evanisonfire Posted August 17, 2012 Share Posted August 17, 2012 so ive decided to get a new set of rims for my car. ive decided to go with the XXR 530, i was thinking of getting the 18" x 8.75" +35. my question is will this rims rize rit with OEM ride height? also what is the widest rubber i would be able to put without clearance issues? Link to comment Share on other sites More sharing options...
Drift Motion Posted August 17, 2012 Share Posted August 17, 2012 yes, and probably 245s Link to comment Share on other sites More sharing options...
Heedz Posted August 17, 2012 Share Posted August 17, 2012 Tire diameter can't be larger than 25.2" 235/40 would be a better bet. Link to comment Share on other sites More sharing options...
Dbl_D718 Posted August 18, 2012 Share Posted August 18, 2012 245/40 tires will rub, probably even with rolled rear fenders (mine do). With an 8.75" width and +35 offset, 235 tires might rub too. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
iNVAR Posted August 18, 2012 Share Posted August 18, 2012 no mention what model or year of vehicle.... i'm not sure if you guys should be giving him answers... Link to comment Share on other sites More sharing options...
charlie_sheen Posted August 19, 2012 Share Posted August 19, 2012 ill be getting the same setup soon. im going to run 225-40's with mild camber so i dont have to worry about rubbing Link to comment Share on other sites More sharing options...
evanisonfire Posted August 19, 2012 Author Share Posted August 19, 2012 05 legacy gt. And cool thanks guys, from what I researched its sounding like 225/40 is the best size to go to avoid issues, especially since I one day plan to slightly lower the car Link to comment Share on other sites More sharing options...
iNVAR Posted August 19, 2012 Share Posted August 19, 2012 check this. it's as thorough as it gets. http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.html Link to comment Share on other sites More sharing options...
Drift Motion Posted August 20, 2012 Share Posted August 20, 2012 my 255s almost fits on my 9 +38 I'm sure if 235s and even 245s should fit... Link to comment Share on other sites More sharing options...
Dbl_D718 Posted August 21, 2012 Share Posted August 21, 2012 [threadjack]^^ Suspension/fender mods? I've got 18x8.5 +45 with 245/40 tires and rolled fenders and mine still rub with rear seat passengers.[\threadjack] MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
Drift Motion Posted August 21, 2012 Share Posted August 21, 2012 it'll more depend on the alignment and ride height if I raise up my car another 1/4 to 1/2 inch, that should eliminate the rubbing fenders are all rolled, and coils Link to comment Share on other sites More sharing options...
Heedz Posted August 21, 2012 Share Posted August 21, 2012 If you have coils you have no worries about clearing OEM strut housings. 225/40s will clear with a ton of space, I have 18x8.5 +45 on konis + swifts -1.5 front and -1.0 rear camber. @Dbl_D718 what suspension? if you're on coils its either too low, over weight capacity, too soft of a setting, or.... maybe a bad strut? Link to comment Share on other sites More sharing options...
Dbl_D718 Posted August 21, 2012 Share Posted August 21, 2012 I'm on the factory spec.B suspension. My guess is the rubbing is because of saggy-butt syndrome. I've got the rear camber kit ordered and I'll try -1.0* of camber until next spring when I can afford new struts/springs. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
lgkahn Posted August 22, 2012 Share Posted August 22, 2012 depends what car too. i am on a 2010 lgt and 245 40 18 on works 8.5 rims dont rub at all Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted August 22, 2012 I Donated Share Posted August 22, 2012 245 on 8" works all day for autocrossers, OP could definitely get away with it on his 8.75" wheels. Link to comment Share on other sites More sharing options...
.blackgt. Posted August 28, 2012 Share Posted August 28, 2012 I am almost certain that your choice of 530's will not fit with the stock spring/strut combo installed. I was telling myself "thank god I put these coilovers on before I put these wheels on" mainly because there was no room in the wheel well. I think there are websites out there that can show you if it will have clearance issues or not. I would let you put one of my wheels on if you were local. South Florida by any chance? Link to comment Share on other sites More sharing options...
.blackgt. Posted August 28, 2012 Share Posted August 28, 2012 As for rubber, I'm running 235/40 and I am pretty low I guess. Had to roll and pull fenders. IF the wheels actually do fit with stock suspension, I think you should be fine for a pretty meaty tire since suspension travel won't be your enemy. It will look pretty weird if you ask me. They are pretty wide, and before I pulled the fronts, they stuck out quite a bit. Link to comment Share on other sites More sharing options...
