frankbrunke Posted March 20, 2011 Share Posted March 20, 2011 Does anyone know if the tire pressure indicator will go off for over inflation? did a good deal of high way driving, on snows and the tire indicator came on. after the car sat for a few hours and did the same drive, later at night, the gauge did not come back on. the light blinked than stayed on. based on the book it states to have someone look at it, but since it did not come on again, i was just wondering regarding the tire pressure. Link to comment Share on other sites More sharing options...
MrBURTON3.6r Posted March 20, 2011 Share Posted March 20, 2011 I accidentally over inflated my tires and the tire pressure light does come on and flashes as well. All I did was decrease the pressure to a normal level and the light turned off. Link to comment Share on other sites More sharing options...
iambuddylee Posted March 20, 2011 Share Posted March 20, 2011 thats weird, I overinflated mine quite a bit (like 8-10psi over) and no lights came on. Link to comment Share on other sites More sharing options...
frankbrunke Posted March 21, 2011 Author Share Posted March 21, 2011 I have been running the tires a little higher in pressure, than normal. When i checked the tires the average was just a little bit over 50 lbs. I reduced the cold pressure and I will keep an eye on it. Link to comment Share on other sites More sharing options...
MrBURTON3.6r Posted March 22, 2011 Share Posted March 22, 2011 Yeah, when I had the tire pressure light blink and stay lit I had my tire pressure around 51-52. Link to comment Share on other sites More sharing options...
underground000 Posted March 22, 2011 Share Posted March 22, 2011 Yea the TPMS comes on if the tire is over inflated, comes on over 50psi - 50psi the max inflation psi on most tires 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Pedrosk Posted January 24, 2017 Share Posted January 24, 2017 I have winter tires on they are inflated at 36psi. The sticker on the door states front 32psi back 30. Would this little over inflation triger the "flat tire" light? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted January 24, 2017 Share Posted January 24, 2017 I have winter tires on they are inflated at 36psi. The sticker on the door states front 32psi back 30. Would this little over inflation triger the "flat tire" light? No, 36 is perfectly fine. Link to comment Share on other sites More sharing options...
GTEASER Posted January 24, 2017 Share Posted January 24, 2017 I run my tires 35 to 36 all the time. On track days I run them around 40. Never had a TPMS light come on except for low pressure, usually around 22 IIRC. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Pedrosk Posted January 25, 2017 Share Posted January 25, 2017 Thanks. These are brand new sensors installed in my winter tires by Firestone. So initially there was no indicator on the dashboard. Next morning at start it blinked and than stayed on. It bothered me so I got one of those external sensors on eBay and keep my eyes on the pressure, how ever the light blinks and stays on after start up and short drive. Makes me wonder why this did not happen when I left Firestone, but since next morning it behaves like that. All tires are above 30PSI. This is on my Subaru Crostrek XV 2013. Any tips? Ed Link to comment Share on other sites More sharing options...
Rutchard Posted January 25, 2017 Share Posted January 25, 2017 Maybe Firestone didn't sync the new sensors properly Link to comment Share on other sites More sharing options...
capttris Posted January 25, 2017 Share Posted January 25, 2017 you guys brought up a good discussion on over-inflating snow tires. I got my 1st set of the Michelin X-Ice XI3 3 winters ago and they always seem "bulgy" and have the look of low air pressure when at 22/33 PSI, so I have been running them about 36-38PSI. They "look" better and I haven't noticed any difference in tread wear, especially in the center of the tires. What have you guys been seeing and doing? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted January 26, 2017 Share Posted January 26, 2017 Maybe Firestone didn't sync the new sensors properly ^^^ What he said. Link to comment Share on other sites More sharing options...
dgoodhue Posted January 26, 2017 Share Posted January 26, 2017 you guys brought up a good discussion on over-inflating snow tires. I got my 1st set of the Michelin X-Ice XI3 3 winters ago and they always seem "bulgy" and have the look of low air pressure when at 22/33 PSI, so I have been running them about 36-38PSI. They "look" better and I haven't noticed any difference in tread wear, especially in the center of the tires. What have you guys been seeing and doing? I had a contract job that was a long distance, so I bought a Chevy Prizm and went through a little phase of making changes to my car and hypermiling. I got bored of the driving techniques real quick (3 weeks). One thing that hypermiling forum recommended right off the bat is to raise your pressure to the maximum sidewall pressure some even advocated for 60psi even if the tires weren't rated for that. I went for the max sidewall pressure which in my case was 51psi. The care rode like shit, but the tire wear didn't noticeable wear out the middle of the tire, if anything the front tires seemed to wear more evenly. I put about 80k miles which most of it was done with elevated tire pressures and I wore out one of set of tires. The car had relatively thin tire (185)mm, so maybe that played a roll. My ex-wife had Toyotay Highland with 225mm width SUV tires and I raised those to 44psi (side wall) and I didn't notice a difference with the tire wear either. The big side wall barely made a difference in the ride quality. I run the factory tire 33/32 pressure in my Legacy, so I can't give you any further experiences. Link to comment Share on other sites More sharing options...
