2.5SLGT Posted April 22, 2009 Share Posted April 22, 2009 Just out of curiosity. Has anyone had the spt intake on for a long time and had any problems? any problems what so ever. Link to comment Share on other sites More sharing options...
EddieSpecB Posted July 7, 2009 Share Posted July 7, 2009 I'm curious about this as well. I just installed one on my wife's Spec.B and it sounds great and seems to have smoothed out the power curve in the mid range, but I'm curious as to long-term experience from others. This car is seldom driven hard, so I'm not too worried about it. We also do not intend on modifying farther than perhaps a catback down the road. Link to comment Share on other sites More sharing options...
EddieSpecB Posted July 10, 2009 Share Posted July 10, 2009 No long-term users of this intake? Scary... :-\ Link to comment Share on other sites More sharing options...
praedet Posted July 10, 2009 Share Posted July 10, 2009 Everyone took theirs off because the testing of the intake proved it was unsafe on an untuned vehicle, and very hard to tune. Moreover, you lose power with it on... Link to comment Share on other sites More sharing options...
Coyote_Lips Posted July 10, 2009 Share Posted July 10, 2009 I took mine off on Shamar's recommendation, car is tuned nicely with an AVO drop in... finding myself missing the fwooosh though. Yup... Link to comment Share on other sites More sharing options...
captainhook Posted July 11, 2009 Share Posted July 11, 2009 Everyone took theirs off because the testing of the intake proved it was unsafe on an untuned vehicle, and very hard to tune. Moreover, you lose power with it on... Right on Link to comment Share on other sites More sharing options...
EddieSpecB Posted July 11, 2009 Share Posted July 11, 2009 Everyone took theirs off because the testing of the intake proved it was unsafe on an untuned vehicle, and very hard to tune. Moreover, you lose power with it on... Searching the forums I've found many threads of people stating this. However, I'm having a hard time finding a thread that contains the test results (not words, but actual numbers). These would (hopefully) include dyno charts of the loss of power, as well. Because it is covered under the Subaru warranty, our vehicle is brand new with most of its MFG warranty left on it, and we don't drive it hard, I'll volunteer to be the unofficial long-term SPT Intake test guinea pig. Link to comment Share on other sites More sharing options...
slacks Posted July 14, 2009 Share Posted July 14, 2009 Searching the forums I've found many threads of people stating this. However, I'm having a hard time finding a thread that contains the test results (not words, but actual numbers). These would (hopefully) include dyno charts of the loss of power, as well. x2 I ordered mine from the dealership with the heat shield and will be here wednesday. It seemed worth a shot since the discount is generous I could try and log some data if it would help some other people. Link to comment Share on other sites More sharing options...
Silverstar Posted July 14, 2009 Share Posted July 14, 2009 Cobb did a write-up on the crapulence of the SPT intake. (IIRC this was before they sold an intake.) I tried searching but didn't come up with anything immediately... Link to comment Share on other sites More sharing options...
slacks Posted July 14, 2009 Share Posted July 14, 2009 From the looks of it the Cobb and SPT intake look pretty identical and Cobb tested the SPT intake without the heatshield (which even our parts guy said that it's meant to be used with). So for the price of a used K&N typhoon intake I'm getting the whole package and am interested in how this works out. Link to comment Share on other sites More sharing options...
praedet Posted July 14, 2009 Share Posted July 14, 2009 Try whatever you want, don't worry about believing us Link to comment Share on other sites More sharing options...
NSFW Posted July 14, 2009 Share Posted July 14, 2009 Searching the forums I've found many threads of people stating this. However, I'm having a hard time finding a thread that contains the test results (not words, but actual numbers). Cobb posted a PDF on their site. They've since removed it, but there was quite a bit of discussion about it at Nasioc, and that's still up. Link to comment Share on other sites More sharing options...
doctorbrody Posted July 14, 2009 Share Posted July 14, 2009 I used an SPT intake/heatshield for a year, and just swapped it out for the Cobb SF/box. The SPT sounds amazing, but there's no question I'm making more power with the Cobb. I was probably making more power with the K&N panel I had first, but the short ram sound is addictive. The SPT is a fun piece if you like the noise, and can be found pretty cheap used. FWIW, I never had a problem leaning out with the SPT, even before tuning for it. Link to comment Share on other sites More sharing options...
