NuWiz Posted October 12, 2012 Share Posted October 12, 2012 Was looking at purchasing some ELH for my '05 legacy and was wondering if they are worth the money. I have read in different forums mixed reviews regarding them. The ones I am looking at are GT Spec, Tomei, and then Perrin. My current setup is 5EAT, AVO Topmount, Crucial Upipe, Downpipe, Midpipe, and Magnaflow cat-back. Also at the time of header install a new fuel pump and mbc will be going on. Thanks in advance Mike. ***And yes I searched Link to comment Share on other sites More sharing options...
whitetiger Posted October 12, 2012 Share Posted October 12, 2012 as long as its ELH and you get a tune for them, yes i think they are worth it Link to comment Share on other sites More sharing options...
Spec B Posted October 12, 2012 Share Posted October 12, 2012 IMO - considering the price for a nice set of ELH, I think they are worth it on a more heavily modded car (stage 3+) where you can squeeze the last bit of performance. If you had a manual tranny, I would suggest adding injectors and a larger turbo, more bang for the buck. But considering you are 5EAT - a header may make more sense since a larger turbo/injectors would probably require some tranny serious upgrades. Link to comment Share on other sites More sharing options...
dingbang Posted October 12, 2012 Share Posted October 12, 2012 Yes, there are some gains to be made with ELH headers. You lose the sound of inefficiency (eg-boxer rumblez), but if you want to squeeze the most out of things...it's the way to go. I loved my APS ELH when I had it on my car. Link to comment Share on other sites More sharing options...
NuWiz Posted October 13, 2012 Author Share Posted October 13, 2012 Thanks for the replies! Any recommendations as far as brand goes GT Spec vs Tomei vs Perrin? Coated or Wrapped? Link to comment Share on other sites More sharing options...
OutbackXT05 Posted October 13, 2012 Share Posted October 13, 2012 I was looking at getting gtspec but they were sold out so i got tomiokas (same exact thin with a different badge on it. From what i can tell it made a differnce but i did headers a gs ebc and a new ej257 block. Once i find a local dyno ill see how much of a differnce it made but also im going to the track this wednesday to see any improvements Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 13, 2012 Share Posted October 13, 2012 GTSPEC > Perrin If you are going to get headers you pretty much have to wrap 'em or whats the point. Wrap voids perrins "5yr" warranty. GTPEC is 2yr wrapped. GTSpec/Tomei also has a nice 3 flange up with a sexy velocity stack. IF ON OEM TURBO, why bother with headers that give power up top? Link to comment Share on other sites More sharing options...
Balrock Posted October 13, 2012 Share Posted October 13, 2012 My GT Spec have been wrapped for at least 3 and half years and are still in great shape. I also don't drive much in the snow and salt. Link to comment Share on other sites More sharing options...
iNVAR Posted October 13, 2012 Share Posted October 13, 2012 Gotta ask, why an MBC? Link to comment Share on other sites More sharing options...
NuWiz Posted October 19, 2012 Author Share Posted October 19, 2012 Is the PNP exhaust manifold and crossover pipe from Grimmspeed a better choice then headers? Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 19, 2012 Share Posted October 19, 2012 Not really. Its shown to make some gains but on the OEM turbo its kind of a why bother dollar for dollar. Link to comment Share on other sites More sharing options...
NuWiz Posted October 25, 2012 Author Share Posted October 25, 2012 If I am only looking for maybe 10-15hp would PNP exhaust manifold and crossover pipe be the right route? The only reason being I don't want to spend $1,500 + for turbo and supporting mods at this time, maybe down the road. Link to comment Share on other sites More sharing options...
fahr_side Posted October 25, 2012 Share Posted October 25, 2012 I don't see much in the way of gains from headers on WRX models with stock TD04 turbos. On STi models you do much better because the turbo hotside may not be the biggest restriction in the exhaust path. On my WRX with a BNR TD05H-E16G (7.5cm2 housing) I picked up about 22whp and 20wtq from adding a Tomei EL header (same as GTSpec), with no loss of spool or low-end torque. I'd recommend you put this on hold until you go to an upgraded turbo. Forget about porting the stock manifolds or adding a bigger COP. Poor return on investment of time and money. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 27, 2012 Share Posted October 27, 2012 On my WRX with a BNR TD05H-E16G (7.5cm2 housing) I picked up about 22whp and 20wtq from adding a Tomei EL header (same as GTSpec), with no loss of spool or low-end torque. Thats what up! Link to comment Share on other sites More sharing options...
NuWiz Posted October 28, 2012 Author Share Posted October 28, 2012 So really without upgrading the turbo at this point there is no more horsepower to squeeze out of the stock VF40? Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 28, 2012 Share Posted October 28, 2012 The oem turbo only moves so much air. By the time the motor is at enough rpm to start taking advantage of the header, the oem turbo is already falling on its face. Link to comment Share on other sites More sharing options...
fahr_side Posted October 28, 2012 Share Posted October 28, 2012 The oem turbo only moves so much air. By the time the motor is at enough rpm to start taking advantage of the header, the oem turbo is already falling on its face. This. You may be able to run a little more timing after fitting a header because it will even out the EGTs on all 4 cylinders. That won't however get you much power, certainly not 10 or 15whp. OTOH you will probably lose some spool and low-end torque. Start saving for a modest turbo upgrade, as no other power mods make financial sense. At stg2 you already have everything the stock turbo can offer. Or, start into suspension and brake mods to make your car quicker through corners. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
NuWiz Posted October 28, 2012 Author Share Posted October 28, 2012 Ok was hoping to get a little more power before a new turbo. Also already have BC Racing Coilovers, and DBA rotors w/ Hawk pads all around. Link to comment Share on other sites More sharing options...
famaya26 Posted October 28, 2012 Share Posted October 28, 2012 What about Unequal Length Headers vs Equal Length Headers? Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 28, 2012 Share Posted October 28, 2012 ^Why bother on any turbo vs why bother on oem turbo. Link to comment Share on other sites More sharing options...
fahr_side Posted October 28, 2012 Share Posted October 28, 2012 ^Why bother on any turbo vs why bother on oem turbo. LOL. Well said! Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 28, 2012 Share Posted October 28, 2012 Want to see where equal length headers are worth it? MY turbo defines high boost, high rpm powa. Im betting headers make more than 20hp in my car. Link to comment Share on other sites More sharing options...
robinlsb Posted October 28, 2012 Share Posted October 28, 2012 Want to see where equal length headers are worth it? MY turbo defines high boost, high rpm powa. Im betting headers make more than 20hp in my car. But headers alone:lol: "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
