brandonGT Posted June 6, 2008 Share Posted June 6, 2008 http://scandepot.net/viewscan.php?pk=4979 http://scandepot.net/viewscan.php?pk=4955 the first link is at 19 psi and the second link is at 18 psi. the car is mainly a weekend/track car and id like to know which tune would be better for the drag strip. 19 psi tune feels MUCH stronger but for some reason i cant seem to beat the 18 psi tune in times. at 18 psi the 50-80 mph is 4.060 seconds and at 19 psi it is 4.233 seconds. can somebody explain to me why the tune that feels much slower is actually faster? 2006 Legacy GT 5EAT 3 in catless turboback catless uppipe AEM intake Perrin Intercooler sea level Link to comment Share on other sites More sharing options...
Infamous1 Posted June 6, 2008 Share Posted June 6, 2008 I was reviewing the logs and was about to say the 18psi tune looks faster, then I read your post. I judge this by the length of the log. I can't plot them so I am guessing the 19 psi map is heating up the air a bit too much. It really seem to be peaking at about 19.5-19.75psi vs 18.5psi (what I run). Your timing is very close on both so that doesn't seem to be the issue. I think you are just running off the efficiency island. And wow your car holds boost well up top! Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 6, 2008 Share Posted June 6, 2008 You should post the csv instead of using scandepot. It's very difficult to manipulate scandepot files. Minimize the stuff that you log. You don't need to log EGT and AFR #1. I would log throttle angle instead of accelerator pedal. Next time log VVT-I. Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 ok just a second fellas ill post the .csv's Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 You should post the csv instead of using scandepot. It's very difficult to manipulate scandepot files. Minimize the stuff that you log. You don't need to log EGT and AFR #1. I would log throttle angle instead of accelerator pedal. Next time log VVT-I. to add to what i was saying earlier, i just dont see how i am getting faster times on the tune that feels SOOO much slower. with the 19+ psi map, i can spin all 4 tires in 1st gear. and at 18 psi, ive never spun the tires. also, at 19 psi when i punch it from a 50 roll, it feels so fast and smooth like an airplane take-off, almost feels as if i have something bigger than a vf40 under the hood. Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 i cant seem to upload the .csv's. when i save them as a .pdf to upload, it becomes too large of a file to upload. Link to comment Share on other sites More sharing options...
ShadowImg Posted June 6, 2008 Share Posted June 6, 2008 csvs are just text files, you should be able to just attach them as is, or rename them to .txt Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 6, 2008 Share Posted June 6, 2008 to add to what i was saying earlier, i just dont see how i am getting faster times on the tune that feels SOOO much slower. with the 19+ psi map, i can spin all 4 tires in 1st gear. and at 18 psi, ive never spun the tires. also, at 19 psi when i punch it from a 50 roll, it feels so fast and smooth like an airplane take-off, almost feels as if i have something bigger than a vf40 under the hood. None of this has anything to do with your 50-80 mph time. Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 None of this has anything to do with your 50-80 mph time. yea i know but im just tryin to figure out how the tune that feels so much quicker is in fact the slower of the two. i think what i might ultimately do is pay 90$ and put the car on the car on the dyno to see which tune makes more power. its too bad that log interpolation software doesnt work for 5eat's Link to comment Share on other sites More sharing options...
