nasty nate Posted July 2, 2010 Share Posted July 2, 2010 I recently bought a 2007 Legacy GT. It's my first Soob and I love it. It's got 60K on it and seems to only have a few problems. My biggest concearn at this time is the large amount of water that is leaking onto my front passenger floor when it rains. And it's been raining alot lately in Western PA. I pulled the panel underneath the glovebox and can see water coming down in the general area of what I presume is the blower motor/evaporator area. I'm hoping it's something fairly simple, and cheap, like a dislodged or clogged A/C drain tube or missing firewall plug. Anyone have this problem before? Any and all suggestions are appreciated. Thanks. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 2, 2010 Moderators Share Posted July 2, 2010 I had a similar problem to this on a 2003 honda accord. I hoped that it was a clogged drainage tube from the sunroof, but it was not. I took a hose to the car to find out exactly where the water was coming from. I found out that pouring water over the windshield wiper cowl area (where the windshield attaches to the car) ended up with a lot of water coming in. I ended up taking it to a trusted body shop, and after taking a look at it they found out that a plug in the firewall was missing, allowing a lot of water to come in whenever it rained...very strange. I owned the car for a while before the leak started, so I still don't understand how the rubber plug simply fell out. Anyway, worth a shot to check all of those plugs I guess. Water leaks can be a real PITA, so best of luck to you. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
big ears Posted July 2, 2010 Share Posted July 2, 2010 Do you have a sun-roof? If so the drain holes may be plugged, you can clear them with a blast of air and the judicious use of a wire probe. Link to comment Share on other sites More sharing options...
apexi Posted July 2, 2010 Share Posted July 2, 2010 One person had a similar problem when it rained, and there was some clip missing under the windshield and rain water was coming in through there. Or it could be a clogged evap hose which has caused problems for a lot of other people. http://legacygt.com/forums/showthread.php/water-passenger-footwell-18050.html Link to comment Share on other sites More sharing options...
Max Capacity Posted July 2, 2010 Share Posted July 2, 2010 Have you blown out the drain tube on the firewall down by the DP ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
nasty nate Posted July 2, 2010 Author Share Posted July 2, 2010 Thanks for all of the responses. All i've had time for as far as diag so far is to run the car through a car wash to observe the door/window seals and briefly looked at the firewall to see if there were any obvious missing plugs. No water was coming in through the window or sunroof seals and I didn't see any missing plugs in the firewall. I guess my next step will most likely be to completely remove the glove compartment and run a hose over the cowl to see if that point to anything obvious. Locating all of the drain tubes and blowing them out seems like a good idea, as well. Thanks for the suggestions. Link to comment Share on other sites More sharing options...
