silen7guardian Posted January 13, 2014 Share Posted January 13, 2014 TL;DR version: Turbo went boom. Eight days ago, when I was almost home in my Outback, I had almost no power, and my engine wouldn't rev above 3,000 RPM. When I got home, I pulled my codes with LearningView. I forget the number... maybe P0011... but it was the code for cam over-advance. So, in a -45º F Windchill, and not in a garage, I pulled my OCVs. I cleaned 'em and put 'em back in. I've been meaning to do this anyway, so great. Just a really cold day is all. I drive in circles by my driveway to test the car. The engine runs slightly better, but still with no power or high revs. The car stalls if I let the engine drop to idle speeds. I then noticed a weird smell, so I pulled back into the driveway and popped the hood. My oil dipstick had been ejected, and oil had spewed a bit. I immediately thought, "Too much oil pressure." Then the proverbial light went on. I had installed a non-Subaru oil filter near the end of the summer. I know, I know. I've brought this upon myself. I installed a [ame=http://www.amazon.com/dp/B003L35936]Royal Purple 10-2876[/ame] because it's supposed to filter even better and last even longer. I had done thorough research, and this filter seemed pretty legitimate. Here's the catch: either the oil filter bypass operates at a different pressure than OEM, or it was clogged beyond operation. I had somehow misremembered, thinking that the RP filter didn't have a bypass, so I figured I just needed to change the oil and filter. So the next day, in -60º F Windchill, I changed my oil and filter. The used RP oil filter was considerably heavier than any used OEM filter, despite being smaller. "Must be clogged as I suspected," I thought. I figured that I had solved my problem. I buttoned everything back up, and reset the ECU to get rid of bad timing learned from too much oil pressure and sticky OCVs. I start the car. Still no power. Now I'm getting a bunch of smoke from the exhaust, and the car doesn't run at all, even with a little gas pedal action. More codes. Misfires in cylinders one, two, and three (not four! ha!). At this point, I got out of my car feeling pretty defeated. The next day, in -40º F windchill, I pulled my intercooler off. There was oily sludge in the intercooler, so my new theory of a blown turbo oil seal is looking pretty good. Yesterday, I pulled the turbo. It was oily, there's shaft play, and the turbines look pretty bad. This turbo was supposedly new from Subaru, installed by the Volvo dealership I bought the car from at 97K miles three years ago. I think I'm at nearly 130K miles now. The bearing in the factory-original turbo failed during my test-drive. When I removed the turbo, I noticed some things that made me sad. The turbo inlet hose had been ripped. The oil feed line was bent to remove the turbo, presumably because the flare nut joint (what's it called?) was stuck. I couldn't open that either, so I, too, had to bend the oil feed line to remove the turbo. The oil return hose wasn't even clamped on the bottom side. One of the bolts holding my down pipe to the turbo was never reinstalled. I could see on the down pipe gasket where there was some exhaust blow-by. Thankfully, I've been able to borrow a vehicle to get to work, etc. My plan for now is to file my taxes and use the expected return to buy an old Saturn SL2 or something, then fix the Subaru as time and money allows. This would allow me a nice time buffer to fix things the right way. Edit: I added a few more pictures. Edit 2: LearningView Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 Subaru plans: Up- and down-pipeClean PCV, grease starter, replace turbo inlet hose, maybe replace knock sensorAttempt to rebuild my VF-40 I can get a new VF-40 cartridge for about $250 right now from eBay. The cartridge is the important part, right? As long as that's new, this should work well enough, right? I could go with BNR 16G, but then I need a new oil feed line, which means pulling the intake manifold I think. I don't want to take that off. It also far more costly. I could go with a rebuilt (new cartridge) VF-46. What do you think? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2014 Share Posted January 13, 2014 As long as you compressor housing is in good shape the ebay part should work. You will remove the banjo filter, right ? You will pull the oil pan and check for metal, right ? If you find metal, you will replace the oil cooler, right ? you will get a new oil return hose. I like to bolt the turbo on the up pipe, use the bolts from the up pipe bracket to the block, the dealer has them. Makes lining up the inlet hose, oil return line and turbo to up pipe much easier. My oil feed AN fitting is frozen too, just bend the pipe carefully. Also that missing nut on the DP is common. You'll understand why when you put it back together. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 You will remove the banjo filter, right? You will pull the oil pan and check for metal, right? If you find metal, you will replace the oil cooler, right? That was the plan. EDIT: Except I was originally thinking that I'd replace the banjo filter with a new one. Perhaps not though. You will get a new oil return hose. Now I will, thanks! Thanks for the install tips, too. Link to comment Share on other sites More sharing options...
