. Link to comment Share on other sites More sharing options...
timbo7 Posted August 6, 2014 Share Posted August 6, 2014 CM Clutch Model: FX350 Car TQ:330 Flywheel:New OEM single mass Chatter experienced?: Massive. From the beginning until about 9500 miles at which point it started to slip in 5th and 6th under boost. Now slipping in 3rd and 4th if not babied. Now that it's dying, its actually manageable from a dead stop. How many miles installed for: Still in at 10,000 but living on borrowed time. Reason for removal: ^^ Replaced with: Looking at Southbend stage 3 daily and Spec 3+ Happy with replacement?: Advice is always welcome. I had the same experience. It doesn't chatter much at all now that it's dying. I'm looking at the stage 3 daily from sb too. Haven't seen many complaints from sb if any. Hopefully I like it. Link to comment Share on other sites More sharing options...
timbo7 Posted August 6, 2014 Share Posted August 6, 2014 We now have 12 reported cases of premature failure. Is someone going to send this to clutch master or is something going to be done? Link to comment Share on other sites More sharing options...
JermTheElf Posted August 6, 2014 Author Share Posted August 6, 2014 Is someone going to send this to clutch master or is something going to be done? Not sure how to go about it. Curious to see if anyone over at nasioc has complained. Link to comment Share on other sites More sharing options...
compsurge Posted August 7, 2014 Share Posted August 7, 2014 Why? I still don't see anything wrong with their clutches. This is 12 reports out of thousands. FWIW, my replacement has been great so far and I haven't experienced any of the issues I had on the last one. Link to comment Share on other sites More sharing options...
subielova88 Posted August 7, 2014 Share Posted August 7, 2014 CM CLUTCH MODEL: FX300 Flywheel:: OEM single mass Chatter experience: Since installed all the way up to now Miles installed for: Around 15k now Reason for removal: Not yet, but I might have to since it blew up completely, I can't even shift thru my gears now at all, and it's weird because sometimes it will let me. It just happened 2 days ago too. Link to comment Share on other sites More sharing options...
jay-d Posted October 27, 2014 Share Posted October 27, 2014 CM Clutch Model: FX250 Car TQ: Under 300lbs. Flywheel: WRX SMFW Chatter experienced?: Yes, only in 1st though. How many miles installed for: 6 months, 20,000km Reason for removal: Starting to slip in 5th at 3,000rpm Replaced with: Haven't yet, looking at Exedy Stage 1 or SouthBend Happy with replacement?: Link to comment Share on other sites More sharing options...
