tytek Posted July 15, 2012 Share Posted July 15, 2012 My car recently started running worse and is not hitting target boost. I checked for boost leaks and did not find any. After doing some logging, it appears that my throttle does not go to 100% when I am WOT under load. It does show throttle position at 100% when revving in neutral. I have gone WOT on the attached log a few times, but it does not show it. The car boosts to under 16psi but is not pulling. Throttle position hardly ever goes above 60%. Could it be an mechanical/electrical issue with the throttle body itself? Or am I having problems elsewhere that manifest themselves in such way? Max target boost is 17.5psi, but I never hit it... This is Cobb Stg2 HWG map. It is a 2011 LGT with a gutted dp and magnaflow cbe. Any ideas on what might be wrong here? TIA!datalog2_small.csv Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted July 15, 2012 Share Posted July 15, 2012 Can you redo your log? Your file looks like the matrix if I scroll fast enough. Link to comment Share on other sites More sharing options...
tytek Posted July 15, 2012 Author Share Posted July 15, 2012 I attached the original log that is not corrupted to the original post. And I also attached another log to this one. Please share your thoughts. Thanks!datalog2_small.csv Link to comment Share on other sites More sharing options...
tytek Posted July 17, 2012 Author Share Posted July 17, 2012 Nothing y'all? Link to comment Share on other sites More sharing options...
iNVAR Posted July 17, 2012 Share Posted July 17, 2012 Your car's DAM is 0.69. Your car is limping for safety reasons due to tons of knock. Hardware Requirements: Stage2 - Otherwise stock vehicle with an aftermarket highflow downpipe WITH catalytic converter, stock or aftermarket catback exhaust, STOCK INTAKE SYSTEM and STOCK INTAKE FILTER ONLY. The addition of any other hardware may make the vehicle perform poorly.You have a gutted DP. I don't know how the 2011s are but the 2005's stock DP is VERY restrictive even being gutted due to the flat plate at the wastegate exit. Also, if you're using the 93 octane map, back off to 91. Link to comment Share on other sites More sharing options...
CL21376 Posted July 17, 2012 Share Posted July 17, 2012 I think you're the first 5th gen guy to gut the stock downpipe. Why are you running the HWG map? Did you try the base stage 2 map and get the same results? Link to comment Share on other sites More sharing options...
eckseleven Posted July 17, 2012 Share Posted July 17, 2012 Time for a protune / etune! Link to comment Share on other sites More sharing options...
tytek Posted July 18, 2012 Author Share Posted July 18, 2012 I have a catted invidia dp on the way. The interesting thing is that the car ran fine with the gutted stock dp, until I put the magnaflow cbe on. Not sure what to think of it, maybe it was coincidence. But will go to a 91oct map and see if things improve. Can you also look at datalog2? Any idea why throttle position would not reach 100%? It limp mode causing it? Will do a log or two with stage 0 and stage 1 as well for comparison. Thanks for the suggestions thus far. And yes, I have considered a protune and will get it once the exhaust is proper. Link to comment Share on other sites More sharing options...
iNVAR Posted July 18, 2012 Share Posted July 18, 2012 For your next log, please remove AF Learning #1, Dynamic Advance, MAF volt. Also, I believe the parameter you want to log isn't Throttle Pos. It should be Throttle Opening Angle. Link to comment Share on other sites More sharing options...
tytek Posted July 18, 2012 Author Share Posted July 18, 2012 For your next log, please remove AF Learning #1, Dynamic Advance, MAF volt. Also, I believe the parameter you want to log isn't Throttle Pos. It should be Throttle Opening Angle. Will do. Thanks! Link to comment Share on other sites More sharing options...
tytek Posted July 20, 2012 Author Share Posted July 20, 2012 Reflashed to stg1 91ct, to see how things would change. Had a very brief drive and just ended up logging basic parameters (same as previous log). Logs from the drive there and back are attached. Thoughts?datalog4.csvdatalog3.csv Link to comment Share on other sites More sharing options...
