monstorr Posted May 20, 2013 Share Posted May 20, 2013 I can't really find anything online so maybe i can get everyones input, Im planning on getting a catless down and uppipe and can't figure out the differences with each vendor.Like which are good which are bad whatever. Currently the car has a stock uppipe and a cobb dp. Link to comment Share on other sites More sharing options...
chimera Posted May 20, 2013 Share Posted May 20, 2013 I find the reviews section on this forum very helpful for this kind of question http://legacygt.com/reviews/? In regards to differences, most likely just down to design to get better (less restrictive) flow Link to comment Share on other sites More sharing options...
monstorr Posted May 21, 2013 Author Share Posted May 21, 2013 I find the reviews section on this forum very helpful for this kind of question http://legacygt.com/reviews/? In regards to differences, most likely just down to design to get better (less restrictive) flow perfect, thanks!! Link to comment Share on other sites More sharing options...
stuck686 Posted May 21, 2013 Share Posted May 21, 2013 i would go with the grimmspeed upipe. As for dp; cobb perrin and invidia seem to be popular. I have CNT which is cheaper but the fitment and quality is great. Link to comment Share on other sites More sharing options...
compression Posted May 24, 2013 Share Posted May 24, 2013 Up pipes and down pipes are such simple parts, it would take a really bad manufacturer to screw one up. They are all *essentially* the same. I prefer up pipes with flex sections in them, but that's just me. Link to comment Share on other sites More sharing options...
Dujo Posted May 24, 2013 Share Posted May 24, 2013 Keep your Cobb down. There's no significant value to going catless if you already have an aftermarket downpipe. The major restriction has already been removed in going to a full bellmouth design and the Cobb has a high flow cat, which isn't too restrictive. Catless at this point would not gain you more than 5HP and probably closer to 1-2HP. It's not worth the cost and effort to switch. Besides, catted is better for the environment. Now the stock uppipe on the other hand is a problem; the cat is a threat to the turbo. Swap that bugger out. Used sti uppipe is cheapest most reliable option. Search here or nasioc. Other than that, it's personal preference on solid vs flex. I got the Cobb solid catless up and a Cobb catted down for my stage 2 setup. Enjoy! Link to comment Share on other sites More sharing options...
iNVAR Posted May 24, 2013 Share Posted May 24, 2013 I have a feeling OP bought the car used with this stuff on there already. Are you SURE the UP you have on there has a cat in it, or did the previous owner swap it with an STI catless one, or maybe gut it? Most people that have done the DP have also already done the UP. I hope you're tuned. Do some reading on forum, there's plenty of info here. Link to comment Share on other sites More sharing options...
lingling1337 Posted May 24, 2013 Share Posted May 24, 2013 Keep the Cobb, its good. Look for a used up. Link to comment Share on other sites More sharing options...
chimera Posted May 26, 2013 Share Posted May 26, 2013 Are up and/or down pipes needed on a JDM? Or are stock different than USDM and sufficient enough for going to stage 2? From tuners here in NZL none mention up or down pipes for stage 2. Some say only a tune, some say tune + wideband. ??? Link to comment Share on other sites More sharing options...
