ebo03's 2011 LGT - BNR 20G, EWGs, custom FMIC, Brembos, Recaro
There will be a nice collection of parts rolling in tomorrow so I figured I'd start a journal. And a stock turbo I picked up from a scrapyard will arrive at BNR for a 20G upgrade tomorrow as well.
Updated 10/2/15:
Power
Cobb AP (tuned by Cleo at IAG Performance)
BNR 20G
ID 1000s
Walbro 255 pump
ETS manifold with twin Tial MV-S 38mm wastegates
AVO TBE (added double wall rolled tips)
Custom FMIC with Vibrant 12810 and AMS crash bar (GR STI)
Tial Q BOV
Suspension
RCE Tarmac Zero
Group N front top hats
Whiteline 26mm F & 24mm R adjustable sways (powdercoated hot candy blue w/rear supports coated yellow nugget)
AVO adjustable F&R endlinks
AVO rear sway mount brace
Brakes
GR STI F&R Brembos painted Porsche Speed Yellow w/black lettering
Mach V F&R lines
DBA T3 4000 slotted F&R rotors
Cosworth Streetmaster F&R pads
1mm titanium shims F&R
Driveline
Clutch Masters FX300
STI short shifter
Perrin short shifter adapter
Perrin shifter bushing
Group N trans mount
Whiteline KDT901 positive shift kit
Whiteline KDT902 positive traction kit
Whiteline KDT903 rear differential inserts
Whiteline KDT905 rear mount bushings
Wheels/tires
Gram Lights 57Xtreme 19x9.5 +43
Continental ExtremeContact DW 275/35/19
Winter - Prodrive GT1 matte anthracite 18x7.5 +48 on Bridgestone Blizzak WS70 225/45/18 with 3mm spacers
Audio
Kenwood DNX-893S
Kenwood CMOS-200 backup camera
Kenwood Sirius adapter
PAC steering wheel controls
JDM dash kit
Misc.
Primitive 3/16" skid plate
Hella Supertones powdercoated wrinkle black w/Subimods bracket & Lightwerkz harness
Lightwerkz HID conversion with blacked out housings
Fumoto oil drain valve
PIAA SI-Tech wipers
PIAA Plasma Ion Yellow fog lights bulbs
Recaro Sportster CS in black leather - Euro spec with side airbag - mounted on Planted bracket with Recaro sliders
Grillcraft grille
2013+ satellite antenna paint matched SSM
  • Replies 585
  • Created
  • Last Reply
Arriving tomorrow...
Clutchmasters FX300
ID 1000cc & adapter harness
DW300 fuel pump
NGK one-step colder plugs
Cobb EBCS
AVO adjustable front endlinks
Also ordered this week...
OEM gaskets & hardware for turbo install
OEM flywheel bolts for clutch install
OEM gauge pod
Cobb XLE bypass valve
Whiteline lateral lock kit
Infamous Performance turbo oil line filter kit
Extra lines and fittings for kit to work on 5th gen (thanks BigBopper)
PLX DM-100
PLX AFR module
PLX boost module
PLX oil pressure module
PLX EGT module
Whiteline 26mm F & 24mm R sways. I want to powdercoat these...any suggestions on colors? Thinking about yellow...same as I did on my STI.
Dropped off sway bars to be powder coated today. Bars will be a candy blue similar to World Rally Blue, rear mount supports will be yellow nugget (yellow with a little orange metallic flake). I will say Whiteline has improved their powder coating since I bought bars for my STI 3 years ago. Back then they did not even put a clear coat on, a big no-no when using metallics. They certainly use a clear now and they look far more durable than before. But never the less, I wanted to add a little color to seldomly seen parts.
PLX gauges got here today and all other parts have arrived except the turbo from BNR.
The bad news is I won't be able to get it tuned until the end of June. Going to have Jorge tune it on Speed Density when he comes to IAG next month. I have a planned trip the weekend of his May tuning session and won't be able to install the clutch until 3 weeks from now anyway.
Parts arriving left and right...the UPS man is starting to resemble Santa Claus.
TUNING UPDATE 8/25/13
Car was tuned this morning by Jorge at IAG. Car made 315/319. Jorge spent a significant amount of time trying to combat boost creep & heat soak. He said the turbo is creeping to 20psi and could not be dialed back down to 18 or 19. Therefore he was not able to limit boost as he would prefer to in that situation and had to pull timing out of the tune in the upper RPMs (5500-7000). He said the turbo had more in it and wanted to continue making power but the IATs he was seeing at 20psi in the higher RPMs were leading to detonation so he had to scale back the timing. At 20psi IATs were going from 80-90° F in the middle of the rev range to around 160° F at 5500 RPM.
I knew the car would be limited by the relatively small turbine wheel and the TMIC. When I dropped it off Thursday I discussed Aquamist kits with the guys at IAG, which they pretty much steered me away from, and also having them possibly make a custom FMIC in the future. I am a fan of efficiency so I'd like to get everything possible out of this turbo.
All in all, a very positive experience at IAG. All the guys there are very friendly and as professional as they can be.
And yes, it feels like an entirely different car!
I will be interested in seeing how that clutch works out for you given my experience with the FX100.
I'm inferring you are not a fan of the FX100. What are your main complaints?
Mike from Infamous pointed me in the direction of the FX300 over the ACT HDSS.
Far too much chatter for a street car. I hope you have different results.
http://i304.photobucket.com/albums/nn183/ebo05jmu/11%20LGT/IMG_20120816_182819.jpg
http://i304.photobucket.com/albums/nn183/ebo05jmu/11%20LGT/IMG_20120816_183034.jpg
http://i304.photobucket.com/albums/nn183/ebo05jmu/11%20LGT/IMG_20120723_185332.jpg
http://i304.photobucket.com/albums/nn183/ebo05jmu/11%20LGT/IMG_20120723_185434.jpg
Damn, I've got 3 out of 5 of those PLX bits sitting on a shelf here, never got around to installing them.
Before you took the broken photo links down, it looked like there was a space in the URL. Get that space out of the folder name on PB, that'll help a lot of broken links, though it may create some new ones if you've linked a lot of things to that folder...
  • 2 weeks later...
I won't get around to it until the weekend of June 7.
Doing it yourself?
If so you should make a DIY. Also don't forget to buy new pressure plate and flywheel bolts as they are all torque to yield.
Doing it yourself?
Never replaced a clutch before so I'm getting a friend to help. He is mechanic by day and a highly skilled one at that so he could probably do it with his eyes closed.
I did buy new flywheel bolts but from what I understand the pressure plate is included in the Clutch Masters kit.
I would say chances are slim that I will do a DIY writeup...flat out too lazy. But I will post any pointers that may be unique to the 5th gen or unusual in general.
Pay a lot of attention for the next clutch replacement. They get easier every time. After a couple clutches on my old 240Z, I got so good at it that I could do it in 2 hours from wheels up to wheels down, in the driveway, by myself. And I started doing it for friends too as long as they brought beer and pizza. :lol:
