instantfury Posted January 6, 2009 Share Posted January 6, 2009 sometimes at idle i get this burnt plastic smell. checked under the hood, no visible smoke or anything. it might be i just ran over a plastic bag, but its been there for a week. any clues? Link to comment Share on other sites More sharing options...
ih8vtec13 Posted January 6, 2009 Share Posted January 6, 2009 check your headlight housing, I had an issue but it went away and a headlight blew shortly after. When i changed the bulb i noticed that the plug on passengers side was kind fo crispy and flaked away. It still works but i am gonna get it fixed next trip to the dealer Link to comment Share on other sites More sharing options...
instantfury Posted January 8, 2009 Author Share Posted January 8, 2009 i do run my headlights all the time. i turned em off and viola no smell. thanks Link to comment Share on other sites More sharing options...
autotech Posted January 10, 2009 Share Posted January 10, 2009 maybe you ran over a plastic bag? and it melted to the exhaust....we see that all the time in my shop Link to comment Share on other sites More sharing options...
instantfury Posted January 10, 2009 Author Share Posted January 10, 2009 how long does it usually stay there? Link to comment Share on other sites More sharing options...
wngan9447 Posted January 12, 2009 Share Posted January 12, 2009 Is the smell from just outside the car, both inside and outside? Is it coming from the vents as well? If so, on fresh air and recirculating? Lots of items come into play. Link to comment Share on other sites More sharing options...
instantfury Posted January 12, 2009 Author Share Posted January 12, 2009 mostly inside, from the vents, and fresh air, recirc usually cuts it off. the lights werent the prob Link to comment Share on other sites More sharing options...
wngan9447 Posted January 13, 2009 Share Posted January 13, 2009 mostly inside, from the vents, and fresh air, recirc usually cuts it off. the lights werent the prob If the smell just showed up, it would mostly be something you ran over like you stated. If it lingers around, i'd look into it more. Good luck. Link to comment Share on other sites More sharing options...
instantfury Posted January 14, 2009 Author Share Posted January 14, 2009 more than likely a bag or something, havent smelled it for a day or so, thanks Link to comment Share on other sites More sharing options...
