troutman Posted January 23, 2011 Share Posted January 23, 2011 I have a 97 outback and have only had it a couple of weeks. I disconnected the battery today to replace the spark plugs. The 4 ways are flashing but I have have no siren or horn flashig. Theyellow tag under the hood says to turn the key tothe run position and push the button near the control module for one second. I CAN NOT FIND THE BUTTON! I've also unlocked the doors like the owners manual says and cannot get the flashers to stop! Link to comment Share on other sites More sharing options...
jamesm113 Posted January 23, 2011 Share Posted January 23, 2011 it's near the drivers door under the dashboard http://www.cars101.com/subaru/codealarmremote1.JPG If you have keyless entry, you can just hit unlock, i believe. Otherwise, you can buy the remote off ebay for ~$20, that's what i ended up doing Link to comment Share on other sites More sharing options...
johnegg Posted January 23, 2011 Share Posted January 23, 2011 put the key in the ignition and turn it to run, just short of start. disconnect the battery. re-connect battery. drive on !! Link to comment Share on other sites More sharing options...
fatboy1214 Posted January 23, 2011 Share Posted January 23, 2011 on mine you have to manually lock all the doors after you disconnect the battery then you rehook it and all the doors unlock and then your all set Link to comment Share on other sites More sharing options...
subikid90 Posted January 23, 2011 Share Posted January 23, 2011 put the key in the ignition and turn it to run, just short of start. disconnect the battery. re-connect battery. drive on !! ^this works everytime. Even on 3rd gens lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
troutman Posted January 23, 2011 Author Share Posted January 23, 2011 I think mine has been messed with. There is no button. I got it to turn off by unlugging two 10 amp fuses in going to the controll module. Next time I'll try some of these other methods. I don't know what the po has done with it or where the keylesss entry thing is. I was thinking as I was laying in the floorboard with a flashlight on my back this has got to be missing a button. I could just see a woman in a dress doing this! Link to comment Share on other sites More sharing options...