Infamous1 Posted June 6, 2008 Share Posted June 6, 2008 yea i know but im just tryin to figure out how the tune that feels so much quicker is in fact the slower of the two. i think what i might ultimately do is pay 90$ and put the car on the car on the dyno to see which tune makes more power. its too bad that log interpolation software doesnt work for 5eat's Try to start your logs at a different point, say 3500rpms in 3rd and compare. When running a pull from say 2k or so the turbo will genereate much more heat and hurt the times and power output as well. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 6, 2008 Share Posted June 6, 2008 yea i know but im just tryin to figure out how the tune that feels so much quicker is in fact the slower of the two. i think what i might ultimately do is pay 90$ and put the car on the car on the dyno to see which tune makes more power. its too bad that log interpolation software doesnt work for 5eat's What do you mean? I thought I fixed it. If there's a bug, let me know. Just log rpm and mph and post your logs. RENAME the extension from .csv to .pdf and then post it. Then in your post, state that it is actually a .csv file. It won't give you correct ABSOLUTE values but it will give you the ability to compare tunes on the same car with the same setup. In any case, if you look at dyno plots, etc..., they are all different depending upon the dyno and settings (for loadable dynos). Dynos are only a tool used for comparisons. Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 What do you mean? I thought I fixed it. If there's a bug, let me know. Just log rpm and mph and post your logs. RENAME the extension from .csv to .pdf and then post it. Then in your post, state that it is actually a .csv file. It won't give you correct ABSOLUTE values but it will give you the ability to compare tunes on the same car with the same setup. In any case, if you look at dyno plots, etc..., they are all different depending upon the dyno and settings (for loadable dynos). Dynos are only a tool used for comparisons. yea i loaded my .csv file on the interpolation software, got the data on the accel tab for rpm and mph and when i calculated acceleration this is what i got: Max 253 hp @ 90 rpm Max 20963 tq @ 40 rpm and none of the graphs showed up on the acceleration charts, hp charts, etc. Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 What do you mean? I thought I fixed it. If there's a bug, let me know. Just log rpm and mph and post your logs. RENAME the extension from .csv to .pdf and then post it. Then in your post, state that it is actually a .csv file. It won't give you correct ABSOLUTE values but it will give you the ability to compare tunes on the same car with the same setup. In any case, if you look at dyno plots, etc..., they are all different depending upon the dyno and settings (for loadable dynos). Dynos are only a tool used for comparisons. there we go, finally got it. make sure to save as a .csv18 psi.pdf19 psi.pdf Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 6, 2008 Share Posted June 6, 2008 That spreadsheet has kind of gotten out of hand. It's easy to make a mistake. Post up your csv files and I'll run it through. Did you log time in milliseconds? Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 That spreadsheet has kind of gotten out of hand. It's easy to make a mistake. Post up your csv files and I'll run it through. Did you log time in milliseconds? yes Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 6, 2008 Share Posted June 6, 2008 there we go, finally got it. make sure to save as a .csv Those are Yahoo html files. Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 Those are Yahoo html files. i cant seem to get it. all im doing is sending an e-mail to myself with the logs attached, then through e-mail i am saving it as a .pdf then i am uploading it on legacygt.com18 psi.pdf19 psi.pdf Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 6, 2008 Share Posted June 6, 2008 I'm getting this. [font=Arial][size=2]<html>[/size][/font][font=Arial][size=2]<!-- Copyright 2007 Yahoo! Inc. All rights reserved. -->[/size][/font][font=Arial][size=2]<head>[/size][/font][font=Arial][size=2]<meta http-equiv="Expires" content="Sat[/size][/font][font=Arial][size=2]<meta http-equiv="Content-type" content="text/html;charset=utf-8" />[/size][/font][font=Arial][size=2]<title>Yahoo! Mail</title>[/size][/font][font=Arial][size=2]<script language="JavaScript">[/size][/font][font=Arial][size=2]window.onerror = function(sMsg[/size][/font][font=Arial][size=2]var str[/size][/font][font=Arial][size=2]var brows="otherBrows"[/size][/font][font=Arial][size=2]if (ua.indexOf('msie')!=-1){brows='ie';}[/size][/font][font=Arial][size=2]else if (ua.indexOf('safari')!=-1){brows='saf';}[/size][/font][font=Arial][size=2]else if (ua.indexOf('firefox')!= -1){brows='ff';}[/size][/font][font=Arial][size=2]if (ua.indexOf('mac')!