fly_navy Posted April 14, 2013 Share Posted April 14, 2013 I recently changed my plugs with stock replacement iridiums and everything seems peachy. I torqued them to the proper spec, coil packs seated properly, etc and the car starts and runs fine. There are no codes, misfires, or any lack of power (if anything it pulls harder). After an ECU reset however when coming to a stop and depressing the clutch pedal the car will literally drop rev's and die, no previous symptoms and it will start back up and drive away fine. Its happened a few times now after I had to pull the battery or reset via AP. The car is running an old protune from 2007 and has a list of mods. Is the car simply readjusting fuel trims or did I screw up my plug install? Any insight would be much appreciated. Link to comment Share on other sites More sharing options...
Hemingway Posted April 14, 2013 Share Posted April 14, 2013 All the vacuum lines plugged in? Any loose or cracked? Link to comment Share on other sites More sharing options...
urfsin Posted April 14, 2013 Share Posted April 14, 2013 Same thing happened to me after changing the clutch (My battery was out of the car for awhile) The ECU just needs to "re-learn" how to idle. Give it a few start / stop cycles and you should be fine. Slide It Sideways Link to comment Share on other sites More sharing options...
fly_navy Posted April 15, 2013 Author Share Posted April 15, 2013 All the hoses and lines have good connections and are in great shape. Take some datalogs and maybe have someone take a look? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted April 15, 2013 Share Posted April 15, 2013 How long have you driven it since the reset? As mentioned, it does take a while to settle in. Link to comment Share on other sites More sharing options...
cmpequeno Posted April 15, 2013 Share Posted April 15, 2013 PCV valve? Neutral Safety Switch? I read that pcv valve sometimes causes rough idle and stalls the car. On my 02 obs when I was coming to a stop and press the clutch pedal the car would shut down, it was the neutral safety swicth. On my wife's 03 outback we were told it was the idle air control valve but we just cleaned the plugs and the valve and it's ok for now. Link to comment Share on other sites More sharing options...
rob-2 Posted April 15, 2013 Share Posted April 15, 2013 Are you sure you got the right plugs? Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted April 15, 2013 Share Posted April 15, 2013 Id put money on ecu needing to re-learn idle and such, especially if plugs were right and there are no loose connections Link to comment Share on other sites More sharing options...
StoplightAssassin Posted April 15, 2013 Share Posted April 15, 2013 Did it once to me when I switched plugs too. Also hit fuel cut once. If it keeps doing it, you'll have to pull the plugs and check the gaps. Link to comment Share on other sites More sharing options...
fly_navy Posted April 16, 2013 Author Share Posted April 16, 2013 Are you sure you got the right plugs? Pretty sure. I'm running the NGK-ILFR6B, exact ones I pulled out of the car. How long have you driven it since the reset? As mentioned, it does take a while to settle in. I've only been driving it briefly for the past few days. I'll have to report back once more time elapses. It just seems strange because before I changed the plugs if I reset the ECU I never had this problem. Why does the idle take a while to settle in? Shouldn't the reset put the vehicle back to the flashed map parameters where idle should have been fine during the original tune? Link to comment Share on other sites More sharing options...
Hemingway Posted April 16, 2013 Share Posted April 16, 2013 FYI. Out of curiosity, I went to NGK's home page and looked up your car. It listed OE Laser Iridium, SILFR6A, 7913, 0.030, as the OE replacement. Don't know if there is a significant difference between yours and the 6A's listed by NGK. *shrugs* Link to comment Share on other sites More sharing options...
StoplightAssassin Posted April 16, 2013 Share Posted April 16, 2013 Pretty sure. I'm running the NGK-ILFR6B, exact ones I pulled out of the car. Those are not the OEM plugs These are: FYI. Out of curiosity, I went to NGK's home page and looked up your car. It listed OE Laser Iridium, SILFR6A, 7913, 0.030, as the OE replacement. Link to comment Share on other sites More sharing options...
fly_navy Posted April 16, 2013 Author Share Posted April 16, 2013 Looks like you are correct. I actually pulled out SILFR6A's. The manual reports the ILFR6B as the replacements but clearly the stock plugs are the 6A. The plugs seem nearly identical. I'll swap them out if the problem continues *sigh* Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 16, 2013 Moderators Share Posted April 16, 2013 Did you check the gap on the plugs you installed? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
fly_navy Posted April 19, 2013 Author Share Posted April 19, 2013 I believe you all were right, the car just had to "relearn" how to idle thanks for the help! I haven't had any problems for the last two days. Out of curiosity, would a stock vehicle have to relearn how to idle if it were reset or do the mods have a direct impact? Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted April 19, 2013 Share Posted April 19, 2013 A stock vehicle would need to relearn for proper idle as well. Tits mcgee Link to comment Share on other sites More sharing options...
