sportwagon Posted February 3, 2009 Share Posted February 3, 2009 Hello, I have an 05 Legacy 2.5GT with 80k miles and I just replaced the clutch with an ACT HD Street Modified clutch and the WRX flywheel. I have been at stage 1 (cobb OTS version) via an Accessport v1 for a long, long time... Now, I have finally got around to installing an UP/DP, but they were installed at the same time as the new clutch! How long should I wait? I don't want to get the tuning done before the clutch is completely broken in... Yesterday I switched the map (not the base map) from Cobb stg. 1 93 OCT to Cobb stg. 2 93 OCT and did some mild stop and go driving and today I drove to work (mostly highway)... The car felt fine! Also... What should I avoid doing while breaking in the clutch? -Avoid hard launches obviously!-Avoid high boost?-Avoid >3000 RPM?-Avoid stop and go? -Avoid long highway stretches?-Avoid cruise control?-Avoid ???? I'm just not completely sure about what exactly is "good break-in driving for a new clutch" ACT website said ~500 miles for break-in, but was very "vague" It basically said to avoid "aggressive driving"... I'm pretty sure I'll do fine... but figured it couldn't hurt to aks! Also, For some immediate tuning questions: I have many other mods... (I'll post them once I update) Can I get by with the Cobb OTS Stage 2 version for a little while?Is it OK to stay with the Stage 1 base map during the clutch break-in? OR, should I do the stage 2 base map update immediately? Thanks!Mark Link to comment Share on other sites More sharing options...
sportwagon Posted February 3, 2009 Author Share Posted February 3, 2009 Chassis/Suspension:JDM Legacy STi Sport Spring Set – PinkJDM Legacy GT Bilstein Struts – Rev. A½” Saggy Butt Shims for the rear (w/ new studs pressed into the top hats) Spec B Aluminum Front Lower Control ArmsSuperPro Polyurethane Camber-Increasing LCA BushingsSTi Trailing Arms w/ ball-bearing bushing– Painted Blue w/ Silver STi logos4BoxParts Adjustable forward lateral links Cusco Front Sway Bar 23mm – Blue (197% Increase in stiffness)Cusco Rear Sway Bar 21mm – Blue (44% Increase in stiffness)AVO F/R Solid EndlinksCobb Rear Sway Bar Reinforcement Bracket KitSTi Upper Strut BarCusco Front Lower Brace – BlueCusco Rear Lower Brace – Blue Engine:AVO Bar & Plate Top Mount Intercooler – Red-Painted STi LogoGFB Hybrid Blow Off Valve – Set to 50/50 recirculationZero Sports Cool Action Intercooler SplitterZero Sports Intake PipePerrin Radiator Hose – RedPerrin Drop-In filterBlitz Induction Cover - Air Box ReplacementSamco BOV Hoses – Red(Perrin Lightweight Crank Pulley to be installed) Engine Management:Cobb AccessPort – Stage 1 Base Map – Stage 2 - 93 OctaneEngine Bay Bling:Cusco Radiator Cooling PlateSTi 1.4 Barr Radiator CapSTi Engine Oil CapProdrive Battery Tie-downJDM Engine Bay Cover Set – Black Brakes:Painted Calipers – RedDBA 4000 Series Slotted Rotors Front & RearHawk HPS Brake Pads Front & RearGoodridge Silicone-Coated Stainless Steel Brake Lines – Carbon GraySubaru Brake Fluid Drivetrain:Cobb Double-Adjustable Short Throw ShifterKartboy Rear Shifter BushingKartboy Hardened Shifter Bushings Exhaust:Turbo XS Uppipe Invidia High Flow Catted DownpipePerrin Mid and Y-Pipe Exhaust SectionGenome STi Axle-back Exhaust Cusco Exhaust Hangars Audio:Sony MEX-5DI MP3/CD/Memeory Stick Receiver w/ TFT LCD DisplaySony CDX-757MX 10 Disc CD/MP3 ChangerSony XA-300 Auxiliary/BUS Changer Control Unit w/ USB InterfaceJL CleanSweep CL44I dspJL 500/1 Monoblock AmplifierJL 300/4 4 Channel AmplifierJL 10W7 High Output Wedge Subwoofer BoxJL VR 650-Csi Front Component SpeakersJL VR 600-Csi Rear Component SpeakersJL Remote Bass Control KnobJL XA-PBTC- 2 – Positive Battery TerminalJL XA-NBTC- 2 – Negative Battery TerminalJL XA-BLKPW4- 115 – 4 Gauge Ground Power Wire (55Ft)JL XA-REDPW4- 115 – 4 Gauge Positive Power Wire (55Ft)JL XA-MGL1- B – Master Ground Lug BoltJL XA-FUSE-ANL- 150 – 150 AMP Blade Fuse(8) JL XA-RT- 4 – 4 Gauge Ring Terminals (8 Pairs)(2) JL XA-BLUSCS12- 130 – 12 Gauge Parallel Conductor Speaker Wire Kits (50Ft)JL XA-BLUAIC4-18 – 4-Channel Audio Interconnects (Sony H.U. to JL 300/4)JL XA-BLUAIC2-18 – 2-Channel Audio Interconnects (Sony H.U. to JL 500/1)JL XA-BLUAIC2-12 – 2-Channel Audio Interconnects (Sony H.U. to Aux Changer)JL XA-BLUAIC2- 9 – 2-Channel Audio Interconnects (10 Disc MP3 to Aux Changer)JL XA-BLUAIC2- 6 – 2-Channel Audio Interconnects (CleanSweep to Aux Changer)Monster Audio MPC S402 2C-15M – 402 XLN Extreme Speaker wire (50Ft)Monster Audio 4 Gauge Terminal Breaker SwitchPhoenix Gold Powered/ Fused Distribution Block w/ LED/ Remote LED Status IndicatorVoodoo FBVP11DNL – Digital Voltage Meter/Fuse Block Sound-Deadening:Application: 100% Coverage (no bare metal showing) Areas of:Trunk, Trunk Lid, Rear Deck, Rear Seat Deck, Rear Floor, Rear A-Pillars, Under Front Seats, Center Console Area, Front Floor, and Four Doors (Inner Frames & Body Panels)Sound-Deadening Materials:(2) Dynamat Extreme Bulk Packs – 72 total sq/ft Material (1.7mm thick) ~ 33 Lbs(2) B-Quiet Extreme 50ft Rolls – 100 total sq/ft Material (1.15mm thick) ~ 33 Lbs Interior:Auto-dimming Mirror With Compass (only factory option)Rear Center Seatbelt RemovalAVO Single Din Cubby ReplacementSTi Side Sills KitAuthentic STi Floor Mats (2004 Impreza STi)Red Line Goods Shifter Boot (shortened 4” Black Leather w /JDM Quadruple Stitching) Red Line Goods E-Brake Boot (Black Perforated Leather w/ JDM Quadruple Stitching)Red Line Goods Armrest Cover (Black Perforated Leather w/ JDM Quadruple Stitching)STi Carbon Fiber Shift Pattern2002-2003 Genuine STi Foglight Mesh-Grille custom install into rear deck lidCup Holder Blue LED Illumination ModGarmin Nuvi 660 -Buried 12V Mod (cell phone charger and Garmin Nuvi charger) Driver Interface:MOMO Steering Wheel (stock) w/ STi EmblemMOMO Aluminum Air Shift Knob / STi Ti Shift Knob / STi Black Delrin Shift Knob STi Metal Pedal Set – Silver/Pink Gauges:Defi BF Boost Gauge Meter – Brass T-FittingDefi BF Fuel Pressure Gauge Meter – Custom Brass Fuel Pressure Line AdapterDefi BF Oil Pressure Gauge Meter – Subaru Oil Gallery Plug Adapter(3) Defi 60mm Meter Cups(3) Defi Free-Angle Mounts(3) Defi Meter Cup HoodsCustom 3-Meter Cup BracketDefi Control Link Unit II -Custom Control Unit installation in Astray location Exterior:Debadged TrunkCyber R Carbon Fiber “Big Bulge” hood scoop – not installed yetRBS Replica JDM GrilleRBS Replica JDM Front Lip Spoiler - currently in 4 pieces – not installedSubaru Moonroof Air DeflectorThule Roof Rack Thule Fairing REI Exclusive Thule Roof Box – Carbon Fiber Pattern(2) STi License Plate Frames – Polished StainlessProtection:Rock Blockers Headlight Protection – ClearRock Blockers Fog light Protection – YellowRalliTek Hydro-Cut Aluminum Skidplate – Painted BlueRally Armor Mud Flaps Security:CompuStar 2WSS Remote Start/ Alarm/ Turbo-timer Safety:Xenon Factory 5000K HID Conversion Kit – PnP Wheels/Tires:SummerProdrive PFF7 Bright Fitter Alloy Rims (18 x 8, 5x100, ET51 CB, 21.35 lbs) Toyo Proxes T1R Ultra-High Performance Summer Tires 235/40/18 Winter Prodrive P1 Bright Silver Alloy Rims (17 x 7, 5x100, ET52 CB, 20.04 lbs) Nokian WR G2 Performance All-Season Snow Tires 225/40/17Utility/Off-road Prodrive P7 Gunmetal Alloy Rims (17 x 7, 5x100, ET52 CB, 22.50 lbs) Bridgestone RE092 All-Season Tires 215/45/17 (stock tires)STi JDM Lug Nut Set by McGard – Black Other Modifications:Green Screaming Trunk Monkey w/ Dark Hangover Shades (+10WHP) Link to comment Share on other sites More sharing options...
rao Posted February 3, 2009 Share Posted February 3, 2009 Just drive the car normally. If you are very paranoid (and it looks like you are ) wait 500 miles before you do the tuning. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Spec B Posted February 3, 2009 Share Posted February 3, 2009 If you are very paranoid (and it looks like you are ) +1 to driving normally, but avoid launching. Link to comment Share on other sites More sharing options...
sportwagon Posted February 3, 2009 Author Share Posted February 3, 2009 well, it's snowing out anyway... so it's probably a good idea to not play around in the snow! I would normally do some parking lot laps on the ride home later tonight! But seeing how this clutch has ~50 miles on it... I'll behave myself! Link to comment Share on other sites More sharing options...
sportwagon Posted February 3, 2009 Author Share Posted February 3, 2009 But, really my questions about "clutch break-in" are more common sense answers... The real questions I'm posing are: Is it OK for me to continue to drive "normally" during the break-in period with a STGE 1 base map and STGE 2 real time map? OR Should I change the real time map back to STGE 1 for the remainder of the breakin? OR Would it be best to go STAGE 2 base/real time Maps immediately? Thanks... Link to comment Share on other sites More sharing options...
Beanboy Posted February 3, 2009 Share Posted February 3, 2009 Really doesn't matter much when the clutch is fully engaged. Maybe if you had 500WHP and stock clutch... What is important is treating it right from a stop. New clutch/flywheel and then miles on dyno tuning a 20G, everything is fine. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
j255c Posted February 3, 2009 Share Posted February 3, 2009 yeah i road tuned my 20g w/ meth about 400 miles onto the clutch no issues. Just dont launch it. Stop and go traffic actually helps break it in quicker. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
sportwagon Posted February 4, 2009 Author Share Posted February 4, 2009 good to know about the stop and go! thanks! Link to comment Share on other sites More sharing options...
