jk_22 Posted July 11, 2012 Share Posted July 11, 2012 Hi I have had several mechanics and i have received several different diagnoses and I don't want to spend $200 to find out i have a $4000 fix. Problem: When I go around a sharp corner under 10mph, i get a jerking noise/feel and it seems like its coming from the front end. Its not clicking. Several ideas were: transfer clutch is going bad, whole differential needs be replaced, cv joints (which made me laugh a little). Anywho, because you can't diagnose the problem without opening it up, its expensive even to get someone to look at it. One guy suggested I put a fuse in AWD spot, which I cannot find. Then after further investigation my findings suggest this is a bad idea because it end up wearing on the tranny. To be honest I have been driving this car like this for over a year now, I take wide turns and try not to get it to jerk. I wanted to fix it, thinking the upper price was $1200, now that I have heard $4000 I am like wtf should I do? Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 11, 2012 Share Posted July 11, 2012 Try posting your problem on legacy central bbs as well. There is only so much help that you can get on this site for first gens: http://bbs.legacycentral.org/index.php The guys on that site know everything about first gens. I'm not saying that you can't get good info on this site, but if you have a first gen joining that forum is essential. Link to comment Share on other sites More sharing options...
subaruguy509 Posted July 11, 2012 Share Posted July 11, 2012 I agree. I am on that one too... Link to comment Share on other sites More sharing options...
Legacy Wagon Posted July 11, 2012 Share Posted July 11, 2012 It's an Auto, I'm guessing. The FWD fuse slot is under your hood near the passenger side strut tower. If the torque binding goes away when you put the fuse in that's one thing. Do you drive with different size tires? Or have a big tread depth difference between front/rear? Try finding someone that has all the same tread depth on tires for a Legacy and throw them on the car and see if it settles down a little. The bummer is that they may be right about your front diff. The better thing is that you can change it by yourself and save $3700 as you should be able to get a front diff for probably less than $300 would be my guess. Either way, look up Duty C Solenoid and it should give you a start on what to look for. Let us know some more info about the car. Link to comment Share on other sites More sharing options...
legacyssturbofreak Posted July 18, 2012 Share Posted July 18, 2012 hate to say it, but if its auto, your center diff is toast. i had an outback recently with same problem. Link to comment Share on other sites More sharing options...
Wicked Posted July 18, 2012 Share Posted July 18, 2012 hate to say it, but if its auto, your center diff is toast. i had an outback recently with same problem. That sounds like your issue. Had the same thing with my '96 Impreza (4eat). Drove me nuts so I had a whole new (74K) tranny installed. Link to comment Share on other sites More sharing options...