rob-2 Posted January 13, 2014 Share Posted January 13, 2014 Notice the blades have impact marks. I would start looking for other damage before putting any money into this motor. Drain oil. Check for metal. Pull oil filter. Check for metal. If you find any consider a rebuild + turbo. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2014 Share Posted January 13, 2014 After my wagon had the P0011 and P0021 codes the banjo filter was removed. the oil flushed and changed. I got another 100 miles out of my turbo, I got lucky, the turbo whinned when in boost, then the day it whistled when leaving for work and stopped driving and ordered a vf52 that morning had it the next day. www.AZPinstalls.com got it for me. If you blades contacted the compressor housing...you have metal in the oil. Looking at your pictures...they hit the housing. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
covertrussian Posted January 13, 2014 Share Posted January 13, 2014 Would a non Subaru oil filter REALLY do that damage? I've been running STP filters on my FXT (before I found out that Subaru's are fairly picky on filters), and as far as I can tell the car has been doing just fine. How are your turbo banjo filters, pull the one behind the turbo out and see if it's dirty. My FXT's filters were spotless, but LGT had a very dirty banjo filters. LGT Turbo was already replaced once by previous owner, but new damage could still be there because they didn't replace/remove the filters. http://images.rvsmods.com/var/albums/Cars/LGT/Engine/Banjo-Filters/CIMG0674.JPG?m=1383856302 http://images.rvsmods.com/var/albums/Cars/LGT/Engine/Banjo-Filters/CIMG0678.JPG?m=1383856302 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2014 Share Posted January 13, 2014 I use Fram filters for most of the wagons first 154,000 miles and cheap dino oil from Walmart, Mobil 5000, Shell, Exxon, whatever 5-30 was on sale. Sometimes Rotella 15-40 in the summer. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted January 13, 2014 Share Posted January 13, 2014 Would a non Subaru oil filter REALLY do that damage? I've been running STP filters on my FXT (before I found out that Subaru's are fairly picky on filters), and as far as I can tell the car has been doing just fine. How are your turbo banjo filters, pull the one behind the turbo out and see if it's dirty. My FXT's filters were spotless, but LGT had a very dirty banjo filters. LGT Turbo was already replaced once by previous owner, but new damage could still be there because they didn't replace/remove the filters. http://images.rvsmods.com/var/albums/Cars/LGT/Engine/Banjo-Filters/CIMG0674.JPG?m=1383856302 http://images.rvsmods.com/var/albums/Cars/LGT/Engine/Banjo-Filters/CIMG0678.JPG?m=1383856302 No the filter choice itself wouldn't case any problems. I run an oversized filter because I'm odd. Link to comment Share on other sites More sharing options...
boxkita Posted January 13, 2014 Share Posted January 13, 2014 Subaru plans: Up- and down-pipeClean PCV, grease starter, replace turbo inlet hose, maybe replace knock sensorAttempt to rebuild my VF-40 I can get a new VF-40 cartridge for about $250 right now from eBay. The cartridge is the important part, right? As long as that's new, this should work well enough, right? I could go with BNR 16G, but then I need a new oil feed line, which means pulling the intake manifold I think. I don't want to take that off. It also far more costly. I could go with a rebuilt (new cartridge) VF-46. What do you think? PM JmP6889928. He is rebuilding the OEM turbos to fix their internal oiling issues. he has several in stock and ready to ship. So much better quality than ebay stuff. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2014 Share Posted January 13, 2014 PM JmP6889928. He is rebuilding the OEM turbos to fix their internal oiling issues. he has several in stock and ready to ship. So much better quality than ebay stuff. There you go, someone we trust has them for you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 After my wagon had the P0011 and P0021 codes the banjo filter was removed. the oil flushed and changed. I got another 100 miles out of my turbo, I got lucky, the turbo whinned when in boost, then the day it whistled when leaving for work and stopped driving and ordered a vf52 that morning had it the next day. www.AZPinstalls.com got it for me. If you blades contacted the compressor housing...you have metal in the oil. Looking at your pictures...they hit the housing. D: I never heard any weird whining noises. The first turbo I definitely heard when it failed. That was pretty distinct. I'll have to further assess the damage, but I think, er... I hope the damage will be minimal. Link to comment Share on other sites More sharing options...
boxkita Posted January 13, 2014 Share Posted January 13, 2014 Minimal, in this case, would be swapping the turbo & full clean of everything. Average would be a engine rebuild due to shrapnel making its way into other systems. Be sure to do a compression check, and check your oil pan (pull it). Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 Would a non Subaru oil filter REALLY do that damage? The more I think about this, the more I'm thinking that the turbo ruined the filter instead of the filter ruined the turbo. Hmmm. Maybe the better filter even helped a little. =[ How are your turbo banjo filters, pull the one behind the turbo out and see if it's dirty. My FXT's filters were spotless, but LGT had a very dirty banjo filters. LGT Turbo was already replaced once by previous owner, but new damage could still be there because they didn't replace/remove the filters. AVCS bolts looked like they had no filter, but I'm thinking maybe they just dropped out, like yours did. Turbo bolt looked pretty dirty. I couldn't get the filter out, but I didn't try very hard, either. The banjo bolt filter was supposedly replaced with a brand new one three years ago. I like your build thread, by the way. I was a little surprised you didn't just put an FM Modulator in your car. The OEM head unit sounds pretty good to me. I like the iSimple. One cable to charge my iPhone and play music, too. Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 One additional tid-bit: I've been using Royal Purple 0W-40 for a little while now. Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 Man. This whole situation just makes me sad, especially because of how perfect of a vehicle the Outback XT is for me. Wonderful versatility. Lots of room in the back to store supplies for helping other folks out of bind such as a flat tire. Ground clearance that mocks MN roads. AWD that laughs at MN snow. Starts every time, even in -25º F actual temperatures with my factory-original battery. Enough power for some fun driving. My first car. Enough problems to teach me that I can, in fact, work on cars- I learned I'm not just the computer guy. Wow. It almost feels like I'm losing a good, long-time friend. It seems silly to like a car so much, but the silliness doesn't make it untrue. Link to comment Share on other sites More sharing options...
