Limeydriver Posted January 7, 2006 Share Posted January 7, 2006 I have an interesting problem that has developed with my OB XT. About once a week the radio stays on after the ignition is off and the key is out of the ignition. Also a few times, the radio has been off, but when I returned to the vehicle it was on. If I push on the fusebox under the dash it will go off. Also if the ignition/radio is off I can usually push and pull the fusebox/relay bank and get the radio to turn on. I am thinking it is either a sticky relay or some issue with the relay block. I checked all the connectors at the back of the fusebox and they were all firmly plugged in. The dealer is going to look at it next week. Anyone else come across this? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted January 7, 2006 Share Posted January 7, 2006 Haven't heard of it, but I'll be interested to hear the resolution. I wonder if it has anything to do with a bad ground as so many other little problems on these cars seem to. Link to comment Share on other sites More sharing options...
Rollin Wes Posted January 11, 2006 Share Posted January 11, 2006 Maybe your cars wants to be like a GM car and have its radio stay on till you open the door! Hope the dealer can figure it out though. Link to comment Share on other sites More sharing options...
JBLU24 Posted January 11, 2006 Share Posted January 11, 2006 i could swear my car's radio stays on til I open my door........or maybe I'm thinking about my Explorer Link to comment Share on other sites More sharing options...
mwiener2 Posted January 11, 2006 Share Posted January 11, 2006 sounds like a bad relay. 1 out of several hundred thousand is pretty normal My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Limeydriver Posted January 12, 2006 Author Share Posted January 12, 2006 The fuse and relay holders were toast. Apparently a bunch of the connections were loose. The car is still at the dealer because the fuse holder assy is on backorder to Japan. The dealer said it was so bad they didn't want me in the car until they replaced it for fear of an electrical fire. I am guessing that the assembly was cracked in installation which caused a bunch of pins to short out. I will let you know definitively when I get the car back. Hopefully by Friday. Link to comment Share on other sites More sharing options...