=-1){plat='mac';}[/size][/font][font=Arial][size=2]else if (ua.indexOf('windows')!= -1){plat='win';}[/size][/font][font=Arial][size=2]str = ["ScriptError"[/size][/font][font=Arial][size=2]RS = document.createElement("IMG");[/size][/font][font=Arial][size=2]RS.onload = function(){ eval( "'onload'; this.onload = null; this.onerror = null;" ) };[/size][/font][font=Arial][size=2]RS.onerror = function(){ eval( "'onerror'; this.onload = null; this.onerror = null;" ) };[/size][/font][font=Arial][size=2]RS.src = "rs?log=ScriptError;" + str.join("-");[/size][/font][font=Arial][size=2]window.onerror = null;[/size][/font][font=Arial][size=2]return false;[/size][/font][font=Arial][size=2]}[/size][/font] Just rename the original .csv file that was output from romraider. Don't edit or alter it. Just rename the extension. Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 I'm getting this. [font=Arial][size=2]<html>[/size][/font][font=Arial][size=2]<!-- Copyright 2007 Yahoo! Inc. All rights reserved. -->[/size][/font][font=Arial][size=2]<head>[/size][/font][font=Arial][size=2]<meta http-equiv="Expires" content="Sat[/size][/font][font=Arial][size=2]<meta http-equiv="Content-type" content="text/html;charset=utf-8" />[/size][/font][font=Arial][size=2]<title>Yahoo! Mail</title>[/size][/font][font=Arial][size=2]<script language="JavaScript">[/size][/font][font=Arial][size=2]window.onerror = function(sMsg[/size][/font][font=Arial][size=2]var str[/size][/font][font=Arial][size=2]var brows="otherBrows"[/size][/font][font=Arial][size=2]if (ua.indexOf('msie')!=-1){brows='ie';}[/size][/font][font=Arial][size=2]else if (ua.indexOf('safari')!=-1){brows='saf';}[/size][/font][font=Arial][size=2]else if (ua.indexOf('firefox')!= -1){brows='ff';}[/size][/font][font=Arial][size=2]if (ua.indexOf('mac')!=-1){plat='mac';}[/size][/font][font=Arial][size=2]else if (ua.indexOf('windows')!= -1){plat='win';}[/size][/font][font=Arial][size=2]str = ["ScriptError"[/size][/font][font=Arial][size=2]RS = document.createElement("IMG");[/size][/font][font=Arial][size=2]RS.onload = function(){ eval( "'onload'; this.onload = null; this.onerror = null;" ) };[/size][/font][font=Arial][size=2]RS.onerror = function(){ eval( "'onerror'; this.onload = null; this.onerror = null;" ) };[/size][/font][font=Arial][size=2]RS.src = "rs?log=ScriptError;" + str.join("-");[/size][/font][font=Arial][size=2]window.onerror = null;[/size][/font][font=Arial][size=2]return false;[/size][/font][font=Arial][size=2]}[/size][/font] Just rename the original .csv file that was output from romraider. Don't edit or alter it. Just rename the extension. ***Corrected*** that should work, at least it did for me18 psi.pdf19 psi.pdf Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 6, 2008 Share Posted June 6, 2008 Sorry. There was a bug in my modification to the spreadsheet. I updated the acceleration and horsepower calculation but then I stopped there. I forgot to update the torque and the graphs. Here are your logs using the acceleration function. The REFERENCE values are your 18 psi log. You are definitely making more power with your 18 psi tune. It looks like more than just heat soak. To me, it looks like the 19 psi tune may have tried to advance the AVCS above 5200 rpm. I am guessing this because thie other parameters look normal. BTW, the VF40 hotside is too small to have any AVCS above 5200 rpm. http://i141.photobucket.com/albums/r69/mickeyd2005/untitled-21.jpg Link to comment Share on other sites More sharing options...
Infamous1 Posted June 6, 2008 Share Posted June 6, 2008 Also to about 4200-4300rpms you are making a bit more torque at 19psi, this would explain the quicker butt dyno. Link to comment Share on other sites More sharing options...
DrewLGT Posted June 6, 2008 Share Posted June 6, 2008 Max 20963 tq @ 40 rpm and none of the graphs showed up on the acceleration charts, hp charts, etc. thats some impressive torque... :lol: Link to comment Share on other sites More sharing options...
brandonGT Posted June 6, 2008 Author Share Posted June 6, 2008 Also to about 4200-4300rpms you are making a bit more torque at 19psi, this would explain the quicker butt dyno. so i guess i can keep the 19+ psi in the low and mid range, i just need to taper it off more Link to comment Share on other sites More sharing options...
Infamous1 Posted June 6, 2008 Share Posted June 6, 2008 so i guess i can keep the 19+ psi in the low and mid range, i just need to taper it off more Possibly, however over about 5k rpms your MRP is about the same. You may want to log your AVCS to see if it is the same on each map. Link to comment Share on other sites More sharing options...
boostsr20 Posted June 8, 2008 Share Posted June 8, 2008 Sorry. There was a bug in my modification to the spreadsheet. I updated the acceleration and horsepower calculation but then I stopped there. I forgot to update the torque and the graphs. Is your new revision posted up for D/L? Link to comment Share on other sites More sharing options...