boxkita Posted January 13, 2014 Share Posted January 13, 2014 lot of people on here who feel the same way. you're in good hands. Have you seen the rear BBK thread? Or the infamous oil line kit? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 Have you seen the rear BBK thread? Or the infamous oil line kit? I don't think so. Do you have the link handy? Link to comment Share on other sites More sharing options...
boxkita Posted January 13, 2014 Share Posted January 13, 2014 here's a small baggy to get you going. I'm a gateway supplier. :-) rear bbk - http://legacygt.com/forums/showthread.php/wilwood-rear-big-brake-kit-potential-group-buy-219483.html?t=219483 IP&T oil line kit - http://legacygt.com/forums/showthread.php/filtered-turbo-oil-supply-line-kit-w-instructions-173373.html?t=173373 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 here's a small baggy to get you going. I'm a gateway supplier. :-) rear bbk - http://legacygt.com/forums/showthread.php/wilwood-rear-big-brake-kit-potential-group-buy-219483.html?t=219483 IP&T oil line kit - http://legacygt.com/forums/showthread.php/filtered-turbo-oil-supply-line-kit-w-instructions-173373.html?t=173373 I think I'd be happy with a LGT brake swap (OBXT is single piston up front). That oil line looks good though. Thanks Link to comment Share on other sites More sharing options...
rob-2 Posted January 13, 2014 Share Posted January 13, 2014 One additional tid-bit: I've been using Royal Purple 0W-40 for a little while now. Unfortunately that oil is pretty bad Link to comment Share on other sites More sharing options...
boxkita Posted January 13, 2014 Share Posted January 13, 2014 I think I'd be happy with a LGT brake swap (OBXT is single piston up front). That oil line looks good though. Thanks check on the brakes forum section. has all the info you need on swapping the brakes. if all else fails, PM BarManBean. he has swapped stuff onto his Outback(s) enough times to know what works. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
covertrussian Posted January 13, 2014 Share Posted January 13, 2014 AVCS bolts looked like they had no filter, but I'm thinking maybe they just dropped out, like yours did. Turbo bolt looked pretty dirty. I couldn't get the filter out, but I didn't try very hard, either. The banjo bolt filter was supposedly replaced with a brand new one three years ago. I like your build thread, by the way. I was a little surprised you didn't just put an FM Modulator in your car. The OEM head unit sounds pretty good to me. I like the iSimple. One cable to charge my iPhone and play music, too. My 05 LGT didn't have AVCS filters, while my 04 FXT did. Rumor has it that 05 FXT didn't have AVCS filters, thus 05 LGT probably never had them too. I used a dentist like pick to get the filter out, they come out fairly easily if you don't mind killing the useless filter. Thanks, I hope the thread is helping you a long, I'm tempted to do my parking brake shoes next... As for radio, I used an FM modulator with USB support for a bit, but crappy sound quality plus poor file browser made me hate it. I don't use MP3 players anymore, 16GB USB stick that always stays in the car, doesn't need charging, and is browsable through the head unit FTW. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 Unfortunately that oil is pretty bad How so? Weight or brand? Link to comment Share on other sites More sharing options...
silen7guardian Posted January 13, 2014 Author Share Posted January 13, 2014 My 05 LGT didn't have AVCS filters, while my 04 FXT did. Rumor has it that 05 FXT didn't have AVCS filters, thus 05 LGT probably never had them too. I used a dentist like pick to get the filter out, they come out fairly easily if you don't mind killing the useless filter. Thanks, I hope the thread is helping you a long, I'm tempted to do my parking brake shoes next... As for radio, I used an FM modulator with USB support for a bit, but crappy sound quality plus poor file browser made me hate it. I don't use MP3 players anymore, 16GB USB stick that always stays in the car, doesn't need charging, and is browsable through the head unit FTW. Oh, that's fair. I like the interface of the iPhone's music player, plus I have it mounted high (in front of the cubby) so that my eyes always have some periphery on the road. iPhone + Spotify = all the music I need. :-). This also serves as my nav system. Link to comment Share on other sites More sharing options...
