1-3-2-4 Posted January 20, 2015 Share Posted January 20, 2015 I was just wondering the nut that's under the turbo that mounts to the uppipe how did you remove it? Does a short 14mm socket fit? Link to comment Share on other sites More sharing options...
covertrussian Posted January 20, 2015 Share Posted January 20, 2015 Ratcheting wrenches go a long way too. All of the bolts are 14mm. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 20, 2015 Author Share Posted January 20, 2015 Ratcheting wrenches go a long way too. All of the bolts are 14mm. Not much room to swing a wrench but on that topic how many nuts hold down the turbo to the up pipe? Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 20, 2015 Share Posted January 20, 2015 Unless someone replaced them with the Grimmspeed nuts, which in that case, are 15mm hex. Try the 14mm first and if it won't go on..... Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 20, 2015 Share Posted January 20, 2015 Three nuts hold the turbo to the down pipe. The other two are for support brackets that are attached to the head to hold the up pipe in place. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 20, 2015 Author Share Posted January 20, 2015 I'm pretty sure they are 14 mm as all the others are. . My flare wrench is a little too long I forgot how I last got to it when I needed to do the oil return. Hose Link to comment Share on other sites More sharing options...
Max Capacity Posted January 20, 2015 Share Posted January 20, 2015 FWIW, I bolt the turbo to the up pipe. Much easier to line things up. pictures in my click here link. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 20, 2015 Author Share Posted January 20, 2015 I got the turbo off but the issue I just ran into while moving things over to the new turbo is the coolant line screw ports are smaller did Subaru has two different size bolts that screwed into the turbo? it's stupid since this is really the only thing stopping me from going on. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 23, 2015 Author Share Posted January 23, 2015 You can see herehttp://tapatalk.imageshack.com/v2/15/01/22/c06755face0610e5e1013c3cd41c3508.jpghttp://tapatalk.imageshack.com/v2/15/01/22/f0133c52f2fc2569ff5475e6e851c624.jpg Link to comment Share on other sites More sharing options...
kzr750r1 Posted January 23, 2015 Share Posted January 23, 2015 Errrrr.... What about the rest of the hardware? Mounting HW that is... Is the company you bought this from offering new coolant hoses? Otherwise your in for some fun building your own set. Link to comment Share on other sites More sharing options...
lingling1337 Posted January 23, 2015 Share Posted January 23, 2015 What turbo are you replacing and what are you replacing it with. Link to comment Share on other sites More sharing options...
Leviman Posted January 23, 2015 Share Posted January 23, 2015 Weird that you can't get to those nuts. The turbo bolts to the up pipe with three nuts, I accessed all with a short 14mm and a long extension. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 23, 2015 Author Share Posted January 23, 2015 I'm not talking about mounting I'm talking about the coolant banjo and the bolts that go in the turbo to hold the coolant line down Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 23, 2015 Author Share Posted January 23, 2015 Errrrr.... What about the rest of the hardware? Mounting HW that is... Is the company you bought this from offering new coolant hoses? Otherwise your in for some fun building your own set. The focus is not the mounting hardware but the bolt it's self.. The stock coolant banjo fits it's the bolt that does not Link to comment Share on other sites More sharing options...
kzr750r1 Posted January 23, 2015 Share Posted January 23, 2015 Yeah.... What else is different... Over. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 23, 2015 Author Share Posted January 23, 2015 It's back to the stock turbo size lol Link to comment Share on other sites More sharing options...
ttnio Posted January 24, 2015 Share Posted January 24, 2015 It's back to the stock turbo size lol Be Happy, being stock Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 24, 2015 Author Share Posted January 24, 2015 Trying to find these banjo bolts is a pain in the ass Link to comment Share on other sites More sharing options...
kzr750r1 Posted January 24, 2015 Share Posted January 24, 2015 It's not just the bolt mon... You need the banjo to match. Get whoever you picked this turbo up from help you isolate what is needed. They may have a different coolant line kit available. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 24, 2015 Author Share Posted January 24, 2015 Why do you need the banjo to match? I already determined the thread size is m12x1.25 that fits the stock banjo line just fine Link to comment Share on other sites More sharing options...
kzr750r1 Posted January 24, 2015 Share Posted January 24, 2015 Ok... Was under the impression the bolt size was smaller so you would need a smaller AN fitting to match. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 25, 2015 Author Share Posted January 25, 2015 Not that I know of as long as it's not too small Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 25, 2015 Author Share Posted January 25, 2015 I think I'm going to get this too bad I have to waithttp://tapatalk.imageshack.com/v2/15/01/25/21468a67cbbd6662518e9a895fefa0f5.jpg Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 25, 2015 Author Share Posted January 25, 2015 Wtf that stupid ass website uses PayPal I can't pat for the items... so back to trying to figure out how to get this shit Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 25, 2015 Author Share Posted January 25, 2015 Finally got around it but had to order the same just on ebay at least this is done.. got the end with barb ends to a an screw fitting banjo in m12x1.25 Link to comment Share on other sites More sharing options...
