Hugo L. Posted April 28, 2012 Share Posted April 28, 2012 Just had my STi brake booster/master cylinder installed, and now when I accelerate hard, I can hear a «new» sound coming from where the booster is, kinda like a «pssssshhhhhhhhhhh» that's not the same as the turbo or blow off valve. The shop said they didn't need the check valve that's referred to in the master cylinder walkthrough on here. Could it be it? Link to comment Share on other sites More sharing options...
sheppo9 Posted May 1, 2012 Share Posted May 1, 2012 There's a valve in the soft rubber hose from the manifold to the booster - they fail every now then, but is not super common or anything. Link to comment Share on other sites More sharing options...
compsurge Posted May 1, 2012 Share Posted May 1, 2012 Can this be indicated with A/F Learning #1 being large? I am curious about the check valve as well. I thought it was the piece that mates the hose to the booster (the nipple). Link to comment Share on other sites More sharing options...
jamal Posted May 1, 2012 Share Posted May 1, 2012 the brake booster operates on vacuum. the check valve prevents it from being pressurized. you need the check valve. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 1, 2012 Share Posted May 1, 2012 without the check valve try slamming on the brakes in full boost and if you actually do this, make sure you don't actually have to stop... Link to comment Share on other sites More sharing options...
Hugo L. Posted May 1, 2012 Author Share Posted May 1, 2012 without the check valve try slamming on the brakes in full boost and if you actually do this, make sure you don't actually have to stop... Ok, in other words, it doesn't brake? Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 1, 2012 Share Posted May 1, 2012 There is a vacuum line connecting the booster and the manifold. Without the check valve the booster will see the manifold pressure, you will not be able to depress the pedal. Link to comment Share on other sites More sharing options...
Hugo L. Posted May 1, 2012 Author Share Posted May 1, 2012 Well, maybe this is my issue. Whenever I'm at full boost, if I want to press the brake pedal as quickly as possible following the moment I let off the gas, the pedal is very tough to depress, it takes a split second before I actually can. Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted May 1, 2012 Share Posted May 1, 2012 Who the hell are you taking your car to??? they're a bunch of retards for taking the valve out; esp in a boosted car! Wonder what other things they think you "don't need". "sir you only need one pad on a caliper cos the piston will make up for the gap" Link to comment Share on other sites More sharing options...
Hugo L. Posted May 1, 2012 Author Share Posted May 1, 2012 New shop I just «tried», specializing in Subies. My other tech changed careers. They did a decent job of fixing my fubar'ed ignition cylinder, installed the master cylinder/booster in the estimated time, adapted some rear lines to fit the STi calipers... seriously, they did a good job, but I specifically told them «what about the check valve?», and they said they were fine, didn't need one. I figured they were gonna re-use the one from the LGT, but I think it's internal, I don't even know what it looks like. But after boosting the other day and trying to brake, I was like «whoa!!!» for like 0.25 seconds. That's 0.25 seconds too long. Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted May 1, 2012 Share Posted May 1, 2012 are we all talking about the same valve in the line going to the booster? Is there any other check valves in the vacuum or even hydraulic system? Link to comment Share on other sites More sharing options...
Hugo L. Posted May 1, 2012 Author Share Posted May 1, 2012 are we all talking about the same valve in the line going to the booster? Is there any other check valves in the vacuum or even hydraulic system? Yes we are. I ordered the STi hose from the dealer that has the STi check valve in it. I'll try to find out how to install it. Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted May 1, 2012 Share Posted May 1, 2012 Yes we are. I ordered the STi hose from the dealer that has the STi check valve in it. I'll try to find out how to install it. k just wanted to make sure I understand the situation correctly. Link to comment Share on other sites More sharing options...
compsurge Posted May 1, 2012 Share Posted May 1, 2012 Still curious if a failed one will show up in A/F Learning #1 A like a vacuum leak does. Any ideas? OP, it's a straightforward install. Trace the old one to the manifold and swap it out. Link to comment Share on other sites More sharing options...
Hugo L. Posted May 1, 2012 Author Share Posted May 1, 2012 Thanks. Do I insert it closer to the manifold, or booster? Link to comment Share on other sites More sharing options...
jamal Posted May 1, 2012 Share Posted May 1, 2012 doesn't matter where it goes, it just needs to face the right direction. Nissan has an external one that you can install by cutting the hose in the middle and sticking it in either end. The cosworth manifolds come with it and I used to have the part number around. Link to comment Share on other sites More sharing options...
Hugo L. Posted May 1, 2012 Author Share Posted May 1, 2012 All right, thanks man. I know that the direction is written somewhere on this forum in the brake booster swap walkthrough. Link to comment Share on other sites More sharing options...
jamal Posted May 1, 2012 Share Posted May 1, 2012 you need to be able to blow through it into the manifold. you shouldn't be able to blow through it into the booster. and I think there is an arrow printed right on the hose. Link to comment Share on other sites More sharing options...
Hugo L. Posted May 2, 2012 Author Share Posted May 2, 2012 you need to be able to blow through it into the manifold. you shouldn't be able to blow through it into the booster. and I think there is an arrow printed right on the hose. You are right. It says « eng. -> ». pretty straightforward. Link to comment Share on other sites More sharing options...
Hugo L. Posted May 4, 2012 Author Share Posted May 4, 2012 All right, I cut open the STi brake hose, removed the bullet-shaped STi check valve, and installed it in the LGT brake booster hose. I lubed the valve a bit to ease the installatiojn, but should've lubed the inside of the hose, since it wouldn't go very far (it's a VERY tight fit). Anyway, I had enough hose length left to securely install it on the booster. No more lack of braking power under boost! And absolutely no congratulations to the shop... Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted May 4, 2012 Share Posted May 4, 2012 Awesome! Glad it was an easy fix Link to comment Share on other sites More sharing options...
pillboy Posted May 4, 2012 Share Posted May 4, 2012 Fifty percent of auto technicians graduated in the bottom half of their class. It is still ugly. Link to comment Share on other sites More sharing options...
Hugo L. Posted May 4, 2012 Author Share Posted May 4, 2012 Fifty percent of auto technicians graduated in the bottom half of their class. As obvious as it is, it's scary! Link to comment Share on other sites More sharing options...
iNVAR Posted May 7, 2012 Share Posted May 7, 2012 Fifty percent of auto technicians graduated in the bottom half of their class. As obvious as it is, it's scary! lol i think he's joking around. what he says is true. but it's also true of every other profession. think about it. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 7, 2012 Share Posted May 7, 2012 Once you take into account the licensing exam for MD's and bar admittance for JD's it's not always the case. But it is interesting to think about it like that. There are a lot of under qualified people out there making important decisions. Link to comment Share on other sites More sharing options...
