94legacy22 Posted June 18, 2013 Share Posted June 18, 2013 I'm having a wierd issue with my subbie, when i turn to position 2 and dont start the car. the injectors and plugs start randomly firing. causing it to flood out. i have unplugged both the cam sensor and the crank sensor and it still does it. also the tach will jump. power and ground to the ecu is ok. i'm thinking it might have a bad ecu... any other thoughts? 1994 2.2 n/a 5speed awd. Link to comment Share on other sites More sharing options...
94legacy22 Posted June 18, 2013 Author Share Posted June 18, 2013 note it starts and runs fine otherwise. Link to comment Share on other sites More sharing options...
snederhiser Posted June 18, 2013 Share Posted June 18, 2013 Hello; Check the ignition switch, ECU relay, fuel pump relay, and Maf sensor output voltage. Perhaps check the voltage on the O2 sensor. Something is triggering the ECU to fire the injectors. My ECU was faulty causing the car to hesistate. I replaced the filter capacitors on the circuit board and fixed my problem. When these go, the computer will keep resetting itself. Steven. Link to comment Share on other sites More sharing options...
94legacy22 Posted June 20, 2013 Author Share Posted June 20, 2013 ok cool i will thanks, i have all ready cleaned the maf. and that seems to be ok. the only code i have is for the purge valve. Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 21, 2013 Share Posted June 21, 2013 Purge control solenoid valves crap out. You can try a junkyard replacement but in my experience they are bad. A new one will save you the headache. They are $120 new from the dealer. Iirc there is a Geo replacement that is much cheaper and works the same. Search around here. I think mnstrmech figured it out. Edit: from what I have gathered the only problem with a bad purge valve is the cel. Otherwise it usually doesn't have an effect on mpg, or the performance. I replaced mine because the cel bothered me. Link to comment Share on other sites More sharing options...
94legacy22 Posted June 22, 2013 Author Share Posted June 22, 2013 yeah the cel is annoying. but that's not the issue. prob gonna take out the ecu this weekend and open it up and look inside for issues Link to comment Share on other sites More sharing options...
snederhiser Posted June 22, 2013 Share Posted June 22, 2013 Hello; You will be dealing with four filter (electrolytic) capacitors, two are 100mf 50volts, one is a 47mf 50volt, and one 33mf 50volt. Use a low wattage soldering iron, not a soldering gun. Make sure the polarity is correct when installing these. Be sure to use a good rosin core solder, Steven. Link to comment Share on other sites More sharing options...
94legacy22 Posted June 22, 2013 Author Share Posted June 22, 2013 i have a local guy that does circuit board repairs that i will use. i know i will mess it up lol Link to comment Share on other sites More sharing options...