jxjjang Posted July 14, 2009 Share Posted July 14, 2009 i've had it on for about 35,000 miles with no problem. although i don't have any numbers, i felt a very slight increase in power when coupled with the heat shield and SPT exhaust, but it sounds great! Link to comment Share on other sites More sharing options...
captainhook Posted July 14, 2009 Share Posted July 14, 2009 From the looks of it the Cobb and SPT intake look pretty identical Lol, then you need to look a lot closer my friend, specifically where the MAF sensor is located . . . in the piping bend where there's a ton of fluctuating air turbulence (SPT) vs the Cobb which is located just after the filter in the straight pipe before the bends. The power difference also has a lot more to do with the fact that the SPT's metal piping gets INSANELY hot after only a short drive where as the Cobb intake's silicon tubing only gets warm. My intake temps were 10-20 degrees higher when I ran the SPT intake+airbox vs the Cobb SF intake + airbox (used the SPT heat shield with both) . . . right there's where your power loss comes from. Link to comment Share on other sites More sharing options...
slacks Posted July 14, 2009 Share Posted July 14, 2009 My intake temps were 10-20 degrees higher when I ran the SPT intake+airbox vs the Cobb SF intake + airbox just curious but how did you keep track of your intake temperatures? Link to comment Share on other sites More sharing options...
NSFW Posted July 15, 2009 Share Posted July 15, 2009 You can log intake air temp with RomRaider. Link to comment Share on other sites More sharing options...
captainhook Posted July 15, 2009 Share Posted July 15, 2009 just curious but how did you keep track of your intake temperatures? You can view it in real time with the AP and/or log it. Link to comment Share on other sites More sharing options...
snow05gtRI Posted July 15, 2009 Share Posted July 15, 2009 i had one, got rid of it. i got sick of the screaming after a few months. i cant really say how it impacted performance, i never drove the car with the stock airbox (came with the SPT on it). at times it felt sluggish when getting on the highway, but this was before i ever went stage 1 or anything so it could have just been the car, or the sound of rushing air made me think i should have been going faster than i was. i moved to an AEM (with a stage 1 tune, at the time...now past that....) and still can hear the nice sounds of an intake but at a much more enjoyable volume level. Link to comment Share on other sites More sharing options...
2mchbst Posted August 3, 2009 Share Posted August 3, 2009 Mine has been on the car (06 LGT, MT) along with the heat shield for almost 60K. My car is currently at 90K. I haven't noticed any loss in power. I didn't notice a 1mpg increase in fuel economy over stock and the studder seemed to have almost disappeared. Link to comment Share on other sites More sharing options...
Mark34 Posted August 4, 2009 Share Posted August 4, 2009 I've had mine on since I got the car in '07. It was installed on the car before I even picked it up. 43K + on it now and no problems noted, though I did ditch the filter for an AEM Dryflow filter. Link to comment Share on other sites More sharing options...
LIZARD Posted August 4, 2009 Share Posted August 4, 2009 To slacks et al: just buy the SPT intake and forget what others who have been on these forums and actually ran the SPT with bad results and data logs/AP real time #'s etc. have said. I believe everthing that's written on an advertisement especially by the company that makes/writes it. Hmmm.. I wonder why there are so many good deals on 'em these days? Meh, go get one!! Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
sugawi Posted August 4, 2009 Share Posted August 4, 2009 Previous owner installed SPT on mine 05 LGTW and since I did not get original intake with the car I just kept it. I had Infamous1 to rescale MAF though. (along with stage 1 tune I can't comment on the difference of SPT and others but I see no problems so far. Here is my tq and hp before and after tuning. I have Borla exhaust and everything else is stock. The values are based on power to the wheels, I have no idea how much is it to the fly wheel. http://i82.photobucket.com/albums/j251/tobyloby/SugawiLGTStg1SPTBorlaCBE.jpg Link to comment Share on other sites More sharing options...
godwhomismike Posted April 24, 2010 Share Posted April 24, 2010 Just out of curiosity. Has anyone had the spt intake on for a long time and had any problems? any problems what so ever. I don't know if it was caused by the SPT Intake, but I had a lot of problems when I had my '05 Legacy GT. I had a bunch of engine problems, and one time so bad my car was off the road at a dealership for repairs for nearly a whole summer. I strongly advise not to **** with it. Buyer beware. btw... The only mod I had was the SPT Intake. Also be warned, it's obnoxiously loud. Link to comment Share on other sites More sharing options...
