instantfury Posted March 8, 2012 Share Posted March 8, 2012 car has 185k. I think i did this right. 2k in third gear start until redline then stop. How bad is it?romraiderlog_20120308_170851.csvromraiderlog_20120308_171912.csv Link to comment Share on other sites More sharing options...
instantfury Posted March 8, 2012 Author Share Posted March 8, 2012 i did a learning view as well. Link to comment Share on other sites More sharing options...
iNVAR Posted March 9, 2012 Share Posted March 9, 2012 It's BAD. Your IAM is at 0. You have something wrong. Looks like a possible vacuum/intake leak based on fuel trims. I didn't even bother looking at your logs. Stay off the throttle until you fix it. edit: Looked at your log. First log is useless. Second log shows you not even making 8psi. Your car is in limp mode. Are you sure there are no check engine codes on? Double check with LV also, with the box checked, and reconnect. Link to comment Share on other sites More sharing options...
Th3Franz Posted March 9, 2012 Share Posted March 9, 2012 He's running spring pressure, but the 10 degrees of pulled timing right at the CL/OL transition has me concerned. If something is rattling horribly maybe it's tripping the knock sensor. I've NEVER seen a car hit an IAM of 0 before. not good -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
instantfury Posted March 9, 2012 Author Share Posted March 9, 2012 damn. i do have some front suspension problems that need to be addressed. ball joints and tie rod boots do have cracks in them. the heat shield on the header, i think, is rusty and a little loose. when i drive down the road on uneven pavement there are some pinging and popping noises from the suspension. I did hook it up to full boost before i did the pull, so i'll put it back on spring pressure until we meet up next week franz. No check engine light was thrown during the pull. With mild acceleration there is a hesitation around 2-2.5k rpms after i flashed the tune. sometimes, not always though. I'll go do another learning view real quick. I knew i should have just waited until we met up... fudge. vid of pull attached as well [ame=http://www.youtube.com/watch?v=WdlSEVZgsI0]VID_20120308_170648.m4v - YouTube[/ame] Link to comment Share on other sites More sharing options...
instantfury Posted March 9, 2012 Author Share Posted March 9, 2012 you can kind of hear the noises i was referring to in the video. it is much louder in person, and sometimes i can feel it in the pedals if the pavement is particularly broken Link to comment Share on other sites More sharing options...
instantfury Posted March 9, 2012 Author Share Posted March 9, 2012 Le bump Link to comment Share on other sites More sharing options...
iNVAR Posted March 9, 2012 Share Posted March 9, 2012 Whatever that noise is, you better get it fixed. In the meantime, stop driving the car around. You need to provide some background for what you are doing and did to your car. Why are you running spring pressure? What tune is that? etc.etc.... Link to comment Share on other sites More sharing options...
instantfury Posted March 9, 2012 Author Share Posted March 9, 2012 I had a clogged up pipe cat that made me think the turbo was bad. Got a bnr16g because it was less expensive than a brand new vf40 and then figured out that it was the cat that was the problem. Gutted the up pipe and then started running spring pressure right away because people said I would blow my engine if i didn't have it tuned. Got the tune last week borrowed Franz tactrix and flashshed yesterday. According to Shamar it's a stage 3 oem fueling tune. Thanks for looking. Link to comment Share on other sites More sharing options...
iNVAR Posted March 9, 2012 Share Posted March 9, 2012 Okay, I think I would start with finding out what that noise is and taking care of it because I think it's making your knock sensor go crazy and pull tons of timing. You're at IAM 0 (which is HORRIBLE) AND you still have 10* pulled. So yeah, I agree with franz about something loose. Link to comment Share on other sites More sharing options...
instantfury Posted March 9, 2012 Author Share Posted March 9, 2012 Thank you both for your help. Link to comment Share on other sites More sharing options...
instantfury Posted March 9, 2012 Author Share Posted March 9, 2012 so while driving around for work(i know i really shouldn't but i have to) i noticed the hesitation went away. i just did a learning view and huh? the road i did the pull on yesterday wasn't exactly in the best condition so maybe that coupled with my suspension problems falsely triggered the excessive knock? Link to comment Share on other sites More sharing options...
instantfury Posted March 10, 2012 Author Share Posted March 10, 2012 Suspension has been taken care of. I'll do another pull Monday morning and hopefully it'll look a lot better. Link to comment Share on other sites More sharing options...
iNVAR Posted March 11, 2012 Share Posted March 11, 2012 1) Don't do pulls. If you had a problem with your leg, your doctor wouldn't tell you to sprint a 100m dash to diagnose the issue would he? 2) Reset your ECU. 3) Log the entire drive to/from work, shopping, etc., and stay out of WOT until we're sure it's not an engine related problem. Then pull an LV. Link to comment Share on other sites More sharing options...
instantfury Posted March 11, 2012 Author Share Posted March 11, 2012 Will do. The reset ecu button in learning view is the same as a battery pull, correct? That's gonna be a big file because I'll end up driving at least a hundred and fifty miles or so. I'm a service tech for Konica minolta so I'm driving all day long. Should I pick and choose when to log? To and from with a couple random times throughout the day? Thanks again man. Link to comment Share on other sites More sharing options...
bmx045 Posted March 12, 2012 Share Posted March 12, 2012 the reset button is the same, you just dont loose your radio presets. i wouldn't log for 150 miles. a lv will give us a good idea if the suspension fixed solved the issues. however your fuel trims are CRACK. Link to comment Share on other sites More sharing options...
instantfury Posted March 12, 2012 Author Share Posted March 12, 2012 ahh. well i did log my ride to work and pulled a learning view also. 60 miles or so. up load failed of the log. it was 3.5 mb so i dunno if its too large of a file. lv looked good. Link to comment Share on other sites More sharing options...
bmx045 Posted March 12, 2012 Share Posted March 12, 2012 you need to scale your maf Link to comment Share on other sites More sharing options...
iNVAR Posted March 12, 2012 Share Posted March 12, 2012 that, or you have a small vacuum leak, pronounced at idle. Link to comment Share on other sites More sharing options...
instantfury Posted March 12, 2012 Author Share Posted March 12, 2012 Found the problem. There is a small hole in the intake hose right before it connects to the Turbo. Is there anyway to fix that, or will I have to get a brand new one? Link to comment Share on other sites More sharing options...
bmx045 Posted March 12, 2012 Share Posted March 12, 2012 new one Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 12, 2012 Mega Users Share Posted March 12, 2012 instant how are you stage 3 with stock fueling? "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmx045 Posted March 12, 2012 Share Posted March 12, 2012 vf52 Link to comment Share on other sites More sharing options...
instantfury Posted March 12, 2012 Author Share Posted March 12, 2012 Bnr16g. Shamar said I was so that's what I'm claiming. Right now I'm stage 2.5i though. Link to comment Share on other sites More sharing options...
Th3Franz Posted March 12, 2012 Share Posted March 12, 2012 Yep replace the inlet hose if it's torn. You can probably find a stock one for real cheap but I like the silicone ones and run a Perrin on my car. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
