sostafari Posted April 6, 2014 Share Posted April 6, 2014 Stock 17" wheels on my 05 GT wagon With the winter potholes so bad this year in Northeast, I've flatted FOUR of these tires! I would blame it on bad luck, but I flatted two of them prior to this winter. Has anyone else had bad luck with these? Can anyone offer a better replacement? These things aren't cheap either. I was thinking of going up to a 215/50/17...Would it help? Could I go even taller? Could I put Outback struts and springs on it and go even bigger? This is driving me batty:spin: Link to comment Share on other sites More sharing options...
FocuS Posted April 6, 2014 Share Posted April 6, 2014 I run 225/55/17s on a set of Rotas... No issues yet, knock on wood! I also run them at higher pressure since new. Link to comment Share on other sites More sharing options...
nouse4aname Posted April 6, 2014 Share Posted April 6, 2014 No issues with my ExtremeContacts...but I do a fair bit of pothole dodging rather than drive through them. Link to comment Share on other sites More sharing options...
apexi Posted April 6, 2014 Share Posted April 6, 2014 I know it might be too late.. But Continental does offer a road hazard warranty for the first year or 2/32" of treadwear. After skimming through their warranty documentation, I think it should cover damage from pot holes, but I'm not positive. Link to comment Share on other sites More sharing options...
nouse4aname Posted April 6, 2014 Share Posted April 6, 2014 Even without that, the city is liable for pothole damage. Link to comment Share on other sites More sharing options...
1337Logic Posted April 6, 2014 Share Posted April 6, 2014 Have had 'extremely' good performance out of mine. On my 3rd set in fact heh Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 6, 2014 Moderators Share Posted April 6, 2014 I just had a extreme contact DW blow out on me due to a pothole. Pretty common issue it seems with conti sidewalls, but honestly with some of the potholes around this year it's just bound to happen. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
sostafari Posted April 7, 2014 Author Share Posted April 7, 2014 okay thanks, I'm not crazy... Link to comment Share on other sites More sharing options...
stanjk3 Posted April 7, 2014 Share Posted April 7, 2014 What psi are you using? I bought a set of '08 WRX wheels with Conti DWS (225/45 17) on them back in October and haven't had any problems yet. I run at 40/38psi. I need new front wheel bearings, but that's not the fault of the tires. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
sostafari Posted April 7, 2014 Author Share Posted April 7, 2014 I was running at 32 until my fourth flat. Then I went to 45. Been fine for a month. I just noticed a serious bubble in my left rear yesterday. Is that considered Warranty? Link to comment Share on other sites More sharing options...
Nightmaresmk Posted April 7, 2014 Share Posted April 7, 2014 45psi!! way way to much max is 42psi no wonder u have a bubble. I run mine tires 36-38 for both my winter and summers. Best advice avoid the potholes. Link to comment Share on other sites More sharing options...
apexi Posted April 7, 2014 Share Posted April 7, 2014 I was running at 32 until my fourth flat. Then I went to 45. Been fine for a month. I just noticed a serious bubble in my left rear yesterday. Is that considered Warranty? I'm not sure, I would call continental directly and ask 1-800-847-3349 Link to comment Share on other sites More sharing options...
lee07 Posted April 8, 2014 Share Posted April 8, 2014 45? Wow! I run 37/35 and never had a tire blow out or had a flat ever, just a couple of nails but that's it. Minnesota has pot holes everywhere, worse I've seen. All you can do is Slow down or find an alternate route that has better roads. Link to comment Share on other sites More sharing options...
stanjk3 Posted April 9, 2014 Share Posted April 9, 2014 I was running at 32 until my fourth flat. That's part of the problem right there. Recommended psi is 35/33 F/R. Many people on here recommend at least 3psi extra to help firm up the sidewalls. Though if a pothole is bad enough, it's not gonna matter if you're using 32 or 42psi. I think the max pressure is 50psi. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
sostafari Posted April 9, 2014 Author Share Posted April 9, 2014 Max PSI is 51. I've decided to try it and see what happens next time i slam one of these things I don't see coming. HOWEVER! I had a eureka moment yesterday when I took my bubbled tire in to get checked out and (sigh) replaced again... BELGIAN BLOCK! My very short driveway tapers from the two car garage to the entrance. It's lined with Belgian Block. Going in and out of the driveway, hitting the Belgian Block every now and then is inevidable. I've been parking my LGT and my Highlander in the driveway together. Highlander, no problem. LGT...deadly. When I was inspecting the tire, I realized it was shredded at three points on the sidewall (one being where it bubbled). I'm parking it on the street from now on. I think this has been the cause of half my replacements. Other half are still just these f'ing potholes and bad luck.... Link to comment Share on other sites More sharing options...
washingtonOBXT Posted April 10, 2014 Share Posted April 10, 2014 I love mine... that being said, people have warned me of the soft sidewalls, thats all i know. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 10, 2014 Share Posted April 10, 2014 I think I would remove that Belgian Block or blocks or at least flatten with a sledge hammer. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
